10-02-2014, 02:56 PM | #1 |
123
Rep 353
KW Sleeve Kit for F80 M3 Arrived
UPDATE: First car on bimmerpost with KW sleeve kit installed on F80 M3. Pics below.
10-02-2014, 03:53 PM | #4 |
590
Rep 5,396
yes, there is shockingly little data on these
-spring rate? -how spring rate was determined? -spring length? -minimum drop vs stock (assuming max perch height) to name a few
10-02-2014, 04:07 PM | #5 |
Gone Fishin’
7315
Rep 12,125
10-02-2014, 04:07 PM | #6 |
10783
Rep 8,852
Drives: '15 SO M4/'20 Z4 M40i
That's because they are springs, not shocks
Tejas Chapter, BMW CCA, mem #23915, President 27 years, www.tejaschapter.org
10-02-2014, 04:07 PM | #7 |
Enjoying driving
388
Rep 1,169
If my calculations are correct based on the H&R TUV submission paper that was posted few weeks ago, the F82 super sport springs at 150# front and 350# rear, I do not know if this makes any sense though, little weird for me to see such wide range in a front heavy car.
10-02-2014, 08:15 PM | #9 |
216
Rep 1,793
Drives: 06' E90 330, 20' F97 X3m
I see what you did there!
LIVE FAST..DRIVE FASTER!! |
10-02-2014, 10:13 PM | #10 |
471
Rep 2,991
It's all about motion ratio. That sounds way too soft, though.
10-03-2014, 11:19 AM | #11 |
Bored all the time
383
Rep 2,171
They would... it's 3 times the price of springs.
Better get coilovers.
Current: 2014 991 Turbo RS
Past: 15 GT3, 17 R8 SC, Two 16 M4 GTS’s, Two 18 GT350R's, Two 13 RS5’s, 13 M3, 10 R8, 15 M4, 09 M3, 04 M3, 09 S5, 02 M3... It all started with an RX-7 (FD). |
10-03-2014, 05:16 PM | #13 |
123
Rep 353
10-03-2014, 09:39 PM | #14 | |
Bored all the time
383
Rep 2,171
10-04-2014, 11:43 PM | #15 |
123
Rep 353
Installed the springs yesterday. Best of all the ride was somewhat floaty before, now it feels like the the E92 M3 again. Looking forward to installing sway bars from Dinan when they are released. Want to make the car give feedback, and ride like the E92 M3 again. I think with the sway bars it will be very similar. Highly recommend this!
10-05-2014, 09:34 AM | #17 | |
123
Rep 353
The excitement that was partially lost with the more capable suspension/chassis of the new car is simply just toned down a bit and masked. Install these springs and the car really starts to feel like the E92 M3 again. Looking forward to installing the sway bars. Last edited by BigMacSmallFries; 10-05-2014 at 05:30 PM.. |
10-05-2014, 04:43 PM | #19 |
123
Rep 353
No, biggest improvement of the F8x M3 over the old one is the suspension, easily. What's lost is the road feel (crevices, cracks, small bumps) because the suspension glides over everything making the car feel floaty and slightly disconnected, not to mention the electric steering. Same story with the new 991s compared to the 997s. Just had a joy ride in my car on some winding roads, these springs bring back all that road detail that the OEM setup hides. Surprised how much more feedback the KW springs give through the chassis compared to the OEM springs. Highly recommend this.
10-05-2014, 05:24 PM | #20 |
123
Rep 353
We took some accurate measurements based on a full tank of gas, and about 50lbs of weight in the trunk that I always have in the car.
Front needs to be dropped 1.5" so that the top of the wheel edges to the fender flares are the same front and rear. This is the result. Did not want to touch the rear ride height because it is already very low. We confirmed this at the end by remeasuring the heights. Drop in front: 1.5" Drop in rear: 0.0" Note: 20mm/18mm spacers front/rear. No rubbing. Last edited by BigMacSmallFries; 10-05-2014 at 05:55 PM.. |
10-06-2014, 12:44 PM | #21 |
768
Rep 958
Drives: G87 M2, G20 330d, Brabus Smart
^^That looks perfect.
