09-22-2014, 11:49 AM | #1 |
229
Rep 3,899
F80 M3 Brake Judder
Hello all,
My car has developed a pronounced brake judder when decelerating hard from any speed above 70 mph. You can feel it through the steering wheel and brake pedal- it's very noticeable . If I apply the brakes gently there is no judder. I have felt a slight judder before but the problem seems to be getting worse and more noticeable. The car has 3000 miles on the clock and has the standard steel brakes. Any advice or probable causes would be appreciated......
2014 AW F80 M3 DCT
2011 AW E90 M3 DCT - Sold 2010 JZB E90 M3 DCT - Sold 2009 6MT E90 LCI 335i M -Sport - Sold |
09-22-2014, 11:56 AM | #2 |
14
Rep 80
Sounds like you might potentially have a warped rotor. This can occur when the rotor cools down unevenly like driving through water when they are hot or leaving the parking brake on after a hot lap on the track. But this is not very common, and certainly not normal. Your dealer will be able to put a run out gauge on the rotors and determine if this is the issue very quickly.
09-22-2014, 12:05 PM | #3 |
351
Rep 1,749
its not a warped rotor. most likely you got some pad desposit on your rotor and it chatters every time it goes over it. is there any dark spots on your front rotors. did you do any aggressive braking recently or had the car on the track without cooling down?
"It gave you amazing satisfaction, but anyone who says he loved it is either a liar or he wasn't going fast enough." - Jackie Stewart on racing at the Nurburgring
09-22-2014, 12:10 PM | #4 |
229
Rep 3,899
I will check for dark spots. As for aggressive braking , not really although I have decelerated moderately from 150 mph on the autobahn a few times but not full hard braking . Never tracked the car.
2014 AW F80 M3 DCT
09-22-2014, 12:19 PM | #5 |
1791
Rep 2,995
I've developed the same thing at 1600 miles but...
I'm pretty sure it's pad deposits. It develops with heat build-up in the rotors, then goes away when cooling down or modest brake usage. It's presented itself about 3-4 times and, when braking hard, almost feels like i'm braking on a very broken surface, in that the whole car and steering wheel suddenly feels like it's been pulled right and left simultaneously. Then it goes away quickly. I admit this is different than other pad deposits I've felt. The first time I felt it, I did think something was wrong with the brakes or tires - it came on very suddenly during a hard braking. |
09-22-2014, 12:51 PM | #7 | |
229
Rep 3,899
2014 AW F80 M3 DCT
09-22-2014, 12:57 PM | #8 |
14
Rep 80
So what is the solution? Turning the rotors? Long term? Different pads? I have actually been thinking about changing the brake pads to something that dusts much less. Getting tired of the wheels being filthy a day after washing.
09-22-2014, 01:11 PM | #9 |
351
Rep 1,749
its not abs. you will feel the pedal vibrate when abs kicks. autobahn speeds make them heat up quick and they will fleck away some pad material. i did it to mine over there easily. you should see light grey smears on front and back sides of rotors. i'm fixing to put track pads, spacers, and stud conversion. i'm going to remove the rotors and have a good check over them along with the pads. pretty sure the compound is very low temp. not sure why yet.
09-22-2014, 01:13 PM | #10 |
351
Rep 1,749
ceramic pads will probably do you fine. if there is pad material and you don't have the patience to scrub them the old fashioned way you can remove them and sand down the material. DO NOT HAVE THEM TURNED with a brake lathe. it compromises the rotors ability to manage heat and you can have cracks form prematurely.
JohnM47.50 |
09-22-2014, 01:55 PM | #11 | |
670
Rep 4,959
I would suggest you look into obtaining some Porterfield R4-S brake pads. They are track-worthy pads that have great bite and low dust (they are quiet, too). http://porterfield-brakes.com/manufa...akes/R4-S.html If you conduct some research, you'll see that these pads are used quite extensively throughout the enthusiast community. I have a set that I use for my HPDE days. Hope the info helps!
Current: '23 G20 M Sport 330i
Current: '20 X253 GLC300 SUV Gone: '20 W205 C43 Sedan Gone: '18 W205 C43 Sedan Gone: '13 W204 C63 Sedan |
09-22-2014, 01:56 PM | #12 |
1791
Rep 2,995
Turning the rotors will not do anything good unless the rotors are warped, which would almost certainly create an issue all the time.
This is most likely an issue with pad deposits, which is almost certainly a pad issue. Unless it becomes alot more frequent, I'm going to live with it. Here's a more detailed description of what happens: 1. You drive around aggressively (on the street/back roads for me) and work the brakes a bit. By no means to track levels, but enough to put some heat into them. 2. Braking is fine. 3. At some point, you initiate a higher speed braking event. Perhaps 70mph-30mph. As you begin braking at 70mph, braking feels fine. However, this is putting alot of heat into the brakes and maybe around 55mph a sudden and strong emergence of vehicle shudder comes on. 4. It is not ABS, which would be pedal shudder, but instead a shudder that is a result of you braking but feels like the tires themselves are squirming. It is constant while you continue braking and you feel it strongly in the pedal and steering wheel. 5. You let up braking and maybe it happens a bit next time you brake, or maybe it's gone altogether. Within a short period of brake cooling, it's gone altogether. ... When it occurs, it feels like very even brake deposits. Again, I'm basing this off it happening very distinctly maybe 4x total. It's not a warbling or on-off-on shuddering, it's just a sudden-onset constant wobble. First time it happened, I thought I had a flat or something....
AW/Carbonstructure 6MT 2015 M3 picked up 8/22/2014. Stripper except for adaptive suspension. Weighed at 3,450 pounds with 1/4 fuel. 70,000 miles as of February 2020.
09-23-2014, 10:00 AM | #13 |
493
Rep 1,104
You, and all of us, need to bed the brakes in properly to ensure that a good layer of pad material is EVENLY transferred to the rotor. Check out the following:
http://www.essexparts.com/learning-c...rs/post/Bed-in |
09-23-2014, 10:57 AM | #14 |
229
Rep 3,899
Here is a pic of my FR brake disc, not sure if this is normal or not?
2014 AW F80 M3 DCT
09-23-2014, 11:33 AM | #15 |
351
Rep 1,749
the dark patches is the pad material stuck on the rotor surface. need to either scrub them with light pedal pressure for a long time or take them off and sand off the deposits with some sandpaper. while at it take a thin screwdriver and poke out all the caked in dust in all the holes.
09-24-2014, 08:37 AM | #16 | |
493
Rep 1,104
The above should remove any irregular deposits on the rotors and place a uniform layer of pad material on the rotors. If it doesn't work, then you can try the above with a more aggressive 'track' oriented pad which should nearly always do the trick. Having to scrub the rotors would be the last thing to try and don't let anyone 'turn' the rotors for you; the rotors aren't warped, (or at least the odds of that being true is very low). Bish |
09-24-2014, 11:52 AM | #17 | |
351
Rep 1,749
09-26-2014, 01:32 AM | #18 | |
229
Rep 3,899
2014 AW F80 M3 DCT
