F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > DIY - Led Fog (F32 to F30) Install Only!!
GetBMWParts
      08-24-2014, 11:34 AM   #1
crapSOOT
crapSOOT's Avatar
Drives: 335D 2011, 328xD 2014
Hello all, I have read through the posts regarding install and coding for LED fog light, but I missed the install DIY, I did this over this weekend and wanted to share.......these are F32 lights, I am putting on my F30, I tried to find some specifically for F30 with no luck.
YES, I know my car is dirty.....
On the scale of 1-10 (10 being don't do it) this is a 3-4 only because of me removing the wheels.
parts:
Fog Lights
63 17 7 315 559
63 17 7 315 560
Tools;
T25 torx driver
I decided to remove my front wheels to take photos and have better access...
Just the new light with part #
Here you see the wheel has been removed and shows the small bolts to be removed to gain access. The arrow shows the location of one more bolt out of the picture frame.
You are doing this to move the fender liner out of the way.
This shows the location of the two screws(T25) holding the light in place, remove them, then disconnect the wire harness.
the following just shows the difference between the lights
Plug wiring harness in the new light, install, and secure with the two screws and put car back together. The passenger side is the same no unexpected surprises other than a dead bug or two.
I suppose you could do this without removing the wheels, by just taking off the grill in front of the fog lights(it just pulls off), and using a mirror to visualize the two mounting screws, it just needs a little more patience.
Final result.....
.....sit back and enjoy your hard work. Don't forget to code, there are so many threads for coding it did not make any sense to add my coding to this post.
You are doing this on your own, use my post only as a guide, your car may be different.....GOOD LUCK
Appreciate 5
      08-24-2014, 12:17 PM   #2
Professor///M
Professor///M's Avatar
819
Drives: 2022 M3, 2022 X5 40i;
Great job. I was hoping this was to add to an M Sport, but strong work nonetheless
      08-26-2014, 12:02 PM   #3
Dante
Enthusiast
Dante's Avatar
Germany
468
Drives: F87 M2 / F31 330d
Thanks for the DIY!
I did that mod in February.
This also works with the wheel mounted. Just go full lock to the left when doing the driver side (other side vice versa).
With the wheel in place, you can tug the fender liner behind the wheel, just like you did with the brake disc.
When putting the new LED fog in place, I found it useful to pull up on the mount. It might not slip into place easily (it didn't with my M-Sport bumper, there was a gap), but when you pull up from the inside, the fog will find its way.
This looks so much better than the yellow fogs. Plus, the cornering lights still work with the LED, which is a bonus.
Just code everything to 100%, otherwise they will start to flicker after a few seconds!
Appreciate 2
Oksamit78280.50
      09-04-2014, 08:54 AM   #4
Tim@codemybimmer
BimmerPost Supporting Vendor
Tim@codemybimmer's Avatar
569
Drives: 2022 X4 M Competition F98 LCI
Hey guys,
I'm thinking about ordering the fogs, however I just wanted to check that you guys did the same coding as this guy
http://f30.bimmerpost.com/forums/sho...5&postcount=45
Please let me know if different. The reason I ask is because there seems to be so many different variances of the coding, it would be helpful if we had just one set of coding we should go by to avoid flickering.
      09-06-2014, 09:04 AM   #5
crapSOOT
crapSOOT's Avatar
That is the coding I used, not sure if I followed that exact one....like you said there are so many threads with the same/similar coding, which is a good thing because at least a lot of users want to post/help others on here.....
      09-06-2014, 09:39 AM   #6
IndotagSwizz
IndotagSwizz's Avatar
525
Drives: F30 320i
parts:
Fog Lights
63 17 7 315 559
63 17 7 315 560
Tools;
T25 torx driver
Yes I know the new light looks bigger in the photo, it is but not by much, there is more than enough room in the area.
Final result.....
thanks for your work I was wondering where did you order the fogs from and how much did they cost? thinking of doing this
      09-06-2014, 03:55 PM   #7
Tim@codemybimmer
569
Well, fingers crossed... about 2 weeks till my Fog Lights arrive! My dealer said they can install the lights as a favor no problem, so means all I have to do on my end is code as usual. I just hope that coding doesn't disable the cornering function as some people reported.
Question - Does the lights fade on and off or is it hard on and off? Also how's the lighting output compared to the stock halogen fogs?
I ordered a set from ECS Tuning, they're $140~ each, so $280 for the set + shipping.
      09-07-2014, 10:47 AM   #8
Dante
Enthusiast
Dante's Avatar
Germany
468
The cornering function works for me.
