How to diagnose injector failure
10-16-2014, 07:17 PM | #1 |
63
Rep 298
My 335 started throwing codes about 3 weeks ago. Misfire on all cylinders but one.
I don't know what was previously done, but with 55k miles, I went ahead and replaced coils and plugs. I have attempted to clear codes with the JB4, but the CE light is still there. The only other thing I can think of is injectors, but didn't know if there was a way to diagnose this easily or not. I have the Maxcare warranty, but I want to make sure there isn't something missing before I have to remove the jb4, and take the car in. Thanks |
10-16-2014, 08:48 PM | #3 |
49
Rep 537
May not be same as you but my car threw multiple misfires and i did everything people recomended and still misfire. Finally gave up and took to dealer. They diagnosed it and replaced TMAP and all is well.
Maybe try replacing that as it is cheaper than 6 new injectors. |
10-17-2014, 08:51 AM | #4 |
63
Rep 298
Thanks for the feedback. Still looking to see if there is a way to easily diagnose this. I have an aftermarket warranty, so looks like it will just be going in for service. I just thought this topic might help others out as well.
10-17-2014, 09:06 AM | #5 |
I even mod my cereal
246
Rep 3,441
Drives: 11 ZCP DCT M3 14 328d 21 GT4
what code(s) is still showing up now?
2011 Mineral White M3 ZCP - Opticoat, Ventureshield, some CF, B&B exhaust, AFE Intake Vorsteiner VFF 101s Ohlins
2014 Mineral White 328d Xdrive Wagon - Opticoat, Ventureshield, B8s, H&R, Apex SM-10s Hawk Pads 2021 718 Cayman GT4 - Fire extinguiser |
10-17-2014, 09:15 AM | #6 |
63
Rep 298
I'm at work, so I will have to check again when I get home. But it is still showing misfires on 5 cylinders.
I drove around for a bit after changing the plugs/coils, cleared the codes with the JB4, drove around some more. Service Engine light never went off. It's fine cruising around, but if I go WOT it's choppy/chugging. Hard to explain, but almost a very quick pulsating. |
10-17-2014, 09:18 AM | #7 |
246
Rep 3,441
Post the code(s) when you get a chance
10-17-2014, 09:41 AM | #8 |
98
Rep 1,321
Drives: Truck in snow, coupe in summer
Sounds to me like injectors. I also replaced plugs and coils soon after I tuned the car. About a month later I got the exact same thing happening with my car. I installed 6 new injectors with 13 index and Idle is much improved, however I am not able to go WOT as they are not coded yet.
Good luck man
2009 BSM E92 335xi - RR600's/FBO-VRSF/Apex Arc 8/Wedge E60 MHD/Fuel it Stage 2/BMW PE w/ Dimisa Tips/Alpina TCU/Dinan Springs/RB Inlets/3.5 Bar TMAP
10-17-2014, 10:34 AM | #9 |
162
Rep 1,264
Its a few injectors going bad, do you have a rougher idle on a cold start? That's a common sign, or when you changed your plugs were any wet?
2010|335i|LMB|E92|6MT|MSport|Logic7|335is Clutch|AE Performance|BMS|Walbro|VRSF 7"| 149.7mph NFZ AZ 1/2mi
1992|Pontiac Firebird|Mild 355ci|T56| -I will look on your treasures, gypsy. Is this understood?- |
10-17-2014, 11:12 AM | #10 | |
63
Rep 298
None of the plugs were wet, and all looked pretty similar. |
10-17-2014, 11:52 AM | #11 |
31
Rep 150
10-17-2014, 01:08 PM | #13 |
246
Rep 3,441
I have a bad injector and do not have symptoms like these (and every car is different). Maybe multiple injectors could cause this, but I was also thinking about the HPFP. Have you had yours replaced at any point or issues with it before?
10-17-2014, 09:31 PM | #15 |
61
Rep 174
I had just one injector fail and the car couldn't be driven, it idled like a two stroke and gas was dumping out of the tail pipe. You could have injectors on the way out, you will know when they actually fail. Maxcare only fixed things AFTER they broke on my Audi. You should be fine though.
10-25-2014, 08:44 PM | #17 |
21
Rep 268
When my injector went I had missifire in cyl 6 ... I replaced injctor 5 with 6 and the missfire moved to 5 ..I only replaced 3 not all 6.
You may want to remove the jb4 any way no one wanted to touch my car when I took it in they all said they could not read the codes etc |
10-27-2014, 08:23 PM | #19 |
63
Rep 298
Well something weird happened.... the SEL wasn't on this morning when I started the car. Made some WOT pulls, everything felt pretty smooth. Decided to take some logs, so if anyone can take a look at them, make sure everything looks OK..
