charge pipe question
10-23-2014, 02:16 AM | #1 |
Rep 139
*Note* you don't have to read the whole thing can just skip to the question in the second paragraph and c the picture.
So i recently just installed the ER charge pipe into my 335i with HKS bov. I made sure everything was plugged and tight in correctly. But then when i tried to test out the BOV by stepping on gas some weird sound came out. The first high pitch after I let off the throttle sounds perfect and normal but as the air blows out from the BOV I hear another sound. Not sure what that second sound is but doesn't sound normal. The only thing I concerned and think it might be is probably how I attached the CP to throttle body. Pic below So my question is it ok to use this stock c clip instead of the coupler? thank you |
10-23-2014, 03:20 AM | #2 |
77
Rep 980
Drives: '08 BSM 335i e92
Using the stock C-clip is actually the preferred method over the aftermarket coupler. When installed correctly, the stock C-clip wont leak or lose boost. The coupler may end up leaking and losing boost or blowing off at some point. Just check the connection and make sure it's installed correctly.
'08 BSM E92 335i 6MT/MHD stg 2+/VRSF 7" FMIC/VRSF CP/HKS BOV/VRSF catless DPs/BMS DCI/muffler delete/BC Extreme lows/OEM style 167s/BMS high side OCC/Mishimoto low side OCC/etc
10-23-2014, 03:50 AM | #3 | |
Rep 139
10-23-2014, 07:29 AM | #4 |
533
Rep 2,872
Use the stock C-Clip, the couplers have been known to pop off the throttle body. Just make sure when you put the CP onto the throttle body, the O-Ring is seated, you may have to push the CP up onto the TB then push down the C-Clip.
BSM E90 6MT-JB4 G5 ISO-BMS DCI-Golf-Tee Mod-Hankook S1N2 Non-RFT-ER Chargepipe/TiAL BOV-E40 blend-VRSF V2's-M3 CDV-MHD/JB4 FLASH-VRSF 5" STEPPED FMIC
10-23-2014, 10:13 AM | #5 |
3441
Rep 79,211
What everyone else said, stick with the C clip and don't forget to re-use stock o ring or use supplied depending on which charge pipe you have. ER uses OEM, VRSF supplies a new one ( o ring).
10-23-2014, 01:23 PM | #7 |
41
Rep 428
So I assume when you get a new charge pipe you dont need a new c-clip, if your existing one is still intact?
M-Sport|OFT Tune|PE Exhaust|VRSF CP|Coded/Alpina Flash|15% Tint|Cyba 3.8 Chrome Tips|Splitters|Lux H8 160|M3 Spoiler Lip|Gloss Black Grille|12mm Spacers F/R
10-23-2014, 01:27 PM | #8 |
2095
Rep 43,350
You would use your existing c-clip. Generally when someone "loses" their c-clip on a broken OEM CP it's because it fell into the undertray when the OEM one failed.
10-23-2014, 03:27 PM | #9 |
BimmerPost Supporting Vendor
24198
Rep 190,805
Good catch
