TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > V2 Data Log enclosed
      01-02-2008, 09:50 AM   #1
yahtzee
El Capitan
yahtzee's Avatar
Drives: fast
Just a brief data log after resetting my ecu and reloading 12/29 map without moving percentages....
I am going to drive another 40 or so miles before making any changes.....this format looks nothing like I have seen from others.....looks like boost peaked at 12.9.
      01-02-2008, 10:46 AM   #2
Driver72
327
Drives: 335i - to new owners now.
"Brief datalog"???
That's a very long datalog of nearly 9 minutes.
With a datalog of more than a minute or so, it's very hard to compare boost vs rpm
      01-02-2008, 11:48 AM   #3
Tuned335i
24
Drives: E92 335i
Zoom in on one pull and hit the "P" key to reset the scale on the boost graph. Change the minimum value to 0 and check off the "auto scale" box. That will reset the scale so that your max boost pressure is the top end of the scale and you'll be able to tell what your peak was (not the spikes).
You can also cut and paste the pulls to make them larger and easier to read and compare boost vs. rpm.
FWIW, your pull at approximately 300 seconds looks normal to me, but it's hard to tell without zooming in on that specific pull...
      01-02-2008, 12:40 PM   #4
yahtzee
El Capitan
yahtzee's Avatar
Drives: fast
Ok, so I learned that the one I had posted earlier wasnt "brief."
Here are two from just a bit ago.....
the first one is a 3rd gear only pull and the 2nd one is a pull in 2nd gear as well as 3rd gear. What does this info tell you? (I know it tells boost and RPM but what would you do with this info?)
      01-02-2008, 01:02 PM   #5
e.n335
Moderator
e.n335's Avatar
Austria
270
Drives: e93 ///M3 DCT, 07/2009
First picture: It tells me that you have the same issue as I have. When you start accelerating, boost is build up first ( 3000 to 3800 rpm ), then it drops down until 4600 rpm and builds up a second time until 5600 rpm. From there it tapers down normally until you shift at 6300 rpm. I don't understand the drop down, IMO this is not normal. The max. boost you are getting is a boost spike after lifting the pedal, this is normal and not seen by the engine thus the throttle is closed.
      01-02-2008, 01:09 PM   #6
yahtzee
El Capitan
yahtzee's Avatar
Drives: fast
Originally Posted by e.n335 View Post
First picture: It tells me that you have the same issue as I have. When you start accelerating, boost is build up first ( 3000 to 3800 rpm ), then it drops down until 4600 rpm and builds up a second time until 5600 rpm. From there it tapers down normally until you shift. I don't understand the drop down, IMO this is not normal. The max. boost you are getting is a boost spike after lifting the pedal, this is normal and not seen by the engine thus the throttle is closed.
I wondered about that....How long should I drive on 90% before bumping it up?
      01-02-2008, 01:24 PM   #7
e.n335
Moderator
e.n335's Avatar
Austria
270
The interesting thing you see in the second picture is that you have the same behavior when you start accelerating the first time ( at different rpm's ), after the shift you have a boost curve as it should be ( no boost drop, just normal tapering down ). Your car behaves exactly like mine.
I think it's fine to raise the torque values up to 92% across the board as soon you have driven your 50 miles with 90%. I would not raise more until we see how the next map ( v2.0.3 ) behaves. It is announced for end of Jan. / 08.
Up to then I will have my Forge Diverter Valves installed and we will know whether the Diverter Valves have a positive impact or not.
- Eugen
      01-02-2008, 01:51 PM   #8
ontopofm
76
Drives: stock
V2.0.3 will not be available until the end of the month? dang 1 long month
      01-02-2008, 02:05 PM   #9
yahtzee
El Capitan
yahtzee's Avatar
Drives: fast
Any idea what it's going to provide?
      01-02-2008, 02:13 PM   #10
e.n335
Moderator
e.n335's Avatar
Austria
270
Shiv said we will be surprised
Gear-depependent user torque settings seem to be implemented. The O2 simms functionality for catless downpipes is announced. Customers are waiting for downpipe maps.
And hopefully other happy surprises ...
V2 has been announced originally with launch control and O2 wideband sensor support ( e.g. Innovate Motorsports LC-1 ). A additional physical valet-switch for switching maps "on the fly" would be great for WIS failsafe support.
The PROcede is a good device with a lot of capabilites. Shiv is an excellent tuner who knows the N54 engine and the PROcede interceptor in and out. Better quality and better customer relationship with better order management is key for the interceptor benchmark in 2008.
- Eugen
      01-02-2008, 03:25 PM   #11
335iheLLraiseR
اوليسيس
335iheLLraiseR's Avatar
Drives: e92 335
2007 e92 335  [10.00]
- Eugen
+1
Originally Posted by lawdude View Post
Anyone who can transition seamlessly from defending one vendor and bashing another vendor to bashing the one he formally defended and defending the one he formally bashed has a instant credibility problem.
<---Sign up Now for Bonus Storage! Up to 10gb!
      01-02-2008, 10:25 PM   #12
zenmaster
Drives: '17 M2
Does it fix limp mode? Just got another one today and noted gear, RPM and ambient temp: 6MT 4th gear, 5200RPM (downshift from 6th), 26 F.
      01-02-2008, 11:00 PM   #13
335iheLLraiseR
اوليسيس
Drives: e92 335
which map? 12/11 or 12/24?
      01-02-2008, 11:41 PM   #14
zenmaster
Drives: '17 M2
12/11
      01-02-2008, 11:45 PM   #15
e.n335
Moderator
e.n335's Avatar
Austria
270
update to the latest map ?
