08-19-2014, 10:18 AM | #1 |
INSTAGRAM: @yaasplease
166
Rep 1,023
Interesting Observation on Engine Operating Temp. in Sport vs. Sport+
When in Efficiency or Sports mode for the throttle response, the engine coolant operating temp is maintained between 105 and 110C. However, if you switch over to sports plus mode, the engine coolant temp is dropped down to between 80 and 85C!
Great way to test it. When parked and idling after the car is warmed up, switch over the sports plus mode. The radiator fan will turn on immediately and lower the temp of the coolant. And if you switch back to efficiency or sports mode again, the fan will turn off immediately. Hmm... Should we run at Sports Plus all the time then to keep the engine nice and cool?
2015 ///M4: M/Vorsteiner Aero, P3Cars, HRE R101, Dinan S2, Coils & Intake; Eis/Akra Exhaust
2013 WRX Hatchback: LED Conversion, Blacked Out, Rally Armor 2015 Macan Turbo: Techart Exhaust, Cargraphics Lowering Module, Blacked Out |
08-19-2014, 10:21 AM | #2 |
1795
Rep 2,997
Good info.
Running an engine too cool is not good for it. You will get more carbon build-up, for example, on a cold engine and it will run richer than desired. There is an optimum operating temp. HOWEVER, coolant temps are a poor proxy for engine temps. For that, oil temps are a much better indicator. If oil temps drop 20 degrees celcius, I'd be more concerned. You want your oil sticking at a certain minimum operating temp. |
08-19-2014, 10:28 AM | #3 |
Slow Mo
15
Rep 534
So I've noticed that the E9x cars had oil temperature indicator while the F8x have coolant temperature indicator.
On my E90 335i N54, I have the BMW performance steering wheel so I could see both oil and coolant temperatures. - I would see coolant temps sit at 210F when I was just cruising but when I was pushing it hard, it would automatically drop to 190-200F. - Oil temperature was maintained at 230-240F. This might be the same cooling logic in the F8x and is no different than at least my N54 though it is quite nice to be able to kick the cooling system in higher efficiency with sports plus instead of it doing it automatically.
BMW '17 X5 35i, '15 M4, ED 7/1/14, US 8/4/14, PU 8/18/14, '13 X5 35i, '08 335i
Motorcycles: BMW '12 R1200GS, '10 F800GS, '74 R90S |
08-19-2014, 10:29 AM | #4 |
18
Rep 82
Engines are more efficient (to a degree) at higher operating temperatures. So the higher temps will get you better gas mileage at cruising speed without hurting the engine. When in stop and go traffic the system is supposed to lower the coolant temperatures and keep the engine cooler. This is one of the benefits of electric fans and water pumps. The ECU can monitor a bunch of parameters and adjust accordingly.
08-19-2014, 10:36 AM | #5 | |
293
Rep 1,514
Drives: Ever changing fleet
23 iX M60, 24 GT3 RS Weissach, 22 Rivian R1T, 23 RS3, 13 E92 M3 Competition: Akra Evo, KW V3, etc
08-20-2014, 06:16 AM | #6 |
560
Rep 570
Re:
The temp indicator in your gauge cluster is oil temperature - just as in the E90.
I'll have to check this out. I'm wondering if the sport plus mode is designed to offer additional cooling when on-track or driving hard. Also, as mentioned, cars are more efficient when hot...but I'd imagine in every mode the car ends up at the same operating temp once fully up to temperature. I hadn't even noticed! Nice pick-up. -Brian S. |
08-20-2014, 09:56 AM | #7 | |
166
Rep 1,023
I was using the coolant temp reading from my P3Car gauge. So the temp I am referencing is definitely coolant temp.
08-20-2014, 10:15 AM | #8 |
21117
Rep 20,741
Drives: 2021 911 turbo
Oil temp is displayed in the cluster. See pic below
08-20-2014, 10:19 AM | #9 |
Resident Engineer
135
Rep 748
The dash cluster is an oil temp gauge.
///M4 (SO/BLK/BLK) Exec, LED, Blk 19s, HK, 6MT <- SOLD
///M2 (LBB), Exec, 6MT <- SOLD 2014 Land Cruiser, Slee Sliders, OME Lift, ARB Onboard Air European Delivery Journal & F8X Door Rattle Fix Machine Shop Directory - www.mfgcenter.com |
08-20-2014, 10:20 AM | #10 |
21117
Rep 20,741
Interesting find OP. I will definitely check this out the next time I take the car out.
My understanding is that a hotter engine run more efficiently from a fuel burn perspective, hence better fuel economy. However, a cooler engine is able to produce more power. The BMW logic makes perfect sense in this respect. Could this also be another reason the S55 shows more power on dynos that what is expected from the official rating? |
08-20-2014, 09:45 PM | #11 |
205
Rep 7,298
we need track temps ppl. nobody cares how its doing on the street. it wont ever affect anything.
canaut please let us know when you get back from an event! |
SYT_Shadow11479.50 |
08-21-2014, 04:43 AM | #12 |
143
Rep 320
Sounds like the car has a dual phase ecu controlled thermostat, as do many other current BMW / minis.
The higher temperature is optimal for emissions and economy, the lower temperature is more optimised for performance. If it works like other models, then regardless of what mode you are in if you drive aggressively, eg multiple full throttle accelerations, then the lower temp 85c mode will activate anyway. Last edited by robbo mcs; 08-21-2014 at 04:49 AM.. |
08-25-2014, 10:55 AM | #13 |
166
Rep 1,023
Spent 1 hour on the track yesterday. Basically, I got off because I ran out of gas. In sport plus mode, coolant temp never exceeded 85C. This was a short track too. So I was in 2nd or 3rd gear all the time, redlining constantly.
08-25-2014, 11:22 AM | #14 | |
205
Rep 7,298
oh, and, VIDEOS!! Last edited by pkimM3r; 08-25-2014 at 11:28 AM.. |
08-29-2014, 12:25 PM | #15 |
220
Rep 433
I agree that this is great news and it makes total sense to me. Thank you for the information.
06-28-2015, 03:15 AM | #16 |
4582
Rep 2,203
Drives: G81 M3 Touring (Frozen Black)
Amazing engine temp differences between Sport and Sport Plus throttle modes
I made a discovery today that i hadn't previously realized. I normally drive in Sport throttle and Sport Plus Steering. Well I decided to spend some time in Sport Plus throttle. The thing is I have a MPE Steering Wheel II with race display and normally leave the engine temp display on while the car warms up. The only thing is I noticed on normal application the engine was quite some amount lower than normal. It was clear the cooling systems were firing away in Sport Plus mode. I normally find in sport mode the engine water/oil temps reached and then maintains about 106-109c (223-228F). Today they stayed around the 84C/93C (183F/199F) in Sport Plus. To test this further I switched to Sport Plus from Sport and the water temp dropped fast from about 228F to 200F in about 45 seconds.
Impressed! |
06-28-2015, 03:40 AM | #18 |
51
Rep 230
06-28-2015, 03:51 AM | #19 | |
4582
Rep 2,203
06-28-2015, 03:52 AM | #20 | ||
4582
Rep 2,203
06-28-2015, 08:30 AM | #21 |
908
Rep 1,110
Drives: M3CX
as long as it is within the safe range (all the temps listed are), you will probably not have the car long enough to notice any change in reliability/longevity.
Sold: 2008 335i, 2015 M3, 2018 M3, 2020 M2 Comp
Current: 2022 M3 CompX, 2024 M2 6-Spd |
