Gas Mileage! (Yes another thread)
10-16-2014, 02:46 PM | #1 |
65
Rep 243
Quick question for those who are more knowledgeable than myself.
I hear driving normally, people get around 22 mpg with a mix of city and highway. However I am having a very hard time keeping even a 20mpg avg while I am babying it as much as I can. Are there any common issues that lead to poor fuel economy? I did have a stored P2A17 code in my DME. I havent checked if it came back or not. |
10-16-2014, 03:59 PM | #2 |
36
Rep 1,176
What kind of fuel are you running?
I get between 11 and 14 mpg with mostly city driving, but I am running around an E50 blend. If I do a lot of highway miles, the mpg increases, but I don't drive on the highway as much as I used to. I've found that running E85 blended with 93 has resulted in significantly worse miles per gallon, but much more smiles per gallon.
335i Coupe, JB4 (G4, map 5) DCI and 40% E85 blend: 2009 BMW 335i Coupe: 12.173 @ 109.490 MPH
10-16-2014, 04:08 PM | #3 | |
533
Rep 2,872
10-16-2014, 05:29 PM | #4 |
3441
Rep 79,211
I averaged 22 MPG for years in my 335i that was mix of mostly spirited driving, cit and highway. On a bad week I'd average 19 with heavily spirited driving.
Best way to save gas is watch your boost and stay out of it during acceleration and throttle transitions. If that code keeps coming back it may be the cause of your mpg but typically driving habits account for a 35% increase or decrease in MPG. E85 uses about 22% more gas then 91-93 octane. |
10-16-2014, 09:06 PM | #5 |
65
Rep 243
19 with heavily spirited driving would be great. I struggle to get 20...
I use sunoco or BP 93 oct only. I dont think a carbon cleaning has ever been done |
10-17-2014, 05:06 PM | #8 | |
3441
Rep 79,211
Carbon cleaning should help anyone with over 35,000 miles but like I said before, that MPG can really sway a lot on your driving habits, throttle transient between gear changes and overall how much you stay out of boost. As soon as you enter 1-3 psi of boost you use significantly more fuel then if you stayed in vacuum. Those of you who know tuning and knowing fueling know how much more fuel is required for boost fuel tables VS vacuum fuel tables of the same power. There was a time when I had an aftermarket A pillar boost gauge on my car before all the gauge hi-jacking and stuff and I'd literally accelerate just enough to stay out of boost, which would maximize MPG by no accident. |
10-17-2014, 05:07 PM | #9 |
162
Rep 1,264
around 18-19mpg mixing E45-50 mixed driving. I can get that quite lower if I push the GO pedal more.
2010|335i|LMB|E92|6MT|MSport|Logic7|335is Clutch|AE Performance|BMS|Walbro|VRSF 7"| 149.7mph NFZ AZ 1/2mi
1992|Pontiac Firebird|Mild 355ci|T56| -I will look on your treasures, gypsy. Is this understood?- |
10-17-2014, 06:09 PM | #11 | |
61
Rep 722
18-20 mpg on only 93 with 95% city driving. Much worse on e85 tanks but thats mainly because im always on it with e85 however there is significant mpg loss with e85 blends
11' m57 335d 165k Miles - JR 2, ATM Full Exhaust & Intake, Wagner FMIC, AAR Boost Pipe, AAR Swirl Delete, AAR EGR Delete
08' n54 135i FBO E85 - SOLD |
10-18-2014, 09:40 PM | #13 |
17
Rep 329
Damn i feel lucky. Don't drive crazy but I do enjoy the throttle on the clovers. 60% hwy 40% city a good amount of mods and I'm at 29 mpg's. 42k miles on my 07. No carbon cleaning and original plugs.
2007 e92 n54 - sold 2003 e46 M3 - sold 1999 e36 M3 - sold |
10-19-2014, 08:47 PM | #16 |
65
Rep 243
My commute to work is a traffic lighted highway. Basically .5-2 miles, stop, .5-2 miles, stop, ect
But I think a 20 avg is low. And that 20 avg is after a 70 mile highway trip. Before that my avg was 18.9 |
10-19-2014, 09:45 PM | #17 |
Rep 28
I'm averaging 17 around town but can get as high as 34 on the highway (a steady 65-67 mph). However, I run my tires 7 psi lower than the max tire pressure. The ride was a little bumpy on run flats but once they were swapped out the ride is tolerable.
Silver 2007 335xi
10-20-2014, 02:34 AM | #19 |
34
Rep 1,093
Get about 22-24mpg on avg. mix city highway but it's mostly a 50mile commute to work each way. I avg 650-700km a tank.
07 335XI (A008006) 6AT ~94K miles JB4 G5 ISO VSRF DP's
09 135I M (VK80379) 6MT. Race Project car. 1) Install Cobb/piggyback? and Motiv 600 Kit[HTA3076R w/ tial .82] 2) JRZ or Moton suspension. 3) Build high flow intake manifold with multi-port fuel and relocate OFH 4) Build full cage 5) Complete staged twin setup with HTA4205R [w/Tial 1.16] 6) Complete dry sump system |
10-20-2014, 10:05 AM | #20 |
Rep 150
I was getting about 21 mpg mixed hwy/city. I got new tires and alignment, now I'm getting 24-27mpg. Alignment was terrible.
Still need carbon cleaning. I'm at 75k miles. Tuned everyday.
2008 335i Coupe TiAg - Cold Weather - Premium - Sport - Style 230 19's - SatNav - Active Steering/Cruise - Comfort Access - PDC
