10-10-2014, 08:48 AM | #1 |
Joint Chiefs of Staff
4901
Rep 115,955
BMS F-Series Wheel Spacers - On Sale!!
ORDER LINK
http://www.n54tuning.com/index.php?_...&productId=129 BMW Wheel Spacers by BMS -Provide Better Handling by Widening the Wheelbase -Provide A Wider More Aggressive Look and Stance -Specifically Designed for your BMW -Guaranteed for the Life of your Vehicle -10 Super Strong Extended Wheel Bolts Included -Light Weight Anodized Black 7075-T6 Aluminum -Special Pry Tabs on the Back for Easy Removal -1-Piece Spacer with Hubcentric Factory Lip -Strong Solid Design & Appearance -Available in 10mm, 12mm, 15mm, 18mm, 20mm Most F Chassis BMW vehicles can have up to 20mm in the rear and 10mm - 12mm in the front. BMS Recommends 12-15mm rear and 10mm front on OEM BMW rims and tires. 15MM, 18MM and 20mm spacers might stick out of the fender slightly except on M cars and the M135i, M235i. The rear fenders of the F Chassis vehicles are thin and don't need rolling. Rubbing is not a concern in the rear on these cars unless the F chassis vehicle is extremely lowered or the tires are wider than stock sizes. F30 and F31 3 series can only have 15mm or larger on the rear due to a tall factory hub. F80 M3 can have any size spacer all the way around. |
10-28-2014, 11:28 AM | #2 |
4901
Rep 115,955
06-18-2015, 07:07 AM | #4 |
WRX Betrayer
68
Rep 141
Hey Mike want to do 12mm front and 15mm rear, these all fit 2 series ? The website doesnt specify that it fits f22 chassis without any issue...
02-28-2017, 08:54 PM | #5 |
4901
Rep 115,955
