Misfire and Low RPM Idle
10-20-2014, 12:54 AM | #1 |
Rep 23
Getting a persistent misfire on cylinder 6. I have changed the plugs, coils, and injectors on all the cylinders. The injectors were coded correctly and I installed new decouplers. HPFP and carbon clean were taken care of as well. I have a really rough cold start with rough idle after until the car is warmed up. The idle after the car is warm is low, it is around 550 rpms unless I have the AC on. Any input on these issues?
10-20-2014, 02:12 AM | #2 |
53
Rep 398
I have been having the same issues but have not replaced my leaky injector. I diagnosed the injector purely by replacing the plugs and plug 6 was drenched in fuel.
This is not your case since you have replaced all the injectors. |
10-20-2014, 10:10 AM | #3 |
98
Rep 1,321
Drives: Truck in snow, coupe in summer
Have you tried cleaning and switching the solenoids? Oil change?
2009 BSM E92 335xi - RR600's/FBO-VRSF/Apex Arc 8/Wedge E60 MHD/Fuel it Stage 2/BMW PE w/ Dimisa Tips/Alpina TCU/Dinan Springs/RB Inlets/3.5 Bar TMAP
10-20-2014, 11:38 AM | #4 |
Rep 23
10-20-2014, 11:54 AM | #5 |
3441
Rep 79,211
Out of curiosity, I would look at the plug on cylinder 6. I know you replaced the injector and plugs but that doesn't mean the injector couldn't be defective.
Also crack in the valve cover or a leaky valve cover gasket can be the culprit too. |
10-20-2014, 12:05 PM | #6 | |
Rep 23
Could a bad TMAP sensor cause this? |
10-20-2014, 12:08 PM | #7 |
3441
Rep 79,211
Hmm, they usually don't go bad unless they were beaten up during install or something. You could pull it out and clean that for peace of mind. Otherwise I'm a little stumped. I've ready before of a few hiccups after a walnut blast but I can't recall off the top of my head what the fixes were.
10-20-2014, 12:15 PM | #8 |
Rep 23
Yeah, I am really confused on to what is going on. I had 29d2, 29d0, and 29cc after I cleaned the valves, so I changed the plugs and injectors and the car was fine for a couple of days and now I have 29d2 again and rough starts.
Car pulls hard when I give it the beans. I am getting an abnormally loud injector tick on injector 3 but no codes specific for that cylinder. |
10-20-2014, 12:24 PM | #9 |
Custom User Title
50
Rep 247
mods? i have a similiar issue, idels at 600 until warm then it stays a bit over 700 when warm. i can feel misfires when its warming up, but stops once its warm, i got no CEL or anything for it...
10-20-2014, 12:27 PM | #11 | ||
3441
Rep 79,211
Edit- I see you just replied, hmm Do you have a BT Tool? Quote:
Have you fresh spark plugs, good coils and injectors not leaking? |
10-20-2014, 12:32 PM | #13 |
3441
Rep 79,211
10-20-2014, 12:35 PM | #14 |
Rep 23
I had factory plugs before I changed to the Bosch oem ones, I switched back to the old factory ones to see if that would help but there is no change. I have reset the adaptation with the car running, should I go through and reset everything with the car off?
10-20-2014, 07:58 PM | #15 |
98
Rep 1,321
How do you reset adaptations????
I just replaced plugs, coils and injectors....Thanks
10-21-2014, 10:58 AM | #18 |
Custom User Title
50
Rep 247
rough idle is a sign, but hard to tell without hearing or seeing, cause it could be a misfire, could be a timing. looking at the rpm description you gave, i want to venture and say solenoids are bad/going bad. did you try swapping them around? i had a solenoid damn near fail on me, i swapped them around and the car ran a bit better, but eventually starting acting up again. on the sidenote though, yours is cylincer specific... so, even a cracked valve cover/gasket, i would think would effect all cylinders...
10-21-2014, 11:02 AM | #19 |
3441
Rep 79,211
I usually did it with the car off so it didn't freak out.
10-21-2014, 11:04 AM | #20 | |
Custom User Title
50
Rep 247
mods are DCI, downpipes, and jb3 |
10-21-2014, 11:04 AM | #21 | |
964
Rep 3,854
Drives: 330i, 135i
10-21-2014, 11:07 AM | #22 |
Custom User Title
50
Rep 247
GoRomeo has a good point.. OP do you have a boost gauge? check and see if your hitting marks with boost/vacuum.
and maybe check your t-taps if you do? idk... jus shooting ideas |
