09-05-2014, 05:13 PM | #1 |
1764
Rep 7,650
IND | KW Suspension for Your F8X M3/M4
KW Suspension is a brand name recognized by every fan of European cars, and synonymous with an extremely high level of build quality. What many dont know about KW is that they are not just among the best aftermarket suspension manufacturers, but also one of the most technologically advanced manufacturers around both in the aftermarket and as an original supplier. KW is one of the only suspension suppliers in the world to have an in-house 7 post shaker rig- a piece of equipment rarely seen outside of Formula 1, enabling KW engineers to physically simulate any road course or street in a laboratory environment. KW is an original equipment supplier for BMW on their now legendary M3 GTS and for Mercedes in their AMG applications. KW is also the leading supplier for racing suspensions in nearly every type of motorsport, from Rally to DTM to WTCC, to amateur racing across the US and Europe. This ability to combine KWs road car experience with their years of racing experience enables KW to create dampers that work phenomenally on the street and on the road course. KWs newly released ClubSport suspension for the F8x M3/M4 is a culmination of decades of experience as a racing and original equipment supplier, and will once again bring unsurpassed quality and performance to the M3/M4. Available for purchase through our website or via any IND representative. https://ind-distribution.com/collect...W%20Suspension Email: info@ind-distribution.com Phone: 866-963-4520 (847-963-4520) We also have access to the installation guide- please PM us for additional info. Well be publishing spring rates in this thread shortly!
09-19-2014, 12:29 PM | #2 |
1764
Rep 7,650
The 3-way Clubsport
the three way adjustable ClubSports include external fluid reservoirs, high speed and low speed compression adjustment, and rebound damping adjustment for an extremely effective shock package, while maintaining the composite perches, stainless steel shock housings, and specially designed shielded spherical bearing upper mounts to maintain an OE level service life. Linear rate main springs and front and rear helper springs maintain an ideal shock travel in bump and droop, which is carefully matched to bump stops of the appropriate length. Photo taken from our most recent project. Pertplus M235i
08-24-2018, 05:47 PM | #4 |
BimmerPost Supporting Vendor
9575
Rep 10,869
Goettler_Boost193.00 |
09-15-2023, 04:29 PM | #5 |
9575
Rep 10,869
