pulling the hand break while moving
12-28-2007, 12:57 AM | #2 | |
364
Rep 1,517
Did you lose your breaks? Are you trying to drift? And yes do not accelerate fast unless your turbos have 2 bags of ice on them! |
12-28-2007, 12:59 AM | #3 |
837
Rep 46,029
it's bad unless ur going 60+ mph then you just pull it hard with a sudden turn of steering wheel. that's the only instance where it's good for your car.
drifting is good too btw. OP RIP |
12-28-2007, 01:01 AM | #4 |
86
Rep 1,153
dont rev your engine too high when the car isnt warmed up because it DOES damage the engine. If you pull on the handbrake while the car is moving it's going to slide (Tokyo drift comes to mind).
12-28-2007, 01:11 AM | #5 |
Smiling politely
165
Rep 7,931
No, it's not bad, it's essentially like pressing the brake pedal, although it only brakes the rear wheels. BMW recommends engaging the handbrake while moving from time to time to prevent corrosion. Don't do this with anyone behind you!
E90 330i Black Sapphire 6MT | 991.1 C4 Platinum Silver 7MT
12-28-2007, 01:30 AM | #6 |
364
Rep 1,517
12-28-2007, 01:31 AM | #7 |
Reverse Homer
151
Rep 1,064
12-28-2007, 11:48 AM | #8 |
chris
278
Rep 12,144
dont rev too hard when ur car is not warmed up, its bad for you... i try to keep revs below 3k for the first 15mins of driving.
Current: 2013 F10 M5 & 2016 Mini JCW 2013 GLK350 (gone), 997.1 GT3RS (gone), 2009 WRX STI (gone), e92 M3 (gone) |
12-28-2007, 02:15 PM | #9 |
45
Rep 1,738
The key word in BMW's instructions is "lightly". I would also keep the release button depressed while performing this exercise so it is easier to modulate the stopping force.
2006 325i - Sparkling Graphite
2000 S2000 - New Formula Red 2007 Chev Silverado crew cab Z71 |
12-28-2007, 03:42 PM | #11 |
152
Rep 3,983
12-28-2007, 03:48 PM | #12 | |||
28
Rep 964
1 - Don't do it if you're commuting or driving around in traffic. 2 - Don't do it until your oil temperature needle has started to move to the warmer side. Quote:
I shift at < 1400rpms in all gears until its warmed up.
12-28-2007, 03:51 PM | #13 |
417
Rep 6,968
Nah, generally speaking -for all cars with manual ebrake- is a friction brake. If you do it too often you may have to replace the contact pad or tense the wire again.
12-29-2007, 03:16 AM | #15 |
this is the way
18149
Rep 8,527
It's useful to avoid a ticket by first braking normally and then using the hand brake to slow down just after you enter an intersection where there's a cop. He won't see your brake lights while you continue to decelerate.
I wouldn't do it any other time and wouldn't do it if someone was behind me either. |