The lights still fade on and off, but fading is not as 'soft' as with the halogen fogs.
Lighting is better than halogen, much wider although not further.
      09-07-2014, 02:11 PM   #9
F30 Epal
Drives: F30 320i
Can you please post the link? I've been searching their site and can't seem to find it.
My Instagram
Alpine White '14 BMW 320i 6-Speed MT: GSR Tuned, H&R Sport Springs, Injen CAI, Borla catback exhaust, ER FMIC/Chargepipe/Downpipe, VMR V810 wheels
      09-07-2014, 04:17 PM   #10
crapSOOT
crapSOOT's Avatar
Not sure what link you wanted....I guessed to the lights, here you are
hope this does not violate any posting rules, if so mods please delete, thank you
http://www.ecstuning.com/Search/SiteSearch/63177315559/
http://www.ecstuning.com/Search/SiteSearch/63177315560/
      09-07-2014, 07:40 PM   #11
Cesarb
Drives: 328d xdrive
Will this work on a 328D drive with normal halogen lights?
      09-07-2014, 08:53 PM   #12
F30 Epal
Drives: F30 320i
Nice, thanks very much!
My Instagram
      09-08-2014, 11:46 AM   #13
radair
radair's Avatar
21
Drives: G26 i4 M50
Hi all,
Can someone who is having a F32 tell me what values the following parameters have:
MAPPING_NEBELSCHW_L_PWM_LEVEL_1
MAPPING_ABBIEGEL_L_PWM_LEVEL_1
I'm asking because I was told that I have to code 100%
The problem is that I don't have 100% available in the drop down menue, so I need to know the HEX value that is coded in the factory, or better, the Voltage that has to be set for the LED fogs.
According to the coding range (see screenshot) 100% = 14V = 8C hex
According to a Friend (with a F30), who has 100% in the drop down menue the hex value is 64 when he chooses 100 % . This corresponds to 10V according to the coding range.
Attached you can find a screenshot of my parameters.
I'm scared that I' using a too high voltage to operate the fog lights.
I'm really confused now and the only thing that might bring light into this is the value set in a F32 (that has the LED fog lights as default).
I hope somebody can help me in this regard.
Many thanks in advance.
Greetings Roland
      09-08-2014, 11:48 AM   #14
radair
radair's Avatar
21
Drives: G26 i4 M50
Screenshot 2
      09-08-2014, 08:19 PM   #15
Tim@codemybimmer
569
Originally Posted by radair View Post
Screenshot 2
Change the werte value to 100. As mentioned in some other threads, it is currently sitting at 86.
      09-09-2014, 03:01 AM   #16
radair
radair's Avatar
21
Drives: G26 i4 M50
Now I'm really confused.
86h means 13,4V. According to the Coding rules this is 95,7%
Can anybody have a look into the settings of a F32 please? Many Thanks.
Greetings
Roland
      09-13-2014, 10:25 AM   #17
Fluffy bastard
Fluffy bastard's Avatar
Russian Federation
9
Drives: Pony
Hi all,
Greetings Roland
You don't need to change voltage to have LED fog lights working correctly.
Fluffy Russian СaT
      09-16-2014, 03:14 AM   #18
radair
radair's Avatar
21
Drives: G26 i4 M50
Hi all,
Can anybody who is having a F32 tell me which values the following parameters have:
It would be great to get a screen shot where the hex value and the coding range can be seen (see jpg attached).
I'm asking because I coded 100% = 14V (according to the coding range) and now the LED fog lights are flickering after 30 seconds. It seems that 14 volts are too high.
Greetings Roland
      09-16-2014, 05:57 AM   #19
Basya
Russian Federation
Drives: F31 Touring 320d
And what we need to do?
      09-21-2014, 11:33 AM   #20
Tim@codemybimmer
569
You do realize that the werte value is independent of the voltage the light gets right?
*read post 22*
      09-21-2014, 11:54 AM   #21
radair
radair's Avatar
21
Drives: G26 i4 M50
Sorry, but that's simply not correct! The HEX Value is NOT the percentage value! (coding range is 0-100% and 0-14V)
Do the math:
86hex = 134dec = 13,4V
Please, just post something if you are really sure about it.
Many thanks!
Radair
      09-21-2014, 02:35 PM   #22
Tim@codemybimmer
569
Do the math:
Many thanks!
Radair
Sorry bout that, was actually going to look into it.
WELL I CAME TO A DIFFERENT CONCLUSION THOUGH!
I get an option for 100% in my dropdown list... which = hex 64 as always.
I'll post a screen once I upload it from my laptop.
EDIT - here we go.
Appreciate 2
f30post
