TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Procede user adjustable settings
      12-29-2007, 08:12 PM   #1
Barat
15
Drives: 335i
Hi Guys,
What's the right procedure to update those values? Do you have to reload the map? or just update the values while connected click apply and then ok? can you do it while the engine is running or only with ignition on?
thanks
      12-29-2007, 08:19 PM   #2
Driver72
327
Drives: 335i - to new owners now.
Originally Posted by Barat View Post
Hi Guys,
thanks
Select the "user adjustable map" section.
Enter values into the rpm ranges.
Click "Apply"
Click "OK"
then close the window.
Then ALWAYS double check yourself by reopening the "user torque settings" window and look at each rpm value to be sure it's correct.
I once almost accidently set a value at 99.3xxx
When I meant to enter 93.xxx, but accidentally hit the 9 button twice.
If the values are what you wanted, then you are good to go.
You can do it with the engine running, but I would turn the engine off and just do it with the ignition on, but engine not running.
      12-29-2007, 08:20 PM   #3
Barat
15
Drives: 335i
thanks!
      12-29-2007, 09:36 PM   #4
midlife
ocasionally in crisis
midlife's Avatar
52
Drives: '08 335i cabrio
thanks!
subscribed
If your car isn't scary - it's just not fast enough !
RPI IC / UR catless DPs / JB3 2.0 beta / UR CAI / Quaife LSD / Snow Methanol Injection / VK oil cooler upgrade / Forge DVs /
M3 rear sway / Riss catch can / Paddle shifting 6AT / M Sport steering wheel / Logic 7 / Dunlop Direzza Z1 255/235 /
