Pandora Car Alarm System
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > DIY and Coding Discussions
      09-16-2014, 01:37 AM   #1
M4NACE
M4NACE's Avatar
28
Drives: F82 M4
DIY: CF Trim Surround M performance
1. Mask tape the top area surrounding the base of the trim.
2. Use a praying tool (plastic preferred), insert slowly at 12' Oclock position and pry upwards. The trim should pop up easily.
3. carefully turn the trim over, remove the red switch from the base of the trim, and then remove 2 screws holding the gear-selection button in place.
4. NOTE * BECAREFUL WITH THE 3 WIRES HINGED ON THE SMALL TAB (SEE PIC). CAREFULLY REMOVE THESE ONE BY ONE.
5. Reverse the steps with the new CF trim and you should be good to go.
should take no more than 10 mins. really easily.
      09-16-2014, 02:55 AM   #2
LukasAT
118
Drives: 2024 BMW X5M
is it working also with the plastic trim to pop out the new one? mine is now really right compared to the original one ... did you try?
      09-16-2014, 10:06 AM   #3
M4NACE
M4NACE's Avatar
28
Drives: F82 M4
I'm not sure if I understand your comment correctly, but are you asking if I have removed the new one with the same method? I would imagine so, there is nothing different from the trim.
      09-16-2014, 03:39 PM   #4
LukasAT
118
yes you understood it correctly. I tried it and the new one is much tighter .. there is no gap between it and the other part of the car
      09-16-2014, 04:31 PM   #5
Sivart321
Sivart321's Avatar
32
Drives: 2015 F80 M3
Do you have a daylight picture? The alcantara parts looks interesting, but doesn't match anything else in the interior. Is that weird looking at all to you?
Cool nonetheless!
      09-16-2014, 04:41 PM   #6
M4NACE
M4NACE's Avatar
28
Drives: F82 M4
Cool nonetheless!
You are right, it doesn't match any part of the interior, but This doesn't really bother me. I love the Alcantara. I plan to do CF brake handles with Alcantara boot once it get's released (either OEM or after market). should complement the interior nicely.
Ofcourse, there is nothing wrong with leather all the way. I just like Carbon more.
      09-16-2014, 04:52 PM   #7
Sivart321
Sivart321's Avatar
32
Drives: 2015 F80 M3
I am not saying it looks bad, as it is subtle and hard to tell. Any chance you can take another pic installed? I imagine its pretty nice.
I wish we could get the alcantara headliner!!
      09-16-2014, 05:00 PM   #8
M4NACE
M4NACE's Avatar
28
Drives: F82 M4
^ THIS. I SOOOO WANTED THIS. but NooooOOoOoo BMW went cheap. LOL maybe they will do it on the M3 GTS.
      09-16-2014, 08:17 PM   #9
M4NACE
M4NACE's Avatar
28
Drives: F82 M4
better photos daytime
      09-16-2014, 09:28 PM   #10
Sivart321
Sivart321's Avatar
32
Drives: 2015 F80 M3
Looks way better in those photos. Do want now.
      09-17-2014, 10:44 PM   #11
khanyam4
Ring Leader of G8X Trolls
khanyam4's Avatar
Cambodia
802
Drives: NA
very nice and thanks for the diy.
      11-02-2014, 01:29 PM   #12
biggie27
33
Drives: M3
For those that don't like the Alcantara I noticed that u can separate the black plastic from the chrome surround, and the same with the carbon from the alcantara since there screwed on maybe someone can mix and match
      11-16-2014, 05:25 PM   #13
tmdpo
Drives: M4
Does the carbon shift knob cover sit flush with the gear? The shift knob cover I bought (61 31 2 343 709) seem to be little bigger than the silver one that came with car.
Thanks
      11-16-2014, 06:09 PM   #14
NorCal f80
346
Drives: M3
I'm not an Alcantara fan, I might look into this.
      11-23-2014, 11:37 PM   #15
NorCal f80
346
Drives: M3
Installed mine yesterday, swapping the alcantara surround. I do like the look better especially since I don't have/like the CF parking brake because of the alcantara, but It doesn't fit [on the plate itself] as snug as the alcantara.
      11-24-2014, 08:43 AM   #16
djhex36
Mr. Fluffy
35
Drives: 2015 AW/BLK M4
I like it without the alcantara surround! I will leave the shifter silver to match the iDrive knob.
Search this Thread:
Advanced Search
f80post
