BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Suspension | Brakes | Chassis > Suspension recommendations?
      09-15-2014, 12:14 AM   #1
Fundguy1
Fundguy1's Avatar
2032
Drives: 335 e93
200,000 miles. After turbo upgrades in my sig comes clutch, then LSD, then suspension. So it's a way off but not too far. What can you guys recommend as far as improving handling but keeping the ride similar comfort wise to stock. I drive this for 3-6 hours a day 4-5 times a week so ride comfort is a priority but I do like doing 4 wheel drifts etc. what stuff should I replace stock, buy aftermarket, etc. coil overs, springs, bushings, sway bars, swing arms, etc. I don't want to lower it much if at all. And I don't want to be fiddling with adjustments all the time. I have sport suspension on it currently. Thx.
'08 e93 AW 335i 6MT,Vargas Stg 2+ 20T clipped,VRSF catless dps & 7"FMIC,ER chargepipe&Tial, MMP inlets&outlets,Motiv Stg 2 fuel rail&dual disc clutch/fly, JB4G5,MHD w/Motiv tune,Fuel-it Stg 3 LPFP,Wavetrac LSD w/lockdown, KwV2,M3(Strut brace,frt control arms,steering wheel)AKE blk sub bush,re11 245/305,19x8.5et30&19x11et43,SmartTop,RE trans mounts,Msport rear bump & skirts,15%tint,ZSP knob,Stoptech rotors,241k miles
      09-15-2014, 02:07 PM   #2
Fundguy1
Fundguy1's Avatar
2032
Drives: 335 e93
Nothing?
      09-15-2014, 02:17 PM   #3
Rezinator
Drives: 335is
I highly recommend the BMW Performance Suspension V2. Comes with all parts, no fiddling, great ride, better than stock ZSP, absorbs bumps much better, less body roll.
      09-15-2014, 02:49 PM   #4
datbimmer
Wastegate Rattle
113
Drives: 335i m6t nav sport
More details ?
      09-15-2014, 03:14 PM   #5
fravel
fravel's Avatar
Drives: Monaco Blue '06 330i
I'm a big fan of the Bilstein B12 kit. Moderate lowering when compared to the non-sport suspension (probably won't make any difference on a car with sport package) and no adjustments to mess with. Just swap them, get your car re-aligned and enjoy.
      09-15-2014, 04:55 PM   #6
Fundguy1
Fundguy1's Avatar
2032
Drives: 335 e93
I'll try to look them up. I'm not finding a bmw kit for the vert though.
      09-16-2014, 12:27 AM   #7
cvc 22349a
cvc 22349a's Avatar
Drives: 335i
M3 subframe bushings
Front control arm bushings
Strut mounts
Rear shock mounts
Koni sport shocks/struts
2007 E90 335i, TiAg, 6AT, ZPP, ZSP, ZCW, 6FL, HD
Quaife lsd, ETS fmic, GIAC s/w, Dinan intake/exhaust/oc, Koni/M3 susp, Apex Arc 8, Mich PSS
      09-16-2014, 09:28 AM   #8
Fundguy1
Fundguy1's Avatar
2032
Drives: 335 e93
So the only vert specific kit I see is the kW. The rest list coupe but not vert. I can't find the bmw version on the bmw or getbmwparts sites. I haven't changed anything since I got the car. Just one bent swing arm 75,000 miles ago. Again, please list specifically each part I need and links to where to get them would be great. I probably need bushings, swing arms, etc. again, I want to maintain the stock sport suspension ride height, comply ride, but improve the handling and lessen the sway in the turns. I don't want to get something with a hard or bouncy ride as I drive 20 hours a week average. Thx.
      09-16-2014, 09:30 AM   #9
Fundguy1
Fundguy1's Avatar
2032
Drives: 335 e93
Strut mounts
Rear shock mounts
Do the bushings come in a kit or do you need to purchase them separately? Are the control arm bushings different on the 335 and the m3?
      09-16-2014, 10:13 AM   #10
Fundguy1
Fundguy1's Avatar
2032
Drives: 335 e93
I read the write ups about the Bilstein B12 setup and it sounds like it fits the bill. There is a different number available for the convertible. Anyone have any experience with this on their vert? And what else do I need to get good results? Sway bars? Bushings? Control arms? Thx
      09-16-2014, 01:21 PM   #11
mlifxs
Diamond Geezer
mlifxs's Avatar
212
Drives: Jet Black 2007 328i Saloon
for the heck of it I went to Ecstuning.com, plugged in your '08 e93 335i and, for shocks, they do show Koni yellows.
http://www.ecstuning.com/BMW-E93-335...ocks/ES518057/
You might want to verify (I would) with them before buying and possibly with the Koni website support desk as well.
ecstuning also shows the b12 kit under "cup kits"
http://www.ecstuning.com/BMW-E93-335...its/ES2725395/
you can also use "bmw garage" to search for folks with convertibles and view their setups. I found a guy with Koni FSD on a 335i here:
http://www.e90post.com/forums/bpgara...o=view&id=4068
no idea if he or you would like that setup
      09-20-2014, 07:56 AM   #12
cdgatti
cdgatti's Avatar
255
Drives: e90 328i
200K on a 335? I would not put too much money into the suspension at this point. Perhaps some koni yellow or bilstein hd and refresh of the mounting hardware.
      09-20-2014, 08:28 AM   #13
Fundguy1
Fundguy1's Avatar
2032
Drives: 335 e93
Already doing a 10k turbo upgrade. Even if it lasts only 100k more it's cheaper than used lol.
      09-20-2014, 09:05 AM   #14
CALWATERBOY
CALWATERBOY's Avatar
146
Drives: 2009 E93 N54
Driving pleasure may be degraded by increased power without accommodating same in your drivetrain and suspenion. IMHO, suspension/LSD first, then power.
The humble truth: You may not feel the need for more power after suspension mods. Put less than $10k into suspension & LSD - you'll have surprising, no-limit handling with better ride quality at speed - slightly firmer down low.
Gotta wonder - does Florida do mandatory emissions tests? Maybe you've resolved that if you're ready t'pop.
RECOMMENDED INSTALLS
      09-20-2014, 04:31 PM   #15
Fundguy1
Fundguy1's Avatar
2032
Drives: 335 e93
Inspection in Florida is nil. Doesn't exist. You renew your registration by paying on the Internet then go outside to burn your leaf and branch pile with gasoline.
As for the suspension etc it's going to be a month after turbos.
