09-09-2014, 10:14 PM | #1 |
25
Rep 80
DIY Request: How to remove fold down rear seat backs
Previous M3 versions with fold down rear seat backs had a J type cap in the center. You used a torx head to remove the securing bolt, remove the cap and just lift the seat backs from their cradle and slide the other end out. Simple. My F80 doesn't seem to have this clip and they look non removable, but I doubt it. Has anyone removed their rear fold down's? If so, how'd you go about it?
Thanks |
09-26-2014, 06:00 PM | #2 | |
351
Rep 1,749
Removing the rear seat (top and bottom) saves 40lbs (cloth seats) I have photos just added to this thread. tools needed: T50 torx bit socket driver towel 1. pull up and out on seat bottom 2. with seat bottom out place thick towel on center gromet to keep the seat back from touching it. 3. pull up from base of corner seatback cushion on rear passenger side (the part behind the seatbelt) you dont need to remove it completely. you will see the T50 screw holding the outer hinge. remove the screw and pop the seat back outwards. 4. remove drivers side same as passenger. the drivers side passenger seat has the center pin for both seats 5. pop back in the corner cushions view from rear after complete. this saves 40 lbs and makes a handy bay for transporting track wheels in rear. aftermath from removing non fixed items plus rear seats. nice little diet for about 10 minutes of work.
"It gave you amazing satisfaction, but anyone who says he loved it is either a liar or he wasn't going fast enough." - Jackie Stewart on racing at the Nurburgring
10-18-2014, 10:02 AM | #4 |
657
Rep 1,749
I am more interested in this as it sounded great on my e92 m3 once I had the rear fold down seats down or ultimately removed. I could hear the raw exhaust much more
10-18-2014, 12:17 PM | #5 |
340
Rep 1,089
I have no personal experience on removing the rear seats but would like to add a note to anyone who's attempting to remove it to be more careful as the F80 have rear heated seats.
10-21-2014, 06:24 AM | #6 |
351
Rep 1,749
good point. i don't have that luxury. when i get one in the shop i will update the thread with disconnecting the heaters.
10-21-2014, 06:25 AM | #7 |
351
Rep 1,749
yes it sounded even better on the track! its noticeably quieter with the seats back in it now. good thing this car sees the track often
08-19-2019, 07:16 PM | #9 | |
///Multiple
2992
Rep 4,243
Drives: M4 Coupe | M3 | Z4M Roadster
Garage List 2006 BMW Z4 M Roadster [8.81]
2016 BMW M4 Coupe ( ... [10.00] 2018 BMW M3 (Euro D ... [0.00] 2011 BMW 335is Coup ... [10.00] |
This thread is almost five years old and if you look at karussell's profile, he hasn't posted here since April, so it's unlikely that he'll even see your post.
The Coupe: 2016 M4 | Sakhir Orange | Black Full Merino Leather | CF Trim | M-DCT | More | ED 5/13/16
The Sedan: 2018 M3 | San Marino Blue | Black Full Merino Leather | CF Trim | M-DCT | ZCP | ED 7/18/18 The Roadster: 2006 Z4 | Interlagos Blue | Black Extended Nappa Leather | Carbon Leather Trim | Purchased 7/19/12 |
12-21-2021, 09:48 AM | #10 | |
Rep 4
Removing rear seat F82
08-18-2022, 09:55 PM | #11 |
IG: @panda_exprs
114
Rep 138
pics and weights
So, I realize there's fairly few people interested in pulling the rear seats of the F8x for weight savings, but I just did it on my '16 F80, and there were a few aspects of the job that slowed me down, so here are some pics... and also documentation of the weight saved.
The seat bottom just pulls up from the front edge... just stick your fingers under it and yank up and a bit forward. One clip per side of the car. If your car has heated rear seats like mine, remember you'll have to disconnect the wiring at the juncture box under the bottom cushion... you'll have to dislodge the wiring from the clips along the edge of the box too: The first time you do this, you may have trouble finding the T50 star-head bolts. You have to peel back the outermost upper seat back sections to see it... And for the removal of driver's side (larger) portion of the split seat back, you need to fully dislodge the outer upper seat back cushion to make clearance to angle the seat back hinge post out of the hole attached to the car. There's a rectangular metal wire loop that has to be pulled up and out of the receptacle for it to free the bottom part of the outer seat back cushion. I never figured out how to remove/unclip the top portion of it:
PM ME FOR USED F8x PARTS! What's left: brand-new pair of VNE front brake rotors; used Ferodo DS3.12 and PFC08 front track pads and used Stoptech Sport and OEM rear brake pads; Apex wheel black center caps (brand new, never used) qty 3
MEDIA: @panda_exprs youtube.com/user/EGbeater/videos |
08-18-2022, 10:02 PM | #12 |
IG: @panda_exprs
114
Rep 138
rear seat and trunk floorboard weight savings documentation
Here's the weight savings stuff.
I used a hanging dairy scale to weigh the one-piece rear seat bottom... it's not as accurate as a digital scale, but still good within .15 lb or so. It registered well over 15 1/2 lbs, so I called it 15.5: The rear seat upper portions, I weighed with a digital shipping scale... the "hold" function allows me to see the weight after I removed the seat back from the platform since it obscures the display: T50 star head bolts, 2: 2 oz. Seat bottom: 15.5 lb. Seat back, large drivers side: 16 lb 9.2 oz. Seat back, small pass side: 10 lb 7.8 oz. TOTAL: 42 lb 11 oz. (42.69 lb.) But wait! There's more!! Easy-button removal of the trunk floor board... no tools required. That 7.4 lb additional savings puts us right over the 50-pound mark for weight removal (unfortunately all over the rear axle, not the front, which would help the handling more). Last edited by EGbeater; 08-18-2022 at 10:08 PM.. |
08-18-2022, 10:05 PM | #13 |
IG: @panda_exprs
114
Rep 138
Two pics of the rear seat area with most of the seating cushions removed (note there's still a noise-damping mat under the seat bottom cushion you could easily pull, probably another 12 to 16 ounces there... plus the outer upper seatback sections and seatbelts, likely another 6 or 7 pounds):
