10-21-2014, 09:10 AM | #1 |
508
Rep 929
A new way to be mad!
I have been watching my TPM system on the screen, watching temps and tire pressures go up, driving me nuts since it gives reading in tenths of a pound, and they all go up in such a strange way, certainly not uniform. I kind of liked the old days where you put 32 lbs at each corner and drive off feeling you have done your job. As I drive i see all kinds of weird pressure increases. Yesterday I spent some time balancing the pressures so they would be even when hot, and find that it is not repeatable on subsequent drives, anyhoo thought I would rant a little. Anyone else feel free to chime in.
10-21-2014, 09:22 AM | #2 |
1791
Rep 2,995
You sound like you are not ready to handle this level of data
Tire pressures, when driving, ARE going to be uneven. Different tires heat up in different patterns due to turning more one way or another, banking of the road, activation of the diff, etc. Your goal is simply to find the hot temp most commonly encountered for your purposes and set the tires evenly to your desired PSI at that point. It will not remain even, that's pretty near impossible, but it will be as close as possible to that "ideal" PSI once warmed up. I can tell you that my tires are running 30 degrees cooler due to temperature changes right now and that my steering feels....off.....until they warm up because the fronts are too low at that time. I can't accomodate that ahead of time - I need to re-establish my tire pressures now that the weather has cooled.
AW/Carbonstructure 6MT 2015 M3 picked up 8/22/2014. Stripper except for adaptive suspension. Weighed at 3,450 pounds with 1/4 fuel. 70,000 miles as of February 2020.
10-21-2014, 09:27 AM | #3 |
978
Rep 2,701
The warmer the tire the higher the temp. TPM goes off when you go down by 3 lbs from where it was set. I always make sure tire is cold when checking at home then adjust at home from a portable air source, otherwise keep in mind by the time you drive to where air is, then adjust setting by 2 lbs or so since your 30 will look like 32 now.
Got It: F82 2015 M4 Alpine White / Silverstone
With integrity nothing else matters, without integrity nothing else matters. |
