European Auto Source (EAS)
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Wheels | Tires -- Sponsored by The Tire Rack
      08-20-2014, 03:51 PM   #1
tonymac1
tonymac1's Avatar
Drives: 2021 X5 40i, 2011 E90 M3
Tire fitment and size question
Hi , I just got my HREs installed on the car and compared to the OEM 19s wheels, the tires seem much stretched in the rear..
Does this look like the rear wheels should be paired with wider tires??I used to run 295 in the rear on E92, it worked fine, guess i should also go 295 for the M4 too ?
Here's the front , the tire fits fine with a flatter sidewall
[IMG][/IMG]
However, the rear tire seems much more stretched than it was on stock wheels.
[IMG][/IMG]
      08-20-2014, 04:06 PM   #2
richb811
richb811's Avatar
450
Drives: 2020 G20 330i M Sport
What are the widths of the HRE's on the rear?
      08-20-2014, 04:08 PM   #3
tonymac1
tonymac1's Avatar
Not very sure but i think it's 10.5""? I used to put it on my e92 and used 295 in the rear with no rubbing. However, i talked to a tirerack guy and they said 295/35/19 will probably have a rubbing issue...
      08-21-2014, 11:15 AM   #4
richb811
richb811's Avatar
450
The offsets on the E9x M3 Rears are a bit lower than the F8x. By default your HRE's would have a lower rear offset than a set they'd configure for the new M3/M4
For reference :
E9x ZCP 19" Wheels (Competition)
Front : 19x9 ET31
Rear : 19x10 ET25
F8x 19" Wheels :
Front : 19x9 ET29
Rear : 19x10 ET40
As your TireRack fellow said, you might not be able to go wider without rubbing. The more aggressive (Lower) offset on the E9x rears push those wheels out and if you bottom out your suspension, it might take half your fender with it if your tire is too wide.
See if you can find your build sheet from your HRE order, and let me know the offset. I should be able to offer some more helpful advice then
      08-21-2014, 12:21 PM   #5
tonymac1
tonymac1's Avatar
For reference :
Front : 19x9 ET31
Rear : 19x10 ET25
F8x 19" Wheels :
Front : 19x9 ET29
Rear : 19x10 ET40
thanks for the reply! I will ask HRE about it and get back to you
2021 G05 X5 40i-Phytonic Blue
Search this Thread:
Advanced Search
f80post
