F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > CAFD Coding Error
GetBMWParts
      10-22-2014, 09:22 AM   #1
RSnic
RSnic's Avatar
Drives: 2020 M340Xi (G20)
2020 BMW M340  [0.00]
CAFD Coding Error
Hi,
Finally got camera control module, TRSV, connected; neither the camera switch nor the iDrive screen icon, however, will activate either the rear or side cameras. I, therfore, thought that I had to inject CAFD into this ECU.
So I went on about injecting CAFD as per Shawn Sheridan's super instructions and when it came time to select CAFD, I selected the most current one listed, associated with F020-14-503.
When I got all done, I got two errors:
cdDeploy ProcessedWithErrors
cafd_0000223-013_009_007 NotExecutable
Here's my I-Step levels:
  • Current: F020-14-07-505
  • Last: F020-14-07-503
  • Shipment: F020-13-07-503
I am using E-Sys version 3.24.3 & PszDdata version 53.4 lite
What do I have to do to correct this error? Most importantly, what are my next steps?
Appreciate any help or thoughts
Al
2020 M340Xi| ZDA| ZDY| ZPP| ZPX| 1CR| 1PL| 688| 6NW| 2VFH|
Retired: 2014 328i
BMW CCA
      10-22-2014, 09:58 AM   #2
carzaddict
158
Drives: 2015 Cadillac Escalade ESV
if i remember correctly.......i think you need the FULL version to inject a CAFD. Lite version is only for coding a CAFD that already exists.
I may be wrong on this.
2015i Cadillac Escalade ESV
      10-22-2014, 10:08 AM   #3
kitster
United Kingdom
541
Drives: G31 M Sport
The lite version is fine for coding. If you want to flash new firmware onto a ECU you will need the full version.
      10-22-2014, 10:53 AM   #4
RSnic
RSnic's Avatar
I have been using the PszDdata lite version; ShawnSheridan suggested that the only instance when you need the full version is for flashing an ECU.
As I continue to scratch my head and dig into this further, I ran into something odd.
Using Token Master's CAFD/NCD tool (Terrific tool, by the way!), I got all of the specific coding items that the three options (508 for both PDCs, 3AG for rear camera & 5DK for side cameras) I added to my VO would affect. I then compared the post-VO-coded NCD files of the three affected modules (ICM, HU_NBT & REM) with the list I got from the tool.
All items were an exact match except for the following:
HU_NBT > ExBox 3001 > TRSVC. This item was VO-coded in the car as 41, but the list showed it as 81 (and I even tried for each of the two camera options separately and then all).
Could this be the cause of my problem as I have no way of figuring out what these values represent??
Very much appreciate any help or counsel
Al
Retired: 2014 328i
BMW CCA
f30post
