09-02-2014, 04:22 PM | #1 |
29
Rep 124
Beware when washing your car...
I found out yesterday that garden hose + key in pocket while rinsing back of car can lead to auto trunk release. Hose fooled sensor into opening trunk. Thank goodness for warning lights...
09-02-2014, 04:31 PM | #2 |
258
Rep 1,309
Drives: YMB M3
Garage List 2016 BMW X6M [0.00]
2018 BMW M3 [0.00] 2015 BMW X4 35i [0.00] 2015 BMW M4 (SOLD) [0.00] 2012 BMW 328i SL(SOLD) [0.00] 2008 BMW 328i (SOLD) [0.00] 2007 C230 Komp (SOLD) [0.00] 1999 BMW 328i (SOLD) [0.00] |
lol this has been an issue since this feature was released.. I have not personally done it but i always leave my keys out of range of the car so it doesnt happen.
09-02-2014, 04:51 PM | #3 |
Large Member
951
Rep 1,749
You should also irrigate the LSD wiper wells as they will just pool up water. The correct side drive wells are irrigated so they don't hold water but the wrong side drive wells that aren't used just pool up with alot of water. Not sure why they didn't put holes in there for us since they aren't being used.
2008 E92 M3 (Engine swap completed), 2015 F82 M4
09-02-2014, 05:10 PM | #4 |
definitivecars.com
352
Rep 3,833
Drives: Elsa - 2015 F80 M3 - YMB/SS
Garage List 2011 E90 M3 [6.66]
2009 (Lease up Sept ... [0.00] 2007 (Lease up 6/19 ... [0.00] 2007 (Lease up Octo ... [0.00] |
Oh and by the way, how do you lift the wipers without scratching the edge of the hood??? I ripped my clearbra during my first wash. So pissed. The e90 didnt have this issue.
D |
09-02-2014, 05:15 PM | #5 |
Resident Engineer
135
Rep 748
I remember hearing that if you press the stalk in a certain pattern, it will stop the blades in the vertical position allowing you to flip them up.
Sadly can't remember the pattern. I vaguely remember the 5 series having a similar feature?
///M4 (SO/BLK/BLK) Exec, LED, Blk 19s, HK, 6MT <- SOLD
///M2 (LBB), Exec, 6MT <- SOLD 2014 Land Cruiser, Slee Sliders, OME Lift, ARB Onboard Air European Delivery Journal & F8X Door Rattle Fix Machine Shop Directory - www.mfgcenter.com |
09-02-2014, 05:26 PM | #6 |
Large Member
951
Rep 1,749
It's covered on the forum somewhere. Just put some time in and search around.
09-02-2014, 05:40 PM | #9 | |
365
Rep 362
This puzzles me as well and I haven't found an answer. I'm driving a 528i loaner right now and it has the same issue |
09-02-2014, 05:56 PM | #11 | |
43
Rep 1,147
Press the wiper stalk up past the resistance point and hold for three seconds so the wipers stop in the center (service position). It's all in the manual. Last edited by SOM3; 09-02-2014 at 06:10 PM.. |
09-02-2014, 06:50 PM | #12 |
65
Rep 503
This likely holds true on DIY oil changes as well, found out the hard way on my 335i w CA that when the key is local, the engine primes itself to start and the oil is under pressure, loosened the drain plug and 50psi hot Mobil 1 everywhere. So awesome.
