2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics N20 (228i) / B46 (230i) Engine, Transmission, Exhaust, Tuning M Performance Exhaust for 228i Vehicles
      10-01-2014, 11:45 AM   #1
THEWRKS
321
Drives: 2018 M2
Hi,
I have installed a M Performance Exhaust on my 2014 BMW 228i M-Sport, since there is no actual M Performance Exhaust out yet for the 228i vehicles i took it on as a challenge, because i couldn't wait for BMW to release it. I have came up with a solution that has worked alot better then i was expecting. i have installed a F30 328I M Performance Exhaust on my 228i and it fits almost perfectly. Just some small modification had to be done to make it fit OEM. I have attached some pictures so you can see how it looks.
The part number I used was: 18302293771 F30 328I
I hope this helps out some people on here!
      10-01-2014, 12:47 PM   #2
VMRWheels
VMRWheels's Avatar
2038
Drives: BMW
2013 BMW M3  [10.00]
2015 BMW M4  [0.00]
2013 BMW F30  [0.00]
2014 BMW F22  [0.00]
2013 BMW F06  [0.00]
WOW, very nice!! What kind of modifications did you have to do exactly?
      10-01-2014, 12:52 PM   #3
THEWRKS
321
Drives: 2018 M2
All I had to do was:
1st - Cut the exhaust tip length by 1inch
2nd - Cut the exhaust pipe from were is connects to the OEM exhaust so it lines up with the stock exhaust piping
Thanks,
      10-01-2014, 01:27 PM   #4
MG 228i
156
Drives: Z4 m40i, 340i 6MT, i3S
Thanks for sharing! Have any videos?
      10-01-2014, 05:51 PM   #5
THEWRKS
321
Drives: 2018 M2
hi,
Here is the video you were looking for. I have the car in Sport Plus it opens the value in the rear muffler.
Here is the link:
Thanks,
      10-01-2014, 07:42 PM   #6
Gentleman Driver
Drives: BMW 228i M Sport THP (future)
Man, that sounds great and looks awesome. BMW really needs to make this a port-installed item ASAP!
Thanks for sharing and great work.
GD
      10-01-2014, 09:42 PM   #7
MG 228i
156
Sounds great! Thanks for the video.
      10-22-2014, 07:57 PM   #8
THEWRKS
321
Drives: 2018 M2
Here is another sound clip of the exhaust system.
      10-22-2014, 10:56 PM   #9
MG 228i
156
Does it burp between shifts or when you let off the gas during hard acceleration?
      10-24-2014, 06:23 PM   #10
THEWRKS
321
Drives: 2018 M2
Hi,
When the car is in sport plus i do get a burp when shifting and some nice over run in the exhaust when i let off the gas. its not to loud but nice and clean.
Thanks,
      10-27-2014, 07:11 PM   #11
escobar929
escobar929's Avatar
154
Drives: M2 CS
2020 M2 CS  [10.00]
2020 M240i  [0.00]
Amazing, it's sounds incredible
If you had a M Performance diffuser, do you think cutting the tips down would still be necessary?
      10-27-2014, 07:49 PM   #12
THEWRKS
321
Drives: 2018 M2
Thank you for all the nice words.
I have test fitted the M Performance Diffuser on and the exhaust tips fit perfect at the length they are at now. There is still room to adjust them out more if I wanted too.
      11-07-2014, 11:07 PM   #13
Daddycat
Drives: Estoril Blue 228i M
Bolt-on Installation?
Is that a bolt-on system or is welding required?
You say it has a valve that opens at full throttle?
Your car an auto or stick?
Thanks
      11-08-2014, 09:53 AM   #14
THEWRKS
321
Drives: 2018 M2
Thanks
I got it welded because I like it better welded.
One exhaust tip has the valve in it, it is all controlled from the Dynamic Control buttons.
My car is stick.
I hope this helps you out.
Thanks,
      12-18-2014, 05:57 PM   #15
mfourn20
mfourn20's Avatar
52
Drives: 228i M Sport
Out of curiosity...
What does it sound like when it's in comfort/wife mode?
      03-26-2015, 01:19 AM   #16
2msport
Drives: '14 228 MT
My car is stick.
Thanks,
Did the hangers need to be extended/altered? Or does it pop right into place?
      03-30-2015, 08:02 AM   #17
THEWRKS
321
Drives: 2018 M2
Everything just fit right into place.
Thanks,
      04-05-2015, 02:14 PM   #18
2msport
Drives: '14 228 MT
Thanks,
I installed mine. Pretty sweet! Definitely better than stock. Thanks for your help
      04-06-2015, 08:48 AM   #19
Roman G
98
Drives: a few
any extra videos of this?
      04-06-2015, 09:34 AM   #20
2msport
Drives: '14 228 MT
I haven't made any yet, sorry. I will say it's true what they say. Videos don't do justice. But for the short amount of time I've had it this is how I think about it.
When you're outside or in a parking lot it sounds awesome. Really nice at low RPMs. Lot's of burbles and a throaty sound. When you're driving and you have the windows down or cracked it sound great. Not super loud but enough to get your attention and to hear over city street driving. (wind noise/other cars) When you're driving with the windows up. Well unfortunately (IMO) because this is where most of us do most of our driving, it's at it's quietest. But still discernible. It's all dependent on how hard you're pushing the car. The more throttle the louder it gets. WOT sounds great to me. Quite loud with a balanced low growl. The way the car should have came from the factory..... One important note. The exhaust system needs to warm up before it sounds it's loudest. Mostly important for windows up driving. It makes a difference. Once it's warm, that's when I know it was money well spent.
      04-06-2015, 11:20 AM   #21
Roman G
98
Drives: a few
just to clarify, the exhaust valve is still functioning or did you disconnect it?
If you ever get a chance to record a video do post.
Thanks,
Roman
      04-06-2015, 11:48 AM   #22
2msport
Drives: '14 228 MT
Thanks,
Roman
Still connected and functioning. In fact it changes how loud the exhaust is when you go from comfort to sport. Possibly even quieter in eco. Not sure.
Will do.
2addicts
