2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics Wheels and Tires -- Sponsored by The Tire Rack Wheels affecting performance
      09-11-2014, 08:27 AM   #1
joshbromberg
20
Drives: 228i
I currently have the stock 18" M Package wheels on my 228i. I plan on getting aftermarket rims, most likely 19". How will this affect the handling and other performance aspects? My car drives beautifully and I wouldn't want to mess that up. I feel like if I put 19" wheels on I would want to also drop the car about an inch on all four sides to compensate for the elevated ride height. I just want to know what will give me the best handling.
      09-11-2014, 09:06 AM   #2
USPSALIMITED
USPSALIMITED's Avatar
Drives: Ford Fusion
Been wondering myself, but in the opposite direction (17's for winter set).
I thought this was interesting, http://www.caranddriver.com/features...d-tires-tested
If you have ever ridden a good bicycle much, it is amazing how much difference light wheels make in braking and acceleration. Not exactly apples and apples I know.
      09-11-2014, 01:17 PM   #3
CaliBlu2
CaliBlu2's Avatar
23
Drives: 228i Msport
I put 19s on and it did compromise the handling to a degree and it bothers me. The diameter changed .55" in the rear and not sure about the front. That's why the car looks like it was dropped. After these tires wear out, I will make sure to get my wheel specs the same as stock, by then there should be more options for wheel and tire set ups. I hope!
      09-11-2014, 02:06 PM   #4
BLK235iNJ
BLK235iNJ's Avatar
183
Drives: m235i,13MustangGT,84C10,99A8
weight is a factor too
      09-11-2014, 06:11 PM   #5
VMRWheels
VMRWheels's Avatar
2050
Drives: BMW
2013 BMW M3  [10.00]
2015 BMW M4  [0.00]
2013 BMW F30  [0.00]
2014 BMW F22  [0.00]
2013 BMW F06  [0.00]
+ 1
Steering may also feel heavier or "slower"
Here are some good reads regarding unsprung weight
http://www.tirerack.com/wheels/tech/...jsp?techid=108
http://en.wikipedia.org/wiki/Unsprun...nsprung_weight
^ Yes, I know it's Wiki lol
      09-11-2014, 07:11 PM   #6
hyperzulu
hyperzulu's Avatar
Drives: 2015 M235i
OP, you are not supposed to modify the overall diameter of your OE wheel/tire combination, so dropping the ride height should not really be necessary for that purpose. Find a tire size that keeps your overall diameter as close to OE as possible.
I have 19's on my current car. I think 19's look brilliant, but while turn-in is crisp, I feel like 18's would have been better for handling. You can feel the car become a bit unsettled because the rest of the chassis is not ready for the sharper response. It's like the two are not in harmony.
For a street car, you have to do something drastic to notice, but I'm sure with enough options and time you might find a better combination than what the BMW engineers have come up with to improve on handling.
      09-11-2014, 09:09 PM   #7
HX_Guy
119
Drives: 2014 BMW M235i
As was mentioned, what you want to do is get a lower profile tire with your new 19s so that the overall diameter of the wheel/tire doesn't change or doesn't change much.
For example, your 228i M Sport came withe 225/40-18s all around (at least that's what TireRack is telling me) so if you went with 19s, you would get 235/35-19 tires which are only 10mm more in diameter, so it will "lift" your car only 5mm, or about 1/5" of an inch, barely noticeable if any. There are other combinations too but you get the gist.
As for performance, if the wheels are heavier than stock, then you probably will feel it in the steering and possibility in the acceleration. I know when I put spacers on my stock wheels, I could feel it in the steering, it felt heavier and slower.
2014 BMW M235i 6MT
2012 Mercedes E350 Bluetec
      09-11-2014, 11:35 PM   #8
samtnel
samtnel's Avatar
Drives: 2020 M4 Alpine White
which rims are these? they BMW?
      09-12-2014, 09:02 PM   #9
hoppy6698
hoppy6698's Avatar
Drives: M235i, Estoril Blue on Black
Isn't there a way to increase size of the wheel without increasing the overall rolling diameter? Or at least minimize it?
"Nothing in the world is more dangerous than sincere ignorance and conscientious stupidity." MLK Jr.
      09-12-2014, 09:18 PM   #10
hyperzulu
hyperzulu's Avatar
Drives: 2015 M235i
Yeah. Shorter sidewall and/or narrower tire.
      09-20-2014, 05:11 PM   #11
CaliBlu2
CaliBlu2's Avatar
23
Drives: 228i Msport
These are M6 Replicas. 19*8.5 square.
2addicts
