GetBMWParts
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Wheels | Tires -- Sponsored by The Tire Rack
      08-31-2014, 10:05 AM   #1
Mandi90TT
Drives: BSM 6MT M4 F82
Spacers and Handling
I like how the M4 looks with some spacers, but have always been told (from previous track experience and from listening to others) that spacers will probably have a negative effect on handling, plus they add in another point on the wheel and hub (even with hub centric spacers) that is a weak point, susceptible to failure.
What's the general consensus on spacers (if there even is one)?
      08-31-2014, 10:19 AM   #2
Racer20
Drives: F80 M3, 228i THP, E46 ZHP
Spacers affect handling a few different ways.
They increase the track width, which generally helps overall grip.
They increase the scrub radius, which increases tire wear and reduces steering feel.
They reduce the effective spring and damper rates because they now have to react against a longer lever arm.
They add another possible point of failure and can increase load on the lug bolts.
These effects will vary in size depending on now big of a spacer you use. The consensus is probably that none of this stuff really matters and that you should do it because HELLAFLUSH YO! This is probably true on the street. For the track, the biggest concerns would be the loss of spring/damping rate and the extra load on the lugs, which can both be mitigated with other modifications.
2015 M3, 2005 330i ZHP, 2015 228i 6MT Track Handling Pack, 2007 M Coupe (Sold)
Appreciate 2
      08-31-2014, 10:31 AM   #3
Mandi90TT
Yeah, your are probaly right about the HELLAFLUSH, YO! thing.
Thanks for the answers.
      08-31-2014, 11:36 AM   #4
khanyam4
Ring Leader of G8X Trolls
khanyam4's Avatar
Cambodia
802
Drives: NA
      08-31-2014, 03:24 PM   #5
Pharmacist_
Straight outta Loca$h
Pharmacist_'s Avatar
Drives: '15 f80 M3 '13 f25 x3 35
Appreciate the thread OP and always appreciate Racer20's thoughts. I did a search on this last week and didn't have enough time to find this exact answer. Figured it would alter OEM setup but this gives good info as to why. Thanks again.
2015 F80 ///M3 (AW/SO|6MT|Exec|LED|HK|M Susp|Black 19s|Cameras)
ED Date: October 13, 2014
PCD Date: December 5, 2014
      08-31-2014, 06:12 PM   #6
6MMMT
Drives: 2015 M3 6MT
Thanks for the post OP. What is consensus on asking the dealer to install spacers, or is this on the "no go" list in case there is any wheel/suspension warranty impact?
      08-31-2014, 07:18 PM   #7
04RC51
Large Member
04RC51's Avatar
951
Drives: E92 M3, F82 M4
Hahahaha, HELLAFLUSH!
2008 E92 M3 (Engine swap completed), 2015 F82 M4
      08-31-2014, 07:25 PM   #8
-JLT-
-JLT-'s Avatar
3420
Drives: '22 X4M COMP, '23 iX xDrive50
HELLAFLUSH YO FTMFW!!!!! Haha
-JLT-
      08-31-2014, 10:13 PM   #9
Mandi90TT
Not sure what the dealer would say, but any competent wheel and tire shop can install spacers in as quick as it takes to rotate the tires. In other words, wheels come off, spacers go on (takes less than a minute per spacer), wheels go back on.
Easy peasy.
      09-01-2014, 12:34 AM   #10
MaynardZed
MaynardZed's Avatar
Drives: wife crazy
Some dealers won't touch a car with spacers. Any track car shop has no problem with them though. There's probably as many guys running spacers as not in my track club. Never seen a catastrophic fail because of them. I tracked my M4 today with 12 and 15mm spacers, never worried a bit. I would torque your lug bolts carefully which you should be doing anyway.
Road course laptimes for BMW M4 2015 6MT
WHP East Track: 1:04.880, Arizona Motorsports Park: 1:54.352
Road course laptimes for Porsche 911 991.1 GTS 7MT
WHP East Track: 1:02.770, Arizona Motorsports Park: 1:48.889
      09-18-2014, 10:25 PM   #11
txgrown
txgrown's Avatar
Drives: 2015 F80
Hellacious hoy
I have been researching and wandering what spacer width (front and rear) that will give that HELLAFLUSHYO look?
TXgrown
2018 x5 50i
      09-19-2014, 11:55 AM   #12
M4NACE
M4NACE's Avatar
28
Drives: F82 M4
15mm front and 12 or 15mm rear.
I'm going 15/12 combo because i planning on lowering the car. you can go 15/15 and shouldn't be any issues.
      09-19-2014, 12:01 PM   #13
-JLT-
-JLT-'s Avatar
3420
i'm running 20mm/18mm and lowered on 435 H&R Sport Springs with no rubbing on my M3
-JLT-
      09-19-2014, 12:09 PM   #14
dmk08
Gone Fishin’
dmk08's Avatar
Drives: Walks
20mm? Holy crap how much do you feel those lol. I could feel 12s like a mofo.
      09-19-2014, 01:58 PM   #15
-JLT-
-JLT-'s Avatar
3420
not a big difference to tell u the truth. HELLAFLUSH YO!!!! haha
-JLT-
      09-23-2014, 11:46 PM   #16
FSHNGRY
FSHNGRY's Avatar
Drives: INDIVIDUAL F90 M5C LCI
As far as day to day driving (no tracking) have you noticed any rubbing/negative affect at all?
CURRENT: '21 M5| FSHNGRY | TARTUFO | CCB | MPE | KW | IND | EVENTURI | EISENMANN | DINAN | LOADED |
GONE: '15 F82 M4 | YMB | IND | MPERF | KW | BM3 | LOADED
GONE: '11 E92 335IS | BLKSPHR | OYSTER | LOADED
GONE: '05 E46 ZHP | LOADED | DINAN STG3 PKG |
IG: @FSHNGRY
      09-24-2014, 01:34 PM   #17
-JLT-
-JLT-'s Avatar
3420
none whatsoever
-JLT-
      09-24-2014, 02:43 PM   #18
dmk08
Gone Fishin’
dmk08's Avatar
Drives: Walks
It does look damn good lol. #HFY :P
      01-08-2015, 02:09 PM   #19
CSanto
634
Drives: 2015 BSM/SO M3
You felt handling negatively impacted by the spacers?
dbonds0.00
      01-08-2015, 05:30 PM   #20
socalsnake
23
Drives: '15 M4, '15 X5 - both AW/BLK
Also have 15mm front, 12 mm rear Macht Schnell spacers from EAS. I've heard good things about Turner Motorsports spacers.
I personally don't feel a difference in the steering feel of the car, but I'm a street only driver. As far as dampening, I've lowered the car with KW HAS so I can't comment on spacer effect on stock dampening.
If you head over to EAS's (European Auto Source) thread, http://f80.bimmerpost.com/forums/sho....php?t=1017256, there are many of us with spacers, lowered and unlowered. I'm sure any of these guys will share their experiences with spacers.
      01-09-2015, 05:52 PM   #21
IE92
Drives: 2015 F80 M3
I have 18mm front and 15mm rear Macht Schnell spacers on my F80. I've had spacers on several of my cars and have tracked all of them with no issues whatsoever. For those of you that are concerned with the potential negative effects that spacers will have on handling, consider this... Porsche offers spacers as a factory installed option on many of their models, including the 911. I'm confident that Porsche engineers know what they're doing, and they wouldn't offer spacers if they had any cause for concern.
      01-11-2015, 06:52 AM   #22
Maxis
Maxis's Avatar
Denmark
140
Drives: F83
Enjoy
Search this Thread:
Advanced Search
f80post
