10-19-2014, 10:55 AM | #1 |
147
Rep 477
Steering Column Buzz Over Rough Pavement
I've got a buzzing noise coming from the plastic around the steering column when driving over rough pavement. All I need to do is to put my finger on either the upper or lower part of the column and the noise stops. I was thinking of padding the mating surfaces of the upper or lower part of the column.
Does anyone know how to remove the plastic cover on the column that sits on top of the signal and wiper stalks? |
10-19-2014, 06:45 PM | #2 |
BMW CCA #257
75
Rep 190
I had the same issue. I turned it over to the dealer to fix (their responsibility) and they fixed it on the first try. I think they removed the panels and packed the area with insulation.
10-20-2014, 06:32 AM | #3 |
5945
Rep 3,292
I had the issue, too. Mine only happened at above 60 mph and, from where my dealer is located, during the day it's nearly impossible to get up to that speed on Portland highways. I had to poke my dealer a couple of times before they dealt with it, but they did.
10-20-2014, 11:17 AM | #4 |
I want to drive a Zamboni
1132
Rep 5,558
Drives: 13 E93 M3 18 F80 M3 16 K71
Do they fixed the problem? Mine had the same buzz noise and drove me crazy.
18 F80 Imola Red 6MT
16 K71 F800GT Montego Blue 13 E93 M3 Melbourne Red 2000 E46,2006 E90,09 E82,13 E93 328i,14 F30 335i,18 F80 M3 My next vehicle would be a Zamboni |
10-20-2014, 02:24 PM | #5 |
5945
Rep 3,292
They did, eventually. I never brought the car in for just the buzz. I brought it up when I brought it in for the vacuum pump recall, then when I bought my 397 wheels, and the third time was when I discovered, 8 months into owning it, that my driver's-side rear folding seat did not, in fact, fold. I was respectfully blunt about not caring if they could reproduce it and the service manager took a look at it himself and decided that plastic was moving too much when he poked it.
They took it apart, foam-taped it or whatever, and put it back together. It doesn't rattle/buzz now, and it doesn't flex when you poke it. It's possible that they didn't get paid from BMW for fixing it under warranty as they never verified the problem actually existed, but in the end they helped keep a customer happy. Last edited by bri1042; 10-20-2014 at 02:24 PM.. Reason: a letter escaped and I had to catch it |
10-20-2014, 03:13 PM | #6 |
179
Rep 713
I have a similar issue most notably on grooved pavement while they prep for a new layer of asphalt. For me I found it to be the vinyl that attaches to the steering column under the cluster. If I apply light pressure to the vinyl or move it a bit, it goes away for a bit and then returns. I figure when I'm in for the next service in a couple thousand miles I'll let them know and they can sort it out, but should be an easy fix.
Good luck with yours.
10-20-2014, 03:59 PM | #8 | |
147
Rep 477
10-20-2014, 07:59 PM | #9 |
BimmerPost Supporting Vendor
569
Rep 987
Drives: 2022 X4 M Competition F98 LCI
I had the same issue. Told them that it has to be the steering column covers, they first applied more insulation but that didn't help. Asked them to replace the covers, which they finally did. No more buzzing!
