proTUNING Freaks
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Wheels | Tires -- Sponsored by The Tire Rack
      09-03-2014, 02:57 AM   #1
MRSSIIM3
MRSSIIM3's Avatar
Drives: M4 SO
Tire Temps Weird
For some reason my front left tire is always hotter by around 10 degrees F than the other 3. Whats going on? Is the left side where the turbos are located or something that produces a lot of heat?
      09-03-2014, 08:35 AM   #2
irablumberg
Drives: 2021 M5 Competition
Same on my M4. I assume this is engine heat.
      09-03-2014, 08:40 AM   #3
Andrew115
Andrew115's Avatar
328
Drives: Silver Bullet
I assume the tire pressure is the same all around?
      09-03-2014, 11:48 AM   #4
irablumberg
Tire pressure on my M4 is identical or within 1 PSI on all 4 tires and reads 33 or 34.
      09-03-2014, 11:58 AM   #5
stevenc
Coming Soon
Drives: 2015 BMW M4 Alphine White MT
I have one tire always hotter than the others as well.
      09-03-2014, 12:08 PM   #6
Andrew115
Andrew115's Avatar
328
This may spell trouble for that front pushing it hard on track days. I wonder if the heat will make that much of a difference in tread wear.
      09-03-2014, 01:18 PM   #7
MRSSIIM3
MRSSIIM3's Avatar
Drives: M4 SO
pressures are the same all around, +- .5 psi depending on how hot they are
      09-03-2014, 11:51 PM   #8
MaynardZed
MaynardZed's Avatar
Drives: wife crazy
My left front got way hot and tight with just 12 minutes of track time. Started 32 psi all around and front left went to 44, rf 40, and both rear 38. I assumed it was because it was a clockwise track but maybe something more to it?
Road course laptimes for BMW M4 2015 6MT
WHP East Track: 1:04.880, Arizona Motorsports Park: 1:54.352
Road course laptimes for Porsche 911 991.1 GTS 7MT
WHP East Track: 1:02.770, Arizona Motorsports Park: 1:48.889
      09-04-2014, 12:03 AM   #9
SakhirM4
SakhirM4's Avatar
Drives: '15 SO M4/'20 Z4 M40i
2020 BMW Z4 M40i  [10.00]
2015 BMW M4  [8.76]
This guy appears to be having the same issue:
http://f80.bimmerpost.com/forums/sho....php?t=1031390
Tejas Chapter, BMW CCA, mem #23915, President 27 years, www.tejaschapter.org
      09-04-2014, 02:50 AM   #10
nasdaq100
nasdaq100's Avatar
France
66
Drives: BMW M4 DKG
same here,
Maybe in UK is on front right
      09-04-2014, 04:42 PM   #11
Maxis
Maxis's Avatar
Denmark
140
Drives: F83
drivers seat
Enjoy
      09-04-2014, 06:27 PM   #12
irablumberg
Originally Posted by Mere View Post
drivers seat
Nope. Same result even with a passenger my size or larger.
      09-04-2014, 06:54 PM   #13
celler
celler's Avatar
14
Drives: F80 M3
I have had this happen in normal street driving, but it was the front right that was 10 degrees hotter and then it normaled back out after a few minutes. Pressures remained constant which probably means a software glitch.
      09-04-2014, 07:57 PM   #14
Racer20
Drives: F80 M3, 228i THP, E46 ZHP
This is fairly common. It happens on many of my development vehicles at work, and it's usually due to the placement of cooling and exhaust system components. On one vehicle I work on, most of the air from the cooling fan exits via the right front wheel well and the wheel/tire/suspension components in that area are typically 20-40deg hotter than on the other side.
My F80 does it too, but I haven't bothered to look under the car to see why.
2015 M3, 2005 330i ZHP, 2015 228i 6MT Track Handling Pack, 2007 M Coupe (Sold)
      09-09-2014, 03:38 AM   #15
YMB_F80
YMB_F80's Avatar
445
Drives: YMB F80 M3
2009 335i  [7.00]
2015 BMW M3  [10.00]
My f80 also has this problem I saw it and was confused as hell!
2015 BMW M3 (Yas Marina Blue)| Toyo Tires | Moton Suspension |
Instagram: YMB_F80
f80post
