10-04-2014, 07:15 AM | #1 |
119
Rep 373
Problem putting power down
Question..
I installed a jb4 in my car a few days ago and it is very, very fast. I am having a blast driving this car! One problem... getting the power down. Currently I am running a 12MM spacer in the rear. My question is would I be able to fit a 305/30/19 on the rear tires. I am also planning on lowering the car on H&R Springs which are sitting in my garage. Would a 295/35/19 or a 295/30/19 suffice? I would like to keep rubbing as minimal as possible, I would just like some input to what the best setup is for optimal grip. Any advice is appreciated! |
10-11-2014, 08:51 PM | #3 |
408
Rep 1,025
On stock wheels or do you have aftermarket wheels? if stock, no problems mounting those tires on stock wheels? Tire rack lists 10.5-11.5" wheel widths as the proper fitment on 305s. I was thinking of going with 295 also, but would use 305s if they would fit.
2017 F-type SVR Black/black
2017 Nissan GTR Red/black 2022 BMW X5M MBB/SO Gone but not forgotten: '12 X5M, '07 AM SuperVantage, '05 Boxster S, '01 BMW M3,... |
10-11-2014, 09:36 PM | #4 |
definitivecars.com
352
Rep 3,833
Drives: Elsa - 2015 F80 M3 - YMB/SS
Garage List 2011 E90 M3 [6.66]
2009 (Lease up Sept ... [0.00] 2007 (Lease up 6/19 ... [0.00] 2007 (Lease up Octo ... [0.00] |
In the realm of things, this will not fix your problem... Im on 11" rears with 295's and no tune or anything and I have trouble putting the power down as well. I think we all do.
D |
10-11-2014, 10:32 PM | #5 |
1231
Rep 1,789
Drives: wife crazy
Garage List 2019 Ford Raptor [0.00]
2016 Porsche 991.1 ... [0.00] 1987 Chevy Camaro I ... [0.00] 1972 Chevy Corvette [0.00] 1999 BMW M3 race car [0.00] |
The tire compound is just as important as the width of the tire. Try some Toyo R888 295/30 in the rear and it should hook up a lot better. They fit fine on stock wheels no rubbing.
Nothing will hold grip in 1st gear with this car, but at least the Toyo's stopped it from breaking loose in 2nd.
Road course laptimes for BMW M4 2015 6MT
WHP East Track: 1:04.880, Arizona Motorsports Park: 1:54.352 Road course laptimes for Porsche 911 991.1 GTS 7MT WHP East Track: 1:02.770, Arizona Motorsports Park: 1:48.889 |
10-12-2014, 02:07 AM | #6 | |
Rep 54
I run stock wheels..... nitto nt05r drag radial!!!!! |
10-13-2014, 08:32 AM | #8 |
408
Rep 1,025
Are you using a 295/30 or 295/35? Wider tires won't help off the line traction...you need a tire with a larger diameter. A 295/30 is actually smaller diameter than stock and probably won't help in putting the power down. A 295/35 should give you better off the line traction, but there might be a slight trade off with handling.
10-14-2014, 11:43 PM | #10 |
657
Rep 1,749
And folks blasted me for wanting a tune with a more progressive power delivery because it doesn't "make the most power possible" Well if you cant put down the power who cares! That is another reason I am pushing for a "NA-tune" file with a more progressive onset of power so we are all not left spinning in the lower gears
02-02-2015, 03:41 PM | #11 | |
260
Rep 658
2015 Alpine white M4\black leather, carbon fiber trim,manual,exec package, 19 inch black rims, M suspension, HK stereo, LED lighting
02-02-2015, 05:20 PM | #12 |
119
Rep 373
I ended up going with a 295/30/19 on the stock 19' wheel. They're sticking pretty well in warmer weather.. NY is a shit show with snow until at least the middle of March
02-02-2015, 05:39 PM | #13 |
260
Rep 658
I was hoping someone would weigh in on the 295/35. I've got no clue but can't imagine .5 inch taller would matter
02-03-2015, 10:14 AM | #14 | |
Enjoying driving
388
Rep 1,169
Do a simple test, repeat few of times if you can to make sure you get reliable data: do few acceleration tests as best as you can without spinning the wheels or minimal spin, record your times (60' or higher), then do the same acceleration without the rear spacers (leave the fronts on). See if that makes any difference in your times Frankly I do not know how much difference there will be, but I would imagine it would be worth the results in one way or another |
02-05-2015, 12:56 PM | #15 | |
2301
Rep 2,019
Drives: INDIVIDUAL F90 M5C LCI
CURRENT: '21 M5| FSHNGRY | TARTUFO | CCB | MPE | KW | IND | EVENTURI | EISENMANN | DINAN | LOADED |
GONE: '15 F82 M4 | YMB | IND | MPERF | KW | BM3 | LOADED GONE: '11 E92 335IS | BLKSPHR | OYSTER | LOADED GONE: '05 E46 ZHP | LOADED | DINAN STG3 PKG | IG: @FSHNGRY |
