2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics Wheels and Tires -- Sponsored by The Tire Rack Need help finding tires (winter), oe fitments
      08-19-2014, 08:24 PM   #1
ska///235i
***** noob
ska///235i's Avatar
Drives: 325xi>M235i>428GCx Mspor
2006 325xi  [0.00]
So I decided to use the stock m235i rims and will put winter tires on them.
Other than the stock F 225/40/18 & R 245/35/18..can I run 225/40 on all 4 wheels
Thx
2006 325xi (Sold)
2014 M235I (Current)
2015 428xi Gran Coupe (STB)
      08-19-2014, 10:04 PM   #2
MikeG12
Drives: 2020 X3M40, 2000 Z3M, 2017 X1
Yes, 225's are OK on up to 9" wide wheels according to the Tire rack spec page. The 235 wheels are 8" wide rears. That's exactly what I am going to do. In fact, I have a set of 8.5" wheels from a 135 that I'm going to use.
      08-19-2014, 10:10 PM   #3
ska///235i
***** noob
ska///235i's Avatar
2006 325xi  [0.00]
So F 225/40 and R 225/35?
Can I also go up on tire profile...front to 45 and rear to 40 or thats a no no
2006 325xi (Sold)
      08-20-2014, 08:00 AM   #4
Bee Pee
Bee Pee's Avatar
United Kingdom
1762
Drives: AW M2 DCT
I have 225/40/18 both front and rear on staggered oem set of alloys - no problem.
Fettled M135i EB AT then AW M2 DCT - both gone but not forgotten:
Current '22 X3M LCI..
      08-20-2014, 10:29 AM   #5
Revartr
Revartr's Avatar
Drives: 2015 BMW M4
If you're going to be running the same widths front and rear, it would actually be best to run the same profile as well, especially considering the rear tire will have to stretch a tad more (not much) to go over a wider wheel (8", compared to the 7.5" fronts). So a 225/40 setup front and rear. I'm not sure on how well a 45 profile wheel would work with the fender-space on the F22, but you could always run a 17" wheel with the 225/45 size, if you're worried.
      08-20-2014, 10:47 AM   #6
five3three
163
Drives: m2c
For comparison purposes, the E90 wheels that were stock on my sport package 335i were 8" in the front and came with 225/40 and they weren't stretched at all. So it definitely won't have the stretched look on 8 inches. At 8.5" is where it started to really be obvious there was stretching.
      08-20-2014, 11:09 AM   #7
Revartr
Revartr's Avatar
Drives: 2015 BMW M4
No, no, no, that's not what I'm insinuating at all, haha. I'm not talking about how it looks or saying that it will have a "stretched look". All tires stretch to fit the wheel. All I'm saying is that the 225 will have to stretch more to fit over the 8" wide wheel in the rear than it will to fit over the 7.5" wide wheel in the front. So him keeping the 35 profile for the rears is actually worse than going with a square 40 profile all around, if he's going with a square 225 setup all around.
And for the record, my '08 350z came stock with 225/45 tires on 18x8 fronts and 245/45 tires on 18x8.5 rears.
      08-20-2014, 11:13 AM   #8
five3three
163
Drives: m2c
Agreed on all points
I'm likely to do 225/40 square for winter. I'm tempted to just do the stock 245/35 in rears but that size is tough to find and the only one I see out there is a Pirelli run-flat.
      08-20-2014, 11:35 AM   #9
ska///235i
***** noob
ska///235i's Avatar
2006 325xi  [0.00]
225/40 all around it is...thanks all
2006 325xi (Sold)
      08-20-2014, 12:27 PM   #10
Revartr
Revartr's Avatar
Drives: 2015 BMW M4
@five3three Same here. I'm contemplating doing 225/40 and 245/35 or 245/40 in the rear for winter. But I think I'll probably go with 225/40 in the long run. Make things easier. Plus, it's just two months out of the year, haha.
@ska///235i No problem!
      08-20-2014, 06:54 PM   #11
MikeG12
245/35 has the same outer diameter as 225/40, so use the 225/40 all around. A 225/35 will be smaller in diameter than a 245/35.
Search this Thread:
Advanced Search
2addicts
