For all those who have done the "PE Mod"...
10-16-2014, 06:14 PM | #1 |
N54 E92
51
Rep 342
I'm planning on hacking open the exhaust on my e92 and have a few questions before I dive in. I'm planning on just "straight piping" the straight sections, not all 4 perforated pipes.
Some images I found showed a cat. shaped section on the driver side muffler, what is the purpose of this piece? Does it exist on both E90/E91 or is it just found on E92/E93s? Should it also be straight piped? Also, does both the top and the bottom of each muffler need to cut to gain access? (What if someone was to cut a section of pipe similar to a "roll pin", cut the hidden side of the mufflers open, wrapped it around the existing pipe, and welded it in place?)
Light Bolt-ons, Tunes, & Methanol Injection: 12.30 @ 115mph [2.0 60ft on Street Tires] [91 Octane] 1.59 Seconds Faster than Stock [as of 05/29/2014] Previous Vehicle: '65 Chevelle [LSx 6.0L/4L80e] |
10-16-2014, 07:59 PM | #4 |
53
Rep 398
Are you sure you read it properly?
I don't think it said to remove all 4 perforated pipes. I am sure it said to just replace the straight pipes with solid pipes as you are planning to do. The cat shaped section in the muffler is a resonator, you need to remove it if it is present. |
10-17-2014, 04:16 PM | #5 |
146
Rep 563
^^+1. Yes all 64 pages. Just like every one else did that was interested in the mod.
Cut the top side of the exhaust box's open. Locate the 2 straight pipes. 1 with resonator and 1 with perforated pipe. Replace both of these pipes with solid pipes. Add tips and away you go. |
