fried ecu with Procede install error?
10-14-2014, 05:02 PM | #1 |
18
Rep 195
i was reinstalling the proced rev3 and i mixed up some connectors and started the car,it ran like shit threw some codes and was making weird ecu noises,so i decided to remove and start over,but now its back to stock and the car wont start it just keeps turning over,i have checked and rechecked connections to no avail.
possible i fried the dme?? any help would be appreciated
2008 335i coupe 6MT BOOST FIEND
10-14-2014, 06:37 PM | #2 |
Macgyver
208
Rep 942
If it uses the adapter harness like JB4, then check that you put the connectors back correctly into the right slots. Then check that those connectors are seated onto the DME correctly with the slide locks. If its not mated, it won't start in either scenario with or without procede.
GTX3076R , ADV, JB4, FMIC, BOV, 17"APEX, 255/40/17 SQ, 6-SPD Manual
10-14-2014, 07:03 PM | #4 | |
533
Rep 2,872
BSM E90 6MT-JB4 G5 ISO-BMS DCI-Golf-Tee Mod-Hankook S1N2 Non-RFT-ER Chargepipe/TiAL BOV-E40 blend-VRSF V2's-M3 CDV-MHD/JB4 FLASH-VRSF 5" STEPPED FMIC
10-14-2014, 07:34 PM | #6 |
58
Rep 665
Also make sure you didn't bend any pins.
2010 535i M Sport - Platinum Gray/Dakota Black/Anthracite Bamboo
2016 Jaguar F-Type S AWD - Polar White/Cirrus |
10-14-2014, 07:39 PM | #7 |
533
Rep 2,872
Also make sure the car has gas
10-14-2014, 07:40 PM | #8 |
18
Rep 195
i did all of that at least 5 times but i will try some more tomorrow.like a noob i removed the harness from the dme while the battery was connected.i hope i did not brick it
10-14-2014, 07:44 PM | #9 | |
533
Rep 2,872
Also check all of your fuses, maybe you blew one somehow.
10-14-2014, 09:47 PM | #10 |
Some dude
92
Rep 1,780
Orange wire power pin in the green plug - if it is not installed straight, it can bend and miss the other end. Also make sure that it's not in the wrong slot.
RRT
E92 335i/6MT with stuff and things |
10-15-2014, 09:08 AM | #11 |
18
Rep 195
removed everything then re-installed and still just turning over.not too sure where to go from here
10-15-2014, 10:26 AM | #13 |
533
Rep 2,872
10-15-2014, 10:41 AM | #14 |
18
Rep 195
no i have not other then the red one in the ecu box and its good,i will look at other fuses later today.and if that doesnt work ill buy a multimeter to test the power in the 2 orange wires
10-15-2014, 11:29 AM | #15 |
8
Rep 476
Did you check your car for codes? My guess is a blown fuse. Not sure what year your car is, but it's either a 15 or 20 amp fuse under the hood or behind the glove compartment.
10-15-2014, 11:34 AM | #16 |
533
Rep 2,872
My thinking would be since the ECU never went to sleep if you didn't let the car sit, maybe you shorted a hot wire and it blew a fuse for the fuel pump or something. That's common on many cars.
10-15-2014, 02:53 PM | #17 |
18
Rep 195
ok so i have re checked the connectors and yellow power wires,along with all fuses in the glove box and they are all good.
10-15-2014, 02:54 PM | #18 | |
18
Rep 195
10-15-2014, 04:34 PM | #20 |
18
Rep 195
yea,i must of removed it and put it back at least 5 times
10-15-2014, 04:43 PM | #21 |
146
Rep 563
It looks like your orange power wire is not seated in the green socket all the way. Try removing it and reinstalling that wire. I had this issue when removing mine a few weeks ago.
10-15-2014, 04:48 PM | #22 |
46
Rep 231
I had the same problem when I was installing my JB4. Turned out I did not put one of the four big plugs coming out of the DME back in the correct slot. If you are having a hard time sliding the retainers in to lock the plugs into the DME then you might have put one of the plugs in wrong. The retainer will lock and all the plugs will looked like they are seated correctly but the car won't start. Once I figured out my momentary lapse of reason and switched the plugs around, my car fired right up. Talk about a great sigh of relief...
