Car Wont Unlock
12-31-2007, 07:35 PM | #1 |
Rep 53
Car Wont Unlock
My girlfriend has a 2007 328i sedan and for some random reason today the car will not unlock. The remote doesn't unlock it and the button from inside the car will not unlock the doors. She can unlock the drivers side door with the actual key in the door, but thats it. Normally if you pull the handle from inside the passenger door, it'll unlock, but this doesnt work either. I know the remote isn't dead because it will lock the driver side door after she unlocks it manually. Is some security function screwing up the door locks? Help!
01-01-2008, 01:41 PM | #4 |
375
Rep 2,348
http://www.e90post.com/forums/showthread.php?t=88174
http://www.e90post.com/forums/showth...ht=door+unlock happened to quite a few members including myself. the actuator mechanism or some sort needs fixing/replacing.
01-01-2008, 01:44 PM | #5 |
Bimmerpost Resident Marijuana Consultant
455
Rep 3,197
Drives: 320i, 325xi, 335Xi, 335i, M3
Garage List 2010 BMW 335i [0.00]
2011 BMW X335i [0.00] 2006 BMW E90 325xi [0.00] 2011 BMW E90 335xi [4.00] 2011 BMW M3 E90 [7.00] 2006 E90 320i [0.00] |
+1. jut take it to bmw, they will replace them and it will be covered by warranty. cheers
"AMG What! S-Line Who? If you ain't got that M I got no respect for you!" '06 Alpine Weiss E90 320i | '06 The Green Machine E90 325xi | '11 Alpine Weiss E90 M3 ZCP | '10 Silverstone X5M | '11 Alpine Weiss E90 335xi |
01-29-2008, 09:35 PM | #7 |
Rep 42
That happened to me today including all doors and fuel cap. If this problem is recurrent makes the car unsafe and dangerous in case of accident. I think must be reported to the safety transportation agency.
01-29-2008, 10:08 PM | #8 |
30
Rep 1,118
Drives: 2009 E89 Z4
Fuel cap is locked because the doors are locked. They're not the same mechanism. If you need to get gas, just unlock your drivers door at the very least and it should release it.
Z4 sdrive30i | Deep Sea Blue | Ivory White Nappa Extended Leather | ZSP |
01-29-2008, 10:39 PM | #10 |
Rep 88
I had the same problem - remote didn't work and the unlock button on the center console didn't work. I had to use the key to unlock the driver door and my wife had to crawl through the driver side or Dukes of Hazzard it through the passenger window.
I brought my car into the dealer and they replaced the driver door control unit (I have the Comfort Pkg) and reinstalled the CIP software. To unlock the fuel cap, I had to go into the trunk, open the back side panel and pull the green fuel cap ring to manually unlock the fuel cap. |
05-29-2008, 12:09 AM | #11 |
Rep 1
Same thing just happened to me. Got out of the car and locked the doors, and the driver's side door made a funny sound and didn't lock. After that, I can no longer unlock the doors with the keyless remote or button in the car. I can only unlock the driver's door with the physical key. Discovered that one of the fuses was blown, but replacing it didn't help.
