01-03-2008, 12:11 PM | #1 |
116
Rep 712
Is Overclocking a bad thing?
I am thinking of buying a new desktop PC with Factory Overclocked Intel Core 2 Extreme processor X6800.
Is Overclocking a bad thing to the processor? It will push the speed from 2.9 something to 3.47 GHz. Will that shorten the life of the processor?
SOLD - 2007 BMW 335i Sedan, Montego Blue with Lemon seats, AluFelgen CS7 rims & Continental DW tires
CURRENT - 2018 Chrysler 300S, Crystal Granite Metallic. |
01-03-2008, 12:47 PM | #3 |
116
Rep 712
No idea. Gateway is selling factory overclocked desktop PCs. If the processor went bad due to heat, it should be covered by the warranty.
01-03-2008, 04:39 PM | #4 |
41
Rep 3,200
Gateway is selling something with an extreme overclocked processor?!?! What is the world coming to?
328xi Coupe, Montego Blue on Black with Alum, Step, Sport, Premium, CA, PDC, Cold Weather (Damn Pennsylvania winters)
Current Mods: Heavy right foot - Planned Mods: Lightweight right foot |
01-08-2008, 10:17 PM | #6 |
10
Rep 412
I have a Core 2 Duo 2.4 ghz ov to 3.0 ghz with the stock intel fan. It's definitely possible and quite safe and easy considering you don't go to far. Usually 200-500 extra mhz is attainable and very reliable. Theoretically it will shorten the life span, from maybe 50 years to 40. Seriously you won't have the computer long enough for that to matter. Just go up in steps and read what other people are able to get on other computer forums and online sites. Usually you can find someone who has the same setup and find out what you should be able to get.
"The most important mod is the one behind the steering wheel" - Koyokid RIP
01-10-2008, 03:37 AM | #7 |
399
Rep 3,288
When poeple bring up the topic of over clocking and it's draw backs I just remember alittle saying, "The bulb that shines twice as bright, only shines half as long." Personally, I've never been a fan of overclocking. Is the extra bit that you get from it really going to significantly increase your computing experience? I doubt it. Today's average computers are coming with quad core CPUs anyways, and when not every application even uses multi-threading technology (no multi-threading means it will only run off 1 core). Its one of those "bragging rights" things and it stemmed from people that built their own systems a few years ago and boasted on how they were able to make their system run stably while overclocked. I really see no reason for the factories to overclock the hardware, but if they are doing it and still covering it in warranty more power to em.
I just think that if the chip is able to go from a 2.4 to a overclocked 3.0... then why the hell did the original manufacturer call it only a 2.4? There has to be a reason, and that reason will be your drawback from overclocking.
01-10-2008, 09:09 AM | #8 | |
10
Rep 412
And yes the results are noticeably, mainly in games. Word and Excel might open a little quicker but if that's all you run your probably not the type that would care about overclocking to begin with.
01-10-2008, 11:17 AM | #9 |
364
Rep 5,842
Drives: 2006 325xi
http://www.tomshardware.com/us/
that site is awesome for reading up about new hardware as well as some good info on overclocking. If you are going to overclock, make sure you have very good cooling and make sure you keep an eye on the core temperature. Slight overclocking is fine, but the more you overclock the more likely you are to run into hardware problems and stability of the chip |
01-10-2008, 01:16 PM | #11 |
10
Rep 412
That's true, if you know enough about computers to overclock them your better off building the computer yourself. I have built my last 4 computers and its much cheaper and better I feel. But for my parents I have bought them dells the last two times, for what they needs its much easier.
01-10-2008, 01:44 PM | #12 | |
218
Rep 4,726
Not to mention no one in their right mind would buy an X series anyway, 999 when the 300$ chip right below it will reach the same speeds. X series chips are for people going for world records who need the unlocked multiplier. Something gateway is not doing for you.
