RB TURBO question
10-16-2014, 11:36 AM | #1 |
Live life to the fullest!
12
Rep 175
RB TURBO question
Hey guys been looking into the RB turbo option. I'm debating about what setup to go with. Currently I have FBO with Cobb protune from Pro Tuning Freaks. I have a BMS meth kit and JB4 but not installed yet. Debating whether to go with cobb protune and no meth with RB's or BMS backend flash with jb4, meth and RB's? Any feedback would be great. Thanks
FBO - CPE DP'S, CUSTOM CXRACING FMIC, STETT CAI, KW'S, COBB V3, WEDGE PRO TUNE, ALPINA B3 FLASH
10-16-2014, 11:45 AM | #3 |
12
Rep 175
Thanks Jeff. Ya the meth is the only thing I worry about. Has to be perfect. Also how much HP/TQ can the 6AT handle? I know I should have stuck with 6MT but this car was immaculate!
10-16-2014, 11:56 AM | #4 | |
Lord Scrip
1815
Rep 3,013
Drives: 2011 M3 Coupe
10-16-2014, 12:11 PM | #5 | |
533
Rep 2,872
10-16-2014, 12:26 PM | #7 | |
456
Rep 6,478
With a single you can make 550-600WHP, the torque curve is a bit more gentle. I'll have a definitive answer v soon PS OP - go with PTF. It's not even a question, and I have tons of respect for BMS. But nothing beats PTF on this platform.
E88 N54 Alpinweiss/Coral Red/Motiv HTA 3586r Tial .82AR/Other stuff...652WHP
F30 N55 XDrive EBII |
10-16-2014, 12:44 PM | #8 | ||
Lord Scrip
1815
Rep 3,013
10-16-2014, 01:09 PM | #9 | |
456
Rep 6,478
With a single it's a bit unclear. I'll know soon enough...Dan (AK335) ran well over 700WHP through his and while the trans was not happy, to my knowledge it never let go or anything like that. At 550-600WHP through a single turbo, it should be OK. The 6HP21 is a really good AT, and again the torque curve won't be as steep on spool. What WHP would I take the motor to and feel comfortable? Depend on tuning....North of 700WHP you are rolling the dice IMO. Up to 600WHP this motor has proven itself time and time again, provided good tuning and a smart owner who doesn't cut corners or do dumb stuff.
10-16-2014, 01:12 PM | #10 | |
BimmerPost Supporting Vendor
24199
Rep 190,807
Their maps are locked so anytime you need to make a change it has to go through them. Thats why i went with BMS custom flash + JB4 custom map.
10-16-2014, 01:12 PM | #11 | ||
Lord Scrip
1815
Rep 3,013
10-16-2014, 01:19 PM | #12 | |
456
Rep 6,478
IMO a hard launch from an RB powered car is far more stressful on the rear end than a 40 roll in a single turbo car. How the torque comes on is every bit as important as the peak number. Dan ran over 700WHP on 6AT (granted the trans was pissed), Ando@bms ran mid 500WHP on 6AT, i'm almost positive there are others.
10-16-2014, 02:42 PM | #13 |
12
Rep 175
Hey guys thanks for all the input so fast on this. So a 335xi 6AT could handle 450-500awhp? I want my car to also be reliable but also to kick some ass on the streets! Can I run COBB protune (PTF) and bms meth with RB's?
10-16-2014, 03:16 PM | #14 | |
258
Rep 1,084
Been running 450+ HP and north of 500-ish torque (also tuned by jake@motiv) for a while no, 0 issues. |
10-16-2014, 03:32 PM | #15 | |
172
Rep 1,909
Dan said his trans started slipping when he got to 660+ whp. Below that, he said it was perfectly fine.
Current: 2017 F30 340i xdrive
Previous: 2008 e92 335i coupe: RB turbos, mach 116 race fuel, methanol, alot of boost. Previous: 2003 Honda Accord V6 coupe: AEM V2, zex 75 wet shot (sold) |
10-17-2014, 12:18 PM | #16 |
12
Rep 175
Great information guys. Getting excited! What are these super RB's you guys are talking about? And can I run COBB protune with BMS meth kit?
10-17-2014, 01:43 PM | #17 |
97
Rep 804
i think PTF only tunes aquamist meth kit....but you can try Wedge out for the Cobb protune + BMS meth
E90 LCI M-sport/ 6AT/ LSD/ FBO+
10-17-2014, 07:16 PM | #18 |
Rep 277
Rob is coming up with some new turbos to compete with the new stage 2+ turbos from Vargas.
Stacked BMS Flash & JB4, Dinan CAI, ER Chargepipe, 7" VRSF Intercooler, VRSF Catless DP's, ER Sport Oil Cooler w/Steel lines, Gunmetal 19" VMR V710's, 335is clutch |
10-18-2014, 08:08 AM | #19 |
4496
Rep 1,862
Drives: powered by bootmod3
OP, whichever turbo option you go with we have you covered. With countless stock frame upgrade turbo maps under our belt with N54s running all over the World, varying ambients, octane, mod configurations we are confident when it comes to our N54s
For those interested in stacking we have started supporting that as well but only in select cases where boost targets higher than the OEM TMAP sensor limit (~21psi) make sense (e.g. VTT Stage 2+, single turbos). Stacked configuration is done only with the JB4 G5 with its latest firmware which has timing correction logging for all 6 cylinders. Earlier versions of the JB hardware (G4 for example) and firmware that don't support timing correction across all 6 cylinders are not supported for stacked tuning by us. In terms of meth we have run most and tuned with all the current methanol kits on the market. Aquamist HFS-4 has always been our meth kit of choice for methanol tuning on the N54. It supports 100% meth (many other kits don't), uses compression fittings everywhere to prevent leaks and losing prime, has one of if not the best on the market turbine based flow sensors that sits in the path of fluid flow that, along with their FAV (injection valve/solenoid), provides for very accurate injection metering and failsafety.
YouTube Channel [NEW] | Facebook User Group (20,000+ members) | Tech Support Website | Wiki | FAQ | iOS App | Android App | bootmod3 Web
Sales Support Email: sales@protuningfreaks.com | Tech Support Email: support@protuningfreaks.com Last edited by proTUNING Freaks; 10-18-2014 at 08:22 AM.. |
10-19-2014, 01:30 AM | #20 |
40
Rep 725
Drives: 2009 e92 335i
anyone know how much power rb's no meth on 91 would make fbo?
e92 335i l Cobb l VMR V710 l BMW PE l KW V1 l Cusco strut brace l M3 Control Arms l BMS DP's l
10-19-2014, 10:46 AM | #21 |
4496
Rep 1,862
We've seen anywhere from 385-400whp Dynojet STD numbers on 91 octane depending on mods, quality of octane, ambient temps, baro. 91 doesn't leave heck of a lot of room to push power on the hybrid turbo upgrades and you'd need either an E85 blend or methanol injection to take full advantage of them.
Sales Support Email: sales@protuningfreaks.com | Tech Support Email: support@protuningfreaks.com |
10-19-2014, 09:07 PM | #22 |
12
Rep 175
Sounds great PTF. I'm gonna be going with Aquamsit HFS4 from your website. And RB's as well. I'm currently working with Dzenan on a 116 unleaded pure race map. See what we can do with that!
