ARMA SPEED
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Suspension | Brakes | Chassis
      09-24-2014, 03:16 PM   #1
Alpinef82
Alpinef82's Avatar
41
Drives: AlpineF82
H&R front and rear sway bars
Found this on tuner motorsport website ... H&R front and rear sway bars .. What is the stock size?
      09-25-2014, 02:15 AM   #2
peter_s
peter_s's Avatar
Sweden
38
Drives: M2, Datsun 280Z, MGB GTS V8
Interesting. I still feel that the swaybars on this car is the last thing I would worry about. Maybe it's different when running slicks...
7:51,4 BTG BMW M4, 8:35 BTG Mini Clubman S, 8:56,6 BTG Swift Stage 2
208 laps on the Nordschleife
      09-25-2014, 03:43 AM   #3
RingMeister01
Croatian
RingMeister01's Avatar
884
Drives: PORSCHE
Is installing the rear sway bar as PITA as the E92 was ???
NARDO GREY '18 PANAMERA TURBO
Ducati V4 S Corse (track only)
Husqvarna FS450 (track only)
Looking for an SUV
      10-06-2014, 06:44 PM   #4
HP Autosport
Supreme Allied Commander
Drives: F80 M3
Yes, it is!
      01-29-2015, 11:10 AM   #5
Greg FEightytwo
Greg FEightytwo's Avatar
Drives: BMW GT4 M4 and X5M
Has anyone confirmed the OEM front sway bar specs? 30mm seems to a be large bar but the car is bigger. I took my M4 to thunder hill and notice a bit of body roll on front. I'm interested in the front bar for sure if its bigger and will help reduce that.. I have EDC and H&Rs.
      02-04-2015, 03:52 PM   #6
RSXDC5
RSXDC5's Avatar
707
Drives: M3
Originally Posted by HP Autosport View Post
Yes, it is!
HP Autosport, do you know the stock sway bar (F & R) sizing in MM?
2015 M3 - AW 6Spd w/ CCB
MCS 2WR Dampers, Spec Twin Disk Clutch, MaxPSI CH, F80Paul Ethanol Tune, 3.5in DPs
      02-04-2015, 06:18 PM   #7
HP Autosport
Drives: F80 M3
No, we don't have that information. The next time our shop car is on the lift we will take a measurement.
Appreciate 2
      02-12-2015, 11:47 AM   #8
HP Autosport
Drives: F80 M3
Just to add to this thread.
Springs, struts and shocks should be upgraded before sway bars. That said, sway bar does cost less and is much easier to install(with the exception of the rear bar).
      02-12-2015, 12:40 PM   #9
Greg FEightytwo
I have edc h&rs just wanted a little less body roll in the front back feels good
      02-12-2015, 02:20 PM   #10
fourtailpipes
110
Drives: the ladies crazy
veblen goods, priced for fools. the better part of a thousand dollars for two bendy bars of spring steel and four urethane bushings.
if you owned a vw golf, h&r would be selling you bars of similar size with lots of extra required pieces for about half the price.
      02-21-2015, 04:58 PM   #11
Greg FEightytwo
26mm front
23mm rear
Appreciate 2
      07-16-2017, 11:20 AM   #12
NightAngel
Curve trader
NightAngel's Avatar
France
Drives: BMW M4 F82
Originally Posted by Greg FEightytwo View Post
26mm front
23mm rear
Thanks ! These values are those of the "standard" BMW M4 or the one equipped with the competition package ?
The ETK references of the stabilizer bars are different with the competition pack... I suppose, therefore, that their diameter is increased.
      07-16-2017, 11:39 AM   #13
Greg FEightytwo
26mm front
23mm rear
these are upgrades to standard. mine are same diameter as gts 30mm / 25mm adjustable HR
      07-16-2017, 11:58 AM   #14
NightAngel
Curve trader
NightAngel's Avatar
France
Drives: BMW M4 F82
OK !
I think to mount only the front bar (30mm), rear bar could cause motricity loss on bumpy roads.
      07-16-2017, 04:08 PM   #15
Greg FEightytwo
OK !
i would do both with dampers and aero the car stays super flat
      07-17-2017, 10:02 PM   #16
zac5
zac5's Avatar
China
152
Drives: F95 X5M
I have only front with H&R swaybar, the rear is stock bar, worked great so far.
"Learn the rules like a pro, so you can break them like an artist."
f80post
