I-Drive Meltdown
12-27-2007, 10:57 AM | #1 |
275
Rep 9,218
I-Drive Meltdown
I got a tire pressure warning message yesterday. Checked the pressures and reset.
Checked them again today and I don't seem to have a problem - either a false alarm or a very slow puncture. My nav disc wasn't working yesterday either (original one - not the sergei remastered version). Today idrive won't boot up at all unless I remove the nav disc. I've tried the reset (press volume button and the 2 eject buttons at once), but it still won't boot up with the nav disc in the slot. I get the BMW splash screen - then it all goes black. Looks like I'm going to have to go to the dealer which is a pain to do when I need the car for the holidays. |
12-27-2007, 11:00 AM | #2 |
The Tarmac Terrorist
949
Rep 29,345
Drives: 997.2 GT3
My goes a bit silly sometimes, not that bad tho, like cd cuts out for a few seconds or nav goes slow, must happen at least once a month!
Get them to loan you a 330i with nav for your holiday! Have a nice time? where are you going? Carlos
997.2 GT3
12-27-2007, 11:02 AM | #3 | |
275
Rep 9,218
I've not had a problem with idrive at all until now, but it seems to be completely fried. It just keeps failing to boot up and restarting with the nav disk in place. I've taken it out now, so at least the radio works, but I'm hacked off about not having nav. |
12-27-2007, 11:35 AM | #4 | |
THE Viv
184
Rep 4,743
Drives: 330i SE
Bit of a mess about, but I think it's going to need your dealer to scratch his head, frown a few times & say "..no idea....May as well stick the latest Progman in it & see what happens...'. Just make sure you stick the original disc in the slot when you take it in. Good luck with it. Viv |
12-27-2007, 12:14 PM | #5 |
571
Rep 7,519
Drives: 2009 E90 335i MT
Check the iDrive subforum on the main E90Post page. There's a lot of information on there about this "phenomenon". Search for "CCC". I had the problem last year; I guess you drew the short straw this year. Mine ended up being a full replacement of the whole iDrive system and then some.
Carlos, as for the CD cutting out, I started getting that after my software upgrade in September. The CD blanks out for about a second somewhere between 15-30 after starting the car. I'm sure it will be addressed with the next software edition but I don't think it is enough of a bother to relenquish my car for a day or two. Now if there were something really wrong, let it piggyback.
2009 E90 335i Montego Blue · Black Leather · Burl Walnut · 6MT · US Spec
SatNav • ZPP • ZCW • 6FL • TPMS • iDrive • PDC • HWS • Xenons • BMW Assist • Power Rear Sunshade • Logic 7 European Taillights • Rear Foglamp • OEM Alarm • PicoTray • DataToys XM-DVR • Multi-view Processor Quaife ATB LSD • Short Shift Knob • Hartge Anti-Roll Bars • AP Racing Front Brakes • 19" Style 269 |
12-27-2007, 04:40 PM | #6 | ||
275
Rep 9,218
It did all start off after I put the data ISO disc in the drive. Can't see how that could have damaged the system though . I think you are right though .. software update will be the first port of call, which isn't a bad thing. I could do with one really. Quote:
Trip to the dealer on the cards either way |
12-27-2007, 04:52 PM | #7 | |
THE Viv
184
Rep 4,743
Drives: 330i SE
Not that it should make any difference whatsoever. A newer Progman version will let you enter destinations without having to spell them & there's some talk of being able to say destinations stored in the car's address book. Viv |
12-28-2007, 10:20 AM | #8 | |
275
Rep 9,218
Coincidentally, that's also when the idrive decided to peg out. Doesn't make any sense at all, but it does seem that this was enough for the idrive to chuck in the towel.. New progman would be appreciated anyway |
12-28-2007, 12:01 PM | #9 |
Rep 48
I've been "playing" with the new Nav disc in the garage. My I drive shut down when the battery got a bit low, and after a reset it would only show the start screen. Shortly afterwards a low battery warning appeared.
Ran the engine for a while and everything returned to normal. |
01-03-2008, 08:17 AM | #10 |
337
Rep 8,811
Is it all fixed now NFS? Did the dealer upgrade your software?
01-03-2008, 08:28 AM | #11 |
275
Rep 9,218
01-03-2008, 03:07 PM | #13 | |
THE Viv
184
Rep 4,743
Drives: 330i SE
Just remember to remove Sergei's 'De-luxe' disc, before you take it to them. Viv |
01-03-2008, 03:59 PM | #14 |
275
Rep 9,218
01-03-2008, 04:14 PM | #15 |
THE Viv
184
Rep 4,743
Drives: 330i SE
He has been awarded various titles in Croatia, non of which are repeatable.
Viv |
01-04-2008, 05:31 PM | #16 | |
275
Rep 9,218
1. Using the steering wheel button assigned to 'next audio source' now scrolls through radio, cd AND audio aux. 2. Switching to audio aux via voice control no longer drops idrive into the audio aux menu. 3. Mobile phone pairing no longer needs to be done with the engine off 4. The idrive looks a cool and slatey grey 5. POI's are searchable by name and information is no longer bizarrely located under 'new destination'. 6. The air con no longer disables air recirculation every time I start the car. I now have Sergei Industries 0801 nav disc with speed cameras in full operation, coupled with the latest software. I'm convinced that inserting the ISO data disc sent to me by Sergei fried the idrive and I think that there is an option here for Sergei to 'bundle' the 0801 disc with an Idrive buggering solution guaranteed to lead to a progman update under warranty. I reckon that there is even more money in this than torches. |
01-05-2008, 05:20 AM | #17 |
Right Responsible
58
Rep 1,646
Great news NFS. You must be well chuffed to get the update and have all running sweetly again.
I am now using the Sergei 0801 disc too (Thanks Sergei) and it is great not to be driving through fields on some of the new town bypasses near me.
Last: 330cd Sport - Silver Grey, 335d M Sport Coupe, F10 535d M Sport.
Current: AW F21 M135i, Coral Red, Pro Nav, Vis, HK, & Clunky Adaptive Suspension Current: F15 X5 XDrive 40d M Sport - Space Grey, lots of toys. |
01-05-2008, 05:30 AM | #18 | ||
THE Viv
184
Rep 4,743
Drives: 330i SE
You'll also have iDrive going straight to the last menu you were viewing, before switching the car off. You can also use voice control to enter nav desinations by full name, instead of having to spell them out & you can jump to specific mp3 tracks- wasn't available on earlier Progman versions. Glad to hear you're happy with the outcome, NFS. Viv |
01-05-2008, 05:57 AM | #19 | |
275
Rep 9,218
I didn't register that this was different last night. The aux input function was the most annoying aspect of the older software. You either had to go into the entertainment menu and select it or use voice control, which then dropped you out of the nav screen and into the audio aux menu. BMW should offer the updates for free really since they are designed to fix 'problems' with earlier versions. |
01-06-2008, 10:32 AM | #21 | |
THE Viv
184
Rep 4,743
Drives: 330i SE
Personally, I think it's even more annoying that dealers will NOT carry out Progman updates FOC, unless the customer 'proves' something is actually 'wrong'. Speaking for myself, I now just look through the SIB updates & check for updated 'fixes'. Once I''m happy that other members are happy with the 'fixes', I check to make sure I've got my 'irrefutable' proof for the need to carry out a Progman update FOC & make my way to dealer. Viv |
01-06-2008, 01:05 PM | #22 |
337
Rep 8,811
Should try and get my idrive software upgraded!
