09-17-2014, 09:22 AM | #1 |
1792
Rep 2,995
1200 mile service - pictures and notes
Featured on BIMMERPOST.com Having my 1200 mile service done at Ottos BMW in West Chester, PA and they gave me about 30 minutes in the shop with my car and tech to take pictures, ask questions, etc. My tech was excellent and a long-term M technician. He DID NOT know the plugs were replacement, but when he went to get the "kit" for the service it included new plugs - so I don't think he would have missed it or anything. The oil drain plug is readily accessible, nothing to remove, and the rear diff drain plugs are 14mm allens. Super easy to access and service, and the rear diff is the standard fill until overflow then plug it up. The engine oil was visibly quite fresh. No real signs of it being dirty, which...frankly...it was cleaner than any new engine oil I've ever changed, so I was surprised at how little combustion byproduct I could see in it. Good for BMW for obviously creating a clean running engine with little blow by and good air/oil filtration. The rear diff oil was filthy. Even though the plugs were clean, the oil itself was complete slimy metallic particles. The tech was actually surprised because the drain plugs looked perfectly clean, but when he stuck a gloved finger up in there it came out slimy looking. Some interesting stuff: - The underside is filled with "easter eggs" labelled "///M" everywhere. Panels, suspension arms, pretty cool. - The front underbody panel has an integrated jacking point in the center front of the car. It's welded on and obviously welded on by hand, not a super clean weld. It's actually kinda cool to see this. - Without taking the felt underbody piece off, I could not see where the trans fluid was kept since the 6MT is a dry sump. I plan on changing it at 15k-30k miles. Anyway, here's some pics. Enjoy! Rear diff plugs below: Joe P.s. I was impressed by the tech here and he offered for me to request him again, which I will. He also let the oils drain a nice long time till they were simply dripping, which I appreciated.
AW/Carbonstructure 6MT 2015 M3 picked up 8/22/2014. Stripper except for adaptive suspension. Weighed at 3,450 pounds with 1/4 fuel. 70,000 miles as of February 2020.
09-17-2014, 10:48 AM | #4 |
368
Rep 1,175
Drives: 2015 SO/SO F80 & 135 M-Sport
Nice...thanks for sharing!
///M3 SO/SO / MT / 19" Black Alloys / Executive Pkg. / Lighting Pkg. / Adaptive Suspension / Enhanced USB / HK / Full Front XPEL / 35 Tint / MODS: Custom painted engine cover and grill surrounds, Pedal Haus Kit, M-Performance Alcantara shifter/boot & e-brake boot, carbon e-brake handle, wrapped seat shells/rear headrests, M-Performance Spoiler with CRT Stripe.
09-17-2014, 10:53 AM | #5 |
Moderator
617
Rep 10,855
Cool.
My recent ED photos: http://f80.bimmerpost.com/forums/sho....php?t=1026808
my not-so-recent ED: http://www.e90post.com/forums/showthread.php?t=31829 Please join BMWCCA http://bmwcca.org/index.php?pageid=c...&ref_by=300279 |
09-17-2014, 11:02 AM | #6 |
1792
Rep 2,995
By the way, in the rear I believe there are 4 jacking points: The jack pads and there is a place where the aluminum bracing meets the subframe that is behind the tire and slightly towards the center of the car. I would not jack up on this diff, given how finned it is and how tall and slanted the fins are.
In the front there are 3 easy to spot jacking points: The jack pads on the sides, and that welded center protusion on the integral aluminum belly pan. Disclaimer: The tech and I agreed that protrusion has no point but to be a jacking point, as it's a welded on jack-pad looking protrusion, but can't confirm this with 100% certainty. I'd certainly use it if I needed to though. |
09-17-2014, 11:38 AM | #9 |
42
Rep 250
Drives: 2015 M4 DCT
Thanks for the info! Mine is at the dealer getting the 1200 break-in service now. Can't wait to get it back this afternoon and really drive the M for the very first time!
'97 328IS SPP 5MT sold '99 E46 328i SPP AT sold '04 E46 M3 6MT RIP '88 E30 M3 5MT RIP '08 E92 M3 6MT sold '15 F82 M4 DCT
09-17-2014, 11:42 AM | #10 |
1792
Rep 2,995
Rear diff is standard and man did it need it. Dirty dirty diff. I haven't heard any diff chatter though since maybe ~600 miles, so I wonder if maybe the diff really does break-in.
Tech commented that BMW always before recommended manual trans fluid change at 1200 miles, so he was surprised by the change, but also had alot of faith in it and felt that they did it for a reason. No offense meant to the tech, but he didn't know about it before I came in that day since this was his first f80/f82 break in service. He was super knowledgeable about past motors, was surprised they retired the s65 as he said "We never had a single problem with that engine. Not one problem [at the dealership where he worked, which is a large volume dealership]" The guy knows the history of these cars in terms of service, common failure items, etc....but he's not spending hours on the forum every day scouring every rumor. Good for him |
09-17-2014, 08:34 PM | #12 |
1792
Rep 2,995
The underside is covered in M symbols but it's actually impressive how much is labelled f80 vs f30. So you don't have to worry about identifying potentially cheaper parts from f30
09-17-2014, 10:54 PM | #14 |
1862
Rep 3,661
Great I'll just follow your lead and use the same tech
Thanks.
2016 F80 M3 AW/SO (Manual) - Picked up at the Welt 08/28/15 My Amazing European Delivery Story |
09-18-2014, 10:53 AM | #15 |
1792
Rep 2,995
Tech was Matt. Great guy, really appreciated his time and approachability. I left the bay when I felt like I was done, not because he seemed to be trying to move on.
09-18-2014, 11:03 AM | #16 |
504
Rep 3,446
Dirty differential oil, hmmmm...
See my photography at http://ronscubadiver.wordpress.com
09-18-2014, 11:14 AM | #17 |
1789
Rep 4,216
Thanks for sharing!
2020 F87 M2 Competition /l\ LBB /i\ Executive Package 2013 E70 X5M /l\ Space Grey /i\ Full Silverstone Leather /l\ LED Headlights /i\ Comfort Access /l\ HUD /i\ Ventilated Seats /l\ 22" BBS SV BMW CCA Member |
09-18-2014, 12:08 PM | #18 | |
Save the Manuals
1714
Rep 2,937
2023 G80 6MT, CCBs
2002 330i Dinan, 5MT 2000 Z3 Conforti, 5MT |
09-18-2014, 12:34 PM | #20 | |
340
Rep 1,089
09-18-2014, 01:03 PM | #21 | |
Croatian
884
Rep 3,613
Drives: PORSCHE
NARDO GREY '18 PANAMERA TURBO
Ducati V4 S Corse (track only) Husqvarna FS450 (track only) Looking for an SUV |
