10-03-2014, 10:32 PM | #1 |
ID10T Specialist
90
Rep 269
Drives: F90 | F97
Garage List 2019 BMW M5 (f90) b ... [9.92]
2021 (F97) BMW X3mc [10.00] 2017 Toyota Land Cr ... [9.50] 2000 Toyota Land Cr ... [0.00] |
First Service Done.... plus TSB
Took my m4 to Mt View today for first service (1550 miles)
Drop at 8.45a and pick up at 4pm. - Car Wash - Engine oil - Diff oil - TSB campaign 10061130400 - CAN Terminator So interesting side note... When the lot boy was retrieving my car it sounded loud, similar to cold start in the morning. I jumped in and drove away but the car exhaust note continues to be louder than before. The car is a tad peppier than before as well (not like it was lacking). At first I thought I was dreaming it but then I picked up my girl friend and she said spontaneously that it was louder so it's not just my mind going. Any ideas why the exhaust note would change? Valves stuck open suddenly. secret software flash? I wasn't told about. Also I previously tried to use launch control (before service) but I could never get it to come up. I mentioned to the service writer but there was nothing they did supposedly to enable it - he said it's there and implied I may have not done it right. Last edited by RobRed; 10-07-2014 at 11:45 AM.. |
10-03-2014, 10:36 PM | #2 |
ID10T Specialist
90
Rep 269
Drives: F90 | F97
Crap wrong forum - mods pls correct my error and move to appropriate forum.
10-04-2014, 12:02 AM | #4 |
120
Rep 616
Weird. Your recall number doesn't come up on http://www-odi.nhtsa.dot.gov/owners/SearchResults -- that's where I'd expect to see more info. No other standard service stuff should have any effect on the exhaust. Check with your dealer and keep us posted.
ED 11/3/14 2015 M3, AW, SO, DCT, 19" blk wheels, HK, Lighting/Exec/Tech packages, ad. susp.
10-04-2014, 10:17 AM | #5 |
33
Rep 119
could be your exhaust has broken in....if that makes sense usually it takes time for an exhaust to break in and it does sound louder with a few miles on it........or the turned up the speakers in the car :P
10-04-2014, 10:51 AM | #6 | |
ID10T Specialist
90
Rep 269
Drives: F90 | F97
The sound increase is from outside the car. I'm not complaining but it's interesting. I'll post a photo in the top of the thread of the service order for the CAN recall. |
10-04-2014, 02:32 PM | #8 |
M4-SAHD
510
Rep 611
Thanks I'll let my advisor know, I'll be doing my service on Monday
10-04-2014, 03:09 PM | #9 |
ID10T Specialist
90
Rep 269
Drives: F90 | F97
I specified to program launch control in my service request. I would have expected to see a line item on work order for it. It did not have it.
I will test for it again today to see if it's working. They did reset my service interval... apparently I have break in maintenance due in 1200 miles LOLz |
10-06-2014, 11:56 AM | #10 | |
M4-SAHD
510
Rep 611
10-06-2014, 04:24 PM | #11 | |
26
Rep 333
10-06-2014, 05:11 PM | #12 |
10783
Rep 8,852
Drives: '15 SO M4/'20 Z4 M40i
Can someone say what the "recall" is?
Tejas Chapter, BMW CCA, mem #23915, President 27 years, www.tejaschapter.org
10-06-2014, 08:58 PM | #13 | |
M4-SAHD
510
Rep 611
I ask a friend that happens to be a master mechanic at the dealer what this was he's answer: its called a terminal resistor It was just not installed at the factory On a short production run of cars its there to protect from over-voltage |
10-06-2014, 09:10 PM | #14 | |
10783
Rep 8,852
10-07-2014, 11:14 AM | #15 |
ID10T Specialist
90
Rep 269
Drives: F90 | F97
Yeah - Sorry I should have not used the term recall... TSB and upgrade.
Corrected original post. Last edited by RobRed; 10-07-2014 at 11:46 AM.. |
10-07-2014, 01:00 PM | #16 | |
M4-SAHD
510
Rep 611
10-07-2014, 01:44 PM | #17 |
BimmerPost Supporting Vendor
733
Rep 10,105
Spoke to our friend in service and looks like it's nothing serious. Apparently some 4-series are missing a particular CAN terminator resistor and are causing false electrical faults in the DME.
10-07-2014, 06:12 PM | #18 | |
ID10T Specialist
90
Rep 269
Drives: F90 | F97
Glad you got it done AND glad it's not me only that noticed the sound change. If you're DCT you may also find the shifting has improved - S2 quicker and smoother, S3 less jerky / smoother. This little part must have been a bigger deal than I was led to believe. |
10-08-2014, 03:05 PM | #19 |
ID10T Specialist
90
Rep 269
Drives: F90 | F97
Update:
Had the service reminder corrected and Launch Control is confirmed Best to use comfort on shocks for launch keeps wheel spin/chirp down. Spoke to BMW more about the CAN terminator and it's a big deal to the cars affected. My M4 is dramatically improved post install. Also confirmed the sound change as an effect of this update. Obviously if you car is not one of the campaign cars you've already had the better sound and driving. Lucky you. |
10-08-2014, 03:42 PM | #20 | |
9
Rep 49
Sorry.. What is a campaign cars? My car finished production on 9/11/2014. It's on the boat now, would that affect me?
Thanks, Bert Quote:
15' M4 YMB w/ SO, MP black trim, MP Aero kits, Vorsteiner rear diffuser, 20' Vorsteiner VFF 102 Carbon Graphite w/P Zero, Full nose clear bra, KW HAS spring)
Current: 07' M5 e60 RPI mod, 12' X5M (wife) Current: 56' Porsche 356 Speedster, 12' Prius C, 90' Miata |
10-08-2014, 05:31 PM | #21 | |
ID10T Specialist
90
Rep 269
Drives: F90 | F97
My production date is 6/17 so if the parts are in the field I would guess your's is not affected. Only way to know is look at the bulletin and see if you VIN range is is listed. |
