10-07-2014, 05:09 PM | #1 |
INSTAGRAM: @yaasplease
166
Rep 1,023
Silent Recalls
Just letting you guys know that there are two right now. One for a resistor and one for water drainage. I would suggest you call up the dealership and get them done.
My car was dropped off for service today due to a ticking sound coming from the engine bay. Could be exhaust valves (in the engine). Stay tuned.
2015 ///M4: M/Vorsteiner Aero, P3Cars, HRE R101, Dinan S2, Coils & Intake; Eis/Akra Exhaust
2013 WRX Hatchback: LED Conversion, Blacked Out, Rally Armor 2015 Macan Turbo: Techart Exhaust, Cargraphics Lowering Module, Blacked Out |
10-14-2014, 08:41 AM | #3 | |
178
Rep 467
10-14-2014, 09:55 AM | #4 | |
421
Rep 4,499
I think this only affects the DCT and not the 6spd manuals, but I will ask my SA when I bring it to them on Thursday.
Have BT Tool professional, will scan and clear codes on your BMW. And now I am able to code my 2011 335is and M4
Link to my M4 euro delivery! http://f80.bimmerpost.com/forums/sho....php?t=1006526 |
10-15-2014, 11:06 PM | #5 |
166
Rep 1,023
Just got the car back...
Basically, two of the exhaust valve lifters were slightly shorter than spec, by 1.1mm, which caused excessive noise. They were replaced and all is quiet now. While my car was in, BMW also performed three different recalls: - replacement of door handle rubber seals - replacement of unit compartment partition wall, no clue what this is - retrofitting of resistor It was also discovered that the passenger side back wheel well liner was warped, so did not sit properly. They will need to replace that when they get the part. Finally, one of the bladders in the driver side chair was squeaking. So they are also replacing that. Things to look out for...
10-15-2014, 11:07 PM | #6 | |
166
Rep 1,023
I've got my fix for manual via the WRX.
10-16-2014, 12:31 PM | #7 |
9
Rep 65
redfox
I have a question for you about the exhaust value lifter fixes. Did it fix the annoying rattle sound from the exhaust? If so, is there a part # and the description in the work order? Also, can you tell us the dealership that did the work, because they seem to know what they are looking for. You can PM me if you feel more comfortable. Thanks |
10-17-2014, 08:48 AM | #8 |
127
Rep 451
Drives: 2015 M4 - SO/SS, 6MT
Hey redfox. Same here, I would be interested to know which dealer.
10-17-2014, 09:37 AM | #9 |
178
Rep 467
got my resistor installed yesterday, took about an hour, but they also installed polyester velour wraps part number 61-13-6-908-716...
2015 AW ///M4 |
10-20-2014, 09:27 PM | #10 |
166
Rep 1,023
Budds did the work on my car.
I had no exhaust rattle. The fix was to fix a louder ticking sound coming from the engine (no, not the quieter, fast paced ticking sound from the fuel injectors).
10-22-2014, 01:58 PM | #11 |
421
Rep 4,499
Well I took my M4 back to the for these recalls.
Service Information #128214 And Service Information #0061130400(f82)
10-22-2014, 03:06 PM | #13 |
421
Rep 4,499
