Turbo Siren
10-19-2014, 08:21 PM | #1 |
292
Rep 1,473
Turbo Siren
I have a FBO PTF tuned Z4 35i DCT and I have been experiencing the turbo siren. It happens most often when cold and between 2300 and 2700 rpm. I am on stock turbos and the noise doesn't seem to affect my boost or performance in any way. Is there any thing that I should do.
10-19-2014, 08:35 PM | #2 |
127
Rep 865
Drives: BMW X3 35i, Porsche Macan S
Common result from having a tuned car. I wouldn't worry about it unless it gets much worse.
MOTIV 750 ST | MOTIV PI | 100% E85 | Fuel-it Stage 4 LPFP | MOTIV Boost Box + MHD Protune | Quaife | Öhlins | Brembo | Akrapovic
10-20-2014, 10:26 AM | #3 |
100
Rep 1,040
I'm in the same boat. Been making noise ever since I installed my cat-back exhaust in August. Does not seem to be affecting performance at all, but still annoying.
2009 335i M Sport coupe, BSM with black/aluminum interior, 6MT, JB4 G5, MDH Backend Flash, Walbro 255 inline LPFP, VRSF Inlets, BMS 3" catless DP's, Borla Aggressive catback, ER FMIC, ER charge pipe, Tial BOV, BMS 2.3 gal Meth Kit, BMS Sport Oil Cooler Valve, Ported CDV, RB PCV, Cyba ram air scoops, Status Gruppe SRS coilovers, ECS trailing arms, Forgestar F14 SDC.
10-20-2014, 04:03 PM | #4 |
221
Rep 365
check to see if the turbo inlets are aligned properly, when installing an intake they can get knocked around and slide off the turbo. particularly the rear turbo
10-20-2014, 04:06 PM | #5 | ||
3441
Rep 79,211
A slight siren is normal, especially when it gets colder out. If your blowing smoke out the exhaust and or having boost issues then it would be somewhat of a concern. My turbo's were making the sire noise since I bought the car new. |
10-20-2014, 04:24 PM | #6 |
BimmerPost Supporting Vendor
24199
Rep 190,807
Siren is normal (depending on how loud it gets)
If you post a video we can definitely help or you can compare it to another local car that is tuned too
10-28-2014, 05:59 PM | #8 |
292
Rep 1,473
Okay here is a video of what I am hearing.
I tried to get the microphone close to the turbos on the passenger side but the turbos are making this noise around 2500rpm. Turn up the volume. |
10-28-2014, 08:13 PM | #10 |
Out Boosting...
242
Rep 3,987
my damn car is louder than a turbo diesel f350 when its cold and i am driving. Think its normal as the car runs perfect.
Alpine White M-Sport F30
10-29-2014, 10:12 AM | #11 | |
100
Rep 1,040
This is exactly what mine sounds like. Starts at around 1800 RPM to about 2800 RPM... Its annoying and I heard it right after I installed my exhaust. I am going to double check my inlets as I had to bang the X pipe on when installing the Borla. Jeff, is this how yours sounds?
