What to run on jb4
10-13-2014, 10:57 PM | #1 |
74
Rep 390
Just bought a jb4. (Pretty new to them.) What should I be running? Maps gas ect.
I have access to 91, and 85. 70/30 blend? Have a bms dci. What numbers should I see? Just did a few pulls tonight, from a roll I can't feel the turbos pulling much, I mostly only feel them from a launch. Why? Think if I install the jb4 and run higher boost settings it'll be better?
My Build Thread: http://www.e90post.com/forums/showth...8#post16918878 |
10-13-2014, 11:17 PM | #2 |
533
Rep 2,872
Please.. This is covered every day. It's also spelled out in the instructions you used to install it. Map 1 or 5 for stock or lightly modded. However map 5 can carry you all the way to FBO + 40% E85. Backend flash required + some other things for higher than 40% ratios. So use map 5.
BSM E90 6MT-JB4 G5 ISO-BMS DCI-Golf-Tee Mod-Hankook S1N2 Non-RFT-ER Chargepipe/TiAL BOV-E40 blend-VRSF V2's-M3 CDV-MHD/JB4 FLASH-VRSF 5" STEPPED FMIC
10-14-2014, 07:42 AM | #3 |
25
Rep 633
JB4? What's that? Never heard about that... Please do your own research first...
10-14-2014, 08:42 AM | #4 | |
74
Rep 390
10-14-2014, 09:52 AM | #5 |
319
Rep 1,023
All bashing aside, 335NJ nailed it. Just use map 5 and you will be fine. Be sure to do a few pulls once switching to map 5 so it can acclimate to your conditions and modifications. Also, if you ever switch away from map 5 (like going to map 0 for the dealer, etc), it will have to relearn when you select it again.
2001 e36/7 M Roadster 5spd
2008 e90 335i 6spd 2011 e90 335xi 6spd 2011 e70 x5 diesel 2010 Ducati Monster 696 |
10-14-2014, 10:14 AM | #6 |
25
Rep 633
Map 5.
10-14-2014, 10:26 AM | #7 |
533
Rep 2,872
Also, if you don't have the usb cable for the JB4, get one. Log your runs, and post your .csv file up here and/or N54tech once you dump some E85 in to make sure your fuel trims all look safe. Also, read the misfire sticky at the top thoroughly.
Try to get a 3rd gear pull across the entire RPM range then stop & save the log so it's not too long to make reading easier. |
10-14-2014, 11:28 AM | #9 | |
3441
Rep 79,211
10-14-2014, 11:38 AM | #10 | ||
74
Rep 390
10-14-2014, 12:00 PM | #11 |
30
Rep 780
hate to say it but search is the real option here... you will learn wwwwaaaayyyyy more and while searching for what you need you will find other answers that will help down the road.. that being said i have a cobb from what i know (by my own research) you need the usb and a laptop to log
10-14-2014, 12:06 PM | #12 |
533
Rep 2,872
Absolutely, I should've included that. I was more worried about the responses he'd get for posting a Datazap file on N54Tech. Since Terry & Russell read .csv only over there mainly. But hands down, Datazap.me is 100x easier to read than a huge excel file
10-14-2014, 01:25 PM | #13 | |
Joint Chiefs of Staff
4918
Rep 115,980
Mike |
10-14-2014, 02:09 PM | #14 |
BimmerPost Supporting Vendor
24199
Rep 190,807
If you do not have an inline fuel pump, keep your E85 level lower than 40%
10-14-2014, 02:22 PM | #15 |
533
Rep 2,872
