Engine oil level at a minimum?
12-27-2007, 10:54 PM | #1 |
152
Rep 3,983
The last 3 times I've shut the car off, I've received a minimal oil notice on the cluster and iDrive.. the car only has about 4k miles on it. What gives ?
12-27-2007, 11:10 PM | #2 |
402
Rep 1,858
Drives: F80 M3 Frozen Black F87 M2 LBB
Most likely oil sensor acting up. I had the same thing happen. Had to take it in, they removed it, cleaned it, replaced my oil and filter and put it all back together. It didn't really solve anything out, but there was a TSB on it I think, and that was the procedure. Every 4500 miles I had to put in one quart, which is not that bad. BMW considers excessive oil use if you need one quart every 750-1000 miles.
2016 F80 M3 Frozen Black
2018 F87 M2 LBB Follow me on Insta: M3Piotr |
12-28-2007, 12:15 AM | #3 |
44
Rep 361
I had this once as well. Start by adding a quart and see what happens. I don't know if it b/c if the new engine or what but I know a few people who have come across this.
Adding a quart is a lot easier than having the sensor checked. Start easy and go from there. |
12-28-2007, 03:18 AM | #4 |
96
Rep 378
Drives: '16 340, ex e92 335, ex e46 M3
FWIW, I had no oil loss for 2500 miles. Then I got a low oil, and severe engine damage warning within 300 miles. It was Fri., 4PM, so I just added a quart. Since I was planning on a 3K oil change, I scheduled it, and asked that they check the quantity when it was drained. Sonnen charged me for the oil change, and BMW to check quantity. They "claimed" that I was not over filled. So where did that quart go in 300 miles???
12-28-2007, 03:52 AM | #5 |
Aberry is a scammer
558
Rep 5,507
Drives: SGM E92 335i, AM E90 335i
oil top off
12-28-2007, 08:47 AM | #7 |
169
Rep 481
Drives: F82 BMW M4
i have 10K miles on mine and i just started getting the low oil warnings. When i turn off the car it usually right below min and tells me to add a quart however, when i start the car after a day it is back to normal.. right in the middle... I understand that colder car will show more oil but my concern is that i don't want to over fill it by adding a quart.. I guess i can try adding 1/2. Does it make sense?
2021 BMW X7 M50i + 2015 BMW M4
Retired: 2018 Audi Q7 | 2015 BMW X5 xDrive35i | 2012 BMW X5 xDrive50i | 2010 Audi S4 | 2007 335i Coupe Creator of Leasematic - Lease/Loan Calculator | iOS App Store | Android Google Play |
12-28-2007, 09:18 AM | #9 |
Rep 189
I recently had my oil sensor report the wrong oil level, so I took it into the shop.
Turns out there is a TSB(TIS) or whatever its called, it says something about moisture getting in the oil sensor and ths making it give bad readings. There are like 10 steps to the procedure, maybe Ill scan it and post it here if I get a chance. There is a fix in the latest progman for this.
2007 328xi - Montego Blue - Black Dakota Leather - Gray poplar - Auto - Nav - IPod - Heated Seats - Sport & Premium
12-28-2007, 11:09 AM | #10 |
15
Rep 145
It is normal to burn some oil in new bmw engines. Just top it off and you will be fine. It should stop burning oil after 10,000 Kms. I had to top it off once at around 5,000kms... This also happened to me with my previous e46 when i was new...
Tom
35% Formula 1 Ceramic Tints, //M E-Brake handle, //M Steering Wheel |
12-28-2007, 11:16 AM | #11 |
97
Rep 2,188
Was it just my dealer, or a BMW thing in general, to include the extra quart of BMW oil (in a spiffy case that velcros to the side of the trunk carpet)? The dealer flat out told me "you'll probably need to add this before your first oil change at 15k miles. It's normal."
12-28-2007, 11:42 AM | #12 |
94
Rep 2,160
12-28-2007, 11:42 AM | #13 | |
78
Rep 1,232
Gary |
12-28-2007, 11:52 AM | #15 |
51
Rep 1,928
well if you drove the car hard it would happen...also it is a brand new car so it is gonna take up a lil more oil!!! it is telling you before you fill up the tank again to go have it topped off...every mag on the planet says to do a 1200 miles oil change with this car...but in reality it should be done on every new car to remove all the particles from the fresh engine!!! seriously do a 1200 mile and a 7500 mile change!!! i view them mandatory for this car...i haven't had one problem so far!!! i have about 8300 miles on her now!!! with the dinan tune my car is a smooth beast now!!!! hell the dinan tune even made my car much more enjoyable to drive in traffic!!!! but seriously get an oil change man for the lousy 70 bucks or whatever even 100 it's worth it!!!!! if you drove the car off the lot and floored it right away and didn't do a proper break in that could also be causing this!!! hell on the s63 we have the engine is so big i have to stop by the dealer every 2000 miles for them to top it off!!!!
12-28-2007, 12:44 PM | #16 | |
402
Rep 1,858
12-28-2007, 12:52 PM | #17 |
152
Rep 3,983
12-28-2007, 03:00 PM | #18 |
122
Rep 425
BMdblU:
Curious - are you parked on a hill when you get the notice? I have the problem on my driveway (5 ft pitch up on a 30 ft long driveway), nose out.
2019 G20 330i xDrive Med. Blue/Cognac Leather ZCV|ZPP|ZPX|HK|Remote Start (Ret'd)
2016 F06 640i xDrive Med. Blue/Red Leather MSport|B&O|Driver Asst+|Cold|Night (Ret'd) 2013 F30 335i xDrive Mineral Grey/Black Leather (Ret'd) 2011 E90 328i xDrive Space Grey/Black Leather(Ret'd) 2009 E90 328i xDrive Monaco Blue/(Ret'd) 2007 E90 328i xDrive Graphite (Ret'd) |
12-28-2007, 03:40 PM | #19 |
152
Rep 3,983
12-28-2007, 04:28 PM | #20 |
BK Employee of the month! / Moderator
636
Rep 15,795
It happens to me too! And it's been below 30 degrees when I leave the house in the morning and I park on a slope with the front of the car facing the street. Once I drive about 10-15 minutes, the warning goes away and when I check the engine oil, it's in the middle. A lot of people who park on a slope has the same problem.
GL!
Sponsored by: Pics of the ---> Barbera Beast <--- Martino Auto Concepts (Like them on Facebook MAC) Factory Trained & Authorized by BMW of North America Matt@Camber-Toe (Like them on Facebook Camber-Toe) LuxAngelEyes (Like them on Facebook LuxAngelEyes) LTBMW (Like them on Facebook LTBMW) OEMconcepts (Like them on Facebook OEMconcepts) |
12-28-2007, 05:42 PM | #21 |
Rep 151
Why drive 10-20-30 minutes, or more, just to save the $5 for a quart of oil? Doesn't seem to make sense just because you have all-inclusive maintenance.
