BMS 2-step NLS issue...
10-13-2014, 09:56 PM | #1 |
7
Rep 79
Everything seems to be hooked up right but say I'm around 4k rpm and slam the clutch it just revs all the way to redline... I tested the 2-step that works fine. Can't see what could be the issie???
Any advice would be much appreciated. |
10-13-2014, 11:17 PM | #4 | |
145
Rep 841
Your gas pedal needs to be fully pressed down |
10-14-2014, 07:56 AM | #7 |
7
Rep 79
Mike, I sent you a personal message thanking you, everything is all good now! I had the clutch wires on the wrong side of the board! Thanks everybody!
10-14-2014, 02:55 PM | #8 | |
34
Rep 284
Im having the same problem my 2step works fine but the NLS does the same as you described. Can you explain what you mean by having the clutch wires on the wrong side of the board? Would be much appreciated.
2009 E92 M3 Coupe DCT (Alpine White/Black Novillo) Borla Exhaust, VRSF Test Pipes, BMC Filter, Alpine Tune, ST Coilovers, Stoptech ST60
2007 E92 335i Coupe 6MT (Space Grey/Coral Red) VRSF Downpipes, BMS DCI, Bigtom FMIC, E-85, JB4 ISO/MHD |
10-14-2014, 03:20 PM | #9 |
41
Rep 823
lol i misread this from the beginning doh.. i thought he said his 2 step wasn't working but he thought he wired it right..
@hithunter i think he means he hooked it up in the wrong slots on the DB9 connector going to the board. |
