08-27-2014, 03:47 PM | #1 |
119
Rep 623
And the shoes fit!!
Finally found a wheel that I really love! Was looking for something with decent concave and it seemed nothing was available for the M235, ended up stumbling across the Breyton GTS-R which have specific sizes for the 1 Series and fell in love!
They look so good in person, have more concave then I expected and are very light. I did have to use a spacer on the front to clear the brakes but would have anyway for a more aggressive offset. Wheels are 18x7.5 ET45 front and 18x8.5 ET48 rear, perfect in my opinion (poke out 12mm in front and 10.7mm in rear compared to stock wheels). Now I have to wait till Friday to get the other two since I only ordered 2 to test fit, damn! Front Rear I'm going to paint the red stripe a matte grey to match the wheel as I've seen others do because unfortunately the wheel was not available without the stripe. Rear has plenty of clearance at the brake caliper and at the rear shock, could easily fit some pretty fat tires back there (measured 26.48mm between rim and shock dust cover) Front needed a 12mm spacer but then cleared the brakes easily (by 6.26mm, stock is 5.25mm) and the front strut has plenty of space. The red stripe is actually in a recessed channel so should be pretty easy to paint clean.
2014 BMW M235i 6MT
2012 Mercedes E350 Bluetec Last edited by HX_Guy; 08-27-2014 at 03:57 PM.. |
08-27-2014, 04:07 PM | #2 |
4516
Rep 8,942
Dig the look, will those take a BMW center cap? One idea on the red, you may have a tough time matching the wheel finish. Could try this if you are thinking about different colors before you go ahead and do it.
http://www.bimmian.com/Mechunik-Colo...r-F45-2-Series |
08-27-2014, 04:13 PM | #3 |
119
Rep 623
They will take a BMW center cap which is what I'm going to use.
That's an idea for the strip but I don't know how much it would stick out. I'm hoping to find a flat enamel that will be close enough, a slight different probably won't be noticeable, especially given the wheels have some degree of brake dust on them all the time.
2014 BMW M235i 6MT
2012 Mercedes E350 Bluetec |
08-27-2014, 04:44 PM | #4 | |
4516
Rep 8,942
2022 Macan S
2016 F31 328i xDrive Sport Wagon 2006 E46 330ci ZHP Convertible |
08-27-2014, 04:51 PM | #5 |
119
Rep 623
The red looks suprisingly good actually and goes well with the Mineral Grey paint, but I don't like things that look aftermarket on my cars, I prefer OEM or OEM-look...the stripe makes them look aftermarket and a bit juvenile too I think.
2014 BMW M235i 6MT
08-27-2014, 05:04 PM | #6 | |
4516
Rep 8,942
2022 Macan S
08-27-2014, 05:12 PM | #7 |
Rep 26
You could try a color that is just a little off the wheel color, but not too much. I'd be curious how a black stripe might look. I've seen some MG M235i's that are all decked out in grey and black with medium tint that look amazing. The black wouldn't contrast too much with the wheel, subtle.
I agree that the red does a have a bit of a boy-racer look, which sounds like it is not what you are after. Just a thought. |
08-27-2014, 05:18 PM | #8 |
119
Rep 623
That's actually what someone over on the 1 Series forum did...didn't have a very steady hand though.
2014 BMW M235i 6MT
08-27-2014, 05:21 PM | #9 |
154
Rep 4,528
Drives: M2 CS
Awesome, congrats. I figured they would fit
I don't like the red stripe either, other than that, it's a sweet looking wheel The black does look much better though, just find someone with a steady hand lol |
08-27-2014, 05:23 PM | #10 |
Rep 26
I realize looks is a personal thing, but I do like the look.
If you did go that route, I'm sure you could get a cleaner implementation. Maybe ala BEM suggestion there is a "tape" option, not unlike the appliques Bimman sells for the front grille, that could be applied down in the groove. Alternatively perhaps some kind of tip could be crafted that fits the groove so color could be added more deliberately. |
08-27-2014, 05:25 PM | #11 |
***** noob
1368
Rep 10,479
Drives: 325xi>M235i>428GCx Mspor
Those will look good
2006 325xi (Sold)
2014 M235I (Current) 2015 428xi Gran Coupe (STB) |
08-27-2014, 05:29 PM | #12 |
119
Rep 623
I'm thinking something like this is hopefully close enough, it has to be a non-shiny, non-metallic paint otherwise I think it would stand out against the matte finish of the wheels.
http://shop.hobbylobby.com/products/...-paint-356220/ I'm thinking they should also have some sort of foam applicator or something that's a close match to the size of the grove at Hobby Lobby or Michael's.
2014 BMW M235i 6MT
08-27-2014, 05:35 PM | #13 | |
***** noob
1368
Rep 10,479
2006 325xi (Sold)
08-27-2014, 05:39 PM | #14 |
119
Rep 623
The whole wheel? Not a big fan of black wheels, which sucks, because TireRack sells this wheel in a black finish without the stripe.
As for plastidipping just the groove, that would probably be really really hard.
2014 BMW M235i 6MT
08-27-2014, 06:59 PM | #15 | |
4516
Rep 8,942
2022 Macan S
08-28-2014, 01:08 AM | #16 |
119
Rep 623
Bam! There is it. Picked up some flat gray and gunmetal enamel (mixed the two as the gray was too light and the gunmetal too dark) at Hobby Lobby and a round tip extra stiff paint brush and went to work. Did a couple of coats and came out good, depending on the lighting, sometimes it's more noticeable than other but looks a ton better than the red stripe to me.
2014 BMW M235i 6MT
08-28-2014, 05:33 AM | #17 |
154
Rep 4,528
Drives: M2 CS
Looks good, way better than the red
08-28-2014, 06:49 AM | #18 |
Rep 26
08-28-2014, 07:26 AM | #19 |
4516
Rep 8,942
Yeah looks great, you def made the right call on the paint. Good luck waiting for the other two with those staring at you begging to be mounted
2022 Macan S
08-28-2014, 09:21 AM | #20 |
22
Rep 82
That is one hell of a good looking garage!
08-28-2014, 12:05 PM | #21 |
154
Rep 4,528
Drives: M2 CS
