2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics Wheels and Tires -- Sponsored by The Tire Rack 19x8.5 et45 VMR v810 square setup installed on xdrive m235i
      08-28-2014, 08:57 AM   #1
RiXst3r
RiXst3r's Avatar
273
Drives: M235i
Hey guys,
Wanted to share the details on my wheels and tires setup.
My car is a 2015 M235i with Xdrive which comes with 18x7.5 and 225/40/R18 all around the entire car.
I purchased several spacers ahead of time so that I could tweak the level of "flush" to the fenders, as well as make sure the front rims would clear the strut side. The 19x8.5 ET45 VMR v810 needs a spacer in the front to fit, I ended up with 5mm spacers on the front (effectively ET40 front) and 3mm spacers on the rear(for looks), effectively making the rears ET42.
Because the car is xDrive, I wanted to install a completely square setup, just like the stock wheels, but with more width and more rubber. I did not want to mess too much with the neutrality of the car, or cause a bunch more under-steer by going with a staggered setup.
I decided to give 235/35/R19 tires all around a try, and it fits great, and from what I can tell from measuring, the tire is tucked/stretched just enough that I can also lower the car without rubbing. I've also loaded the car up with as much weight as possible and done plenty of "try and make it rub" tests, with zero rubbing. I know people are running ET40 19x8.5 in the front with 225/35/R19 totally SLAMMED to the ground on KW suspension, so I should be good with a modest drop, as I wanted a bit more tire up front so I went with 235. So far so good...
Below attached to this post are the photos... The 5mm front and 3mm rear spaces give me the flush look that i was going for.
      08-28-2014, 11:59 AM   #2
GeoBem007
Belgium
28
Drives: F21 M135i
Stock setup is not square on a xDrive. It's the same as the regular M235i. (F7.5/R8.0")
Do be aware that xDrive is very sensitive to changes on the wheels/tyres/total diameter.
Anyway, those new Vorsteiner wheels do look very good!
      08-28-2014, 12:01 PM   #3
ska///235i
***** noob
ska///235i's Avatar
Drives: 325xi>M235i>428GCx Mspor
2006 325xi  [0.00]
So the xdrive has the adaptive susp too?
2006 325xi (Sold)
2014 M235I (Current)
2015 428xi Gran Coupe (STB)
      08-28-2014, 12:35 PM   #4
HX_Guy
119
Drives: 2014 BMW M235i
Looks great, nice choice.
2014 BMW M235i 6MT
2012 Mercedes E350 Bluetec
      08-28-2014, 01:45 PM   #5
RiXst3r
RiXst3r's Avatar
273
Drives: M235i
Yes, I am told that the suspension is exactly the same. It feels the same compared to the RWD I drove, and the ride height appears to be the same as well when I compared the two.
      08-28-2014, 01:49 PM   #6
RiXst3r
RiXst3r's Avatar
273
Drives: M235i
Actually, it DOES come with a square setup. in the USA.
Double Spoke light alloy wheels (Style 436M), 18 x 7.5; and 225/40 run-flat all-season tires on all 4 wheels.
      08-28-2014, 02:54 PM   #7
ska///235i
***** noob
ska///235i's Avatar
2006 325xi  [0.00]
That is awesome news...the E9x xdrive was crap
2006 325xi (Sold)
      08-28-2014, 05:08 PM   #8
VMRWheels
VMRWheels's Avatar
2038
Drives: BMW
2013 BMW M3  [10.00]
2015 BMW M4  [0.00]
2013 BMW F30  [0.00]
2014 BMW F22  [0.00]
2013 BMW F06  [0.00]
Looking good!
Loving the look of the V810 on the 2-series
      08-28-2014, 05:20 PM   #9
abirmaher
abirmaher's Avatar
Drives: 2018 BMW M2 & 2024 BMW X1 M35i
  [0.00]
2018 BMW M2  [10.00]
OP can you post photos from front and year from down low so we can see how much the wheels stick out or don't, just to see how they sit.
Also I am running H&R sport springs on my M235i, rides the same and looks tons better, just about an inch drop all the way around.
Follow my builds:
The Racecar (2018 M2 - M0010): Build Thread | @_m0010
The Daily (2024 X1 M35i - X001M35):Build Thread | @_x001m35
      08-28-2014, 06:57 PM   #10
escobar929
escobar929's Avatar
154
Drives: M2 CS
2020 M2 CS  [10.00]
2020 M240i  [0.00]
Love the look, those are the same wheels I plan on getting only in a 9.5 in the rear
      08-28-2014, 07:12 PM   #11
RiXst3r
RiXst3r's Avatar
273
Drives: M235i
Sure, I can try and get some more photos...
I plat to run the H&R sport springs as well... it needs the drop!
      08-28-2014, 09:31 PM   #12
abirmaher
abirmaher's Avatar
  [0.00]
2018 BMW M2  [10.00]
It does and they're great IMO.
Follow my builds:
      08-30-2014, 05:27 AM   #13
GeoBem007
Belgium
28
Drives: F21 M135i
LOL. Sorry! Strange call though. It's still 7.5/8 in the rest of the world.
      08-30-2014, 06:02 AM   #14
daisy16905
10
Drives: 2014 M235i
What is your drop front and rear??
M235i (Black) Auto, JB 4 (Stage 2 / Map 7 with EWG & FF wires) ER DP, resonator delete, running E35, BMW Performance LSD, Hankook Ventus R-S3's (255/35/18 & 235/40/18) ATE Super Blue Racing brake fluid, 35% tint, black grills!
      08-31-2014, 07:11 AM   #15
RiXst3r
RiXst3r's Avatar
273
Drives: M235i
I have no drop, I am on stock M adaptive suspension, xdrive.
2addicts