01-22-2008, 09:52 AM | #13 |
Rep 207
as long as the temperature remains somewhat close to factory specs.....you should have no worries......most computer gurus overclock...it's simple and safe.....temperature, not durability, is of importance
01-23-2008, 12:02 PM | #14 |
2070
Rep 4,365
Drives: '07 Z4 Coupe, '21 X3, '16 GMC
Never over clocked myself, no need really. I don't play games.
Since it is new, why not just get a faster CPU in the first place?
2007 Z4 3.0si Coupe • 6 MT • Black Saphire Metallic • PP • SP
2016 GMC Sierra SLT Z71 Premium Plus 4x4 2017 Harley StreetGlide • Denim Black • V&H Tune 2021 BMW x30i • Phytonic Blue Metallic • Fully loaded |
02-24-2008, 08:06 AM | #15 |
24
Rep 826
02-24-2008, 12:17 PM | #16 | |
Tired
131
Rep 2,673
If you're not going for e-penis records, I wouldn't get the X. For the price, I got a Q6600 GO (stock is 2.4) and it's comfortably sitting at 3.6 24/7 (prime dual stable for 12 hours). I had it higher (3.9), but I wasn't comfortable with the temps I had since I'm only on air cooling with a Thermalright Ultra 120X. I don't know if the Q6600 is still the chip of the moment, but it was 6 months ago when I built the rig. If you're comfortable building your own system, you'll save money and can build it to your specs. Gateway wouldn't even be on the list of manufacturers I would consider (personally). Good luck either way.
BMW-less
02-24-2008, 12:44 PM | #17 |
Critical Care Anesthesiologist
481
Rep 8,828
Drives: SMB F83
There's certainly harm done to the CPU but like Sanford said, with proper cooling, the heat is very manageable. I personally prefer Zalman's cooling solutions. I built my current system almost 3 years ago, so I'm pretty much outdated on the hardware scene, but I can attest that my Zalman copper flower worked very well and allowed me to safely overclock my Athlon XP CPU.
Go to newegg.com to shop for the components that you like and build it yourself. It might not save you cash, but you're in control of what to put in your system and it's loads of fun building your own computer.
kev { divinum est sedate dolorem }
"your friendly neighborhood critical care anesthesiologist" |
02-25-2008, 08:57 PM | #18 | |
15
Rep 397
And, yes, it makes a difference...starting Vista, starting Photoshop, ripping DVDs, etc. etc.
2018 WRX
2014 C63 507 1991 Mr2 Turbo |
02-29-2008, 02:02 AM | #19 |
Rep 9
Like someone said above, overclocking will reduce the life of your processor, but I can guarantee you that you will be buying a new computer way before that ever happens (if done right of course).
If you provide sufficient cooling and you have a pretty solid processor, overclocking (within a reasonable amount) is nothing to be afraid of. HOWEVER, I don't know if buying an OEM overclocked Gateway is such a great idea. Now-a-days you can probably get a better processor and build yourself something much nicer for the same price or less. Then, overclock at your discretion and give it some good cooling. I also think it's important to get yourself a nice, well designed case. Or, just spend a few extra bucks and buy a faster processor to start with |
03-04-2008, 10:40 PM | #20 |
479
Rep 298
Overclocking is so so so 90's. It was very popular back in the 90's because computers MHZ evolved so slowly and prices of CPU and memory was oh so expensive. Now, CPU speeds go up by the hundreds within months. Everyone owns a computer and the prices have gone down BIG TIME! Back then, you'll have to wait years to have a 33MHZ to go to 66MHZ. Unless you want to screw up your CPU and have your programs crash unexpectingly, avoid overclocking.
Does anyone here remember the days when 1 MEG of RAM cost 50 bux? I still remember when original DOOM game required 4 MEGS of RAM min. to run the game and a 386 CPU which was insanely slow when compare to today's standards but the coding of the game was, in my opinion, as masterpiece!!!! 4 megs of RAM with a 386 CPU is slower than most of today's cell phones but none of the cell phone's games are advanced as the original DOOM game. I just laugh when games of today require like half a gig of memory to run. Programmers/Coders of yesterday are WAY WAY WAY more talented. |
03-05-2008, 01:07 AM | #21 | |
41
Rep 3,200
