2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics Suspension | Chassis | Brakes Street/Track pads
      08-18-2014, 04:43 PM   #1
Liquidpaper
Liquidpaper's Avatar
Drives: '15 M235i
2015 BMW M235i  [0.00]
Street/Track pads
So, I intend to take my M235i out for track days. Accordingly, one of the things I am worried about is brake fade - several reviews have mentioned that the stock M-Sport pads just aren't up to the task over the long run.
Accordingly, I'm looking for some hybrid street/track pads. I plan on doing HDPE type events mostly, and am okay with some extra noise on the street and dust, if it means some better braking performance on the track.
Any suggestions? I've been looking but haven't been able to find anything - maybe because the 2 series is so new.
      08-18-2014, 07:02 PM   #2
mike@tpc
51
Drives: white M235i
for best results, switch back and forth, but I like carbotechs. I run XP12 on my 370z race car, but you might get by with XP8 for dual use
      08-21-2014, 05:43 PM   #3
daisy16905
10
Drives: 2014 M235i
Who has swapped factory pads for something with better grip for the track????
M235i (Black) Auto, JB 4 (Stage 2 / Map 7 with EWG & FF wires) ER DP, resonator delete, running E35, BMW Performance LSD, Hankook Ventus R-S3's (255/35/18 & 235/40/18) ATE Super Blue Racing brake fluid, 35% tint, black grills!
      08-22-2014, 11:27 AM   #4
Cybertronic
48
Drives: G30 M550i, E30 M3
Not used these on the M235, but have liked these on other cars in the past...
http://www.hawkperformance.com/perfo...t/pads/hp-plus
      08-22-2014, 01:16 PM   #5
daisy16905
10
Drives: 2014 M235i
Thanks for info, does not look like they currently make Hawk pads for M235i
      08-28-2014, 05:29 AM   #6
fegizi
Drives: 320
I think they make Ferodo DS2500 for the M235, but only front
      09-01-2014, 06:35 PM   #7
hoppy6698
hoppy6698's Avatar
Drives: M235i, Estoril Blue on Black
Akebono ceramic pads on my Audi A4. Beautiful pads, no dust, smooth progressive braking. Not sure if they have fitments for the M235i yet, quick google didn't find a proper size.
"Nothing in the world is more dangerous than sincere ignorance and conscientious stupidity." MLK Jr.
      09-02-2014, 10:26 AM   #8
Béhème
41
Drives: M235i
Though not a street pad, the Pagid RS-29 pads are available for our cars.
FRONT : # 4931
REAR : # 4933
      09-02-2014, 01:32 PM   #9
timsev
24
Drives: BMW
Track pads are simply not needed. Do not assume you'll get brake fade just because you read it somewhere in a magazine (or some guy on here thinks they will). I'm assuming you have little to no experience on the track. Stop worrying about track pads and all that stuff. Just go out to learn how to drive and get better. The stock brakes are more than adequate for tracking. If and when you get to the level where you can feel fade, then back off for a few turns until the brakes come back and you're good to go.
I have run 2.5 track days in the M235i with RS3 tires and stock brakes. The brakes held up just fine in 95+ temps with no fade. No crumbling, no pad knock, no pad deposits or warping, no excessive wear. I'm actually surprised at how well they have held up. Coming from 3 previous BMW track cars, I expected to smoke the oem pads, but haven't. I'm an instructor with several national sanctions so I'm not a noob.
      09-02-2014, 01:40 PM   #10
Liquidpaper
Drives: '15 M235i
Thank you very much. You are correct, I am very much a novice and have only had one day of HDPE so far a few months ago. That is great news that the OEM BMW pads hold up so well!
      09-02-2014, 01:48 PM   #11
daisy16905
10
Drives: 2014 M235i
Plus just adding high quality DOT 4 brake fluid with higher boiling = track worthy!
      09-03-2014, 02:40 PM   #12
Béhème
41
Drives: M235i
Based upon timsev's experience, and the fact I haven't received my track pads yet, I shall be going to the track with fresh Gulf Competition RF1000 fluid. That should be fine for my first time out with the 235 (coming off a S2000).
Peter
      09-04-2014, 04:56 AM   #13
Chris in Japan
Drives: BMW M135i on order
I also track my car regularly on stock pads. They have held up great with no fade. I run endless fluid and stainless lines.
Off topic I know, but I would recommend investing in set of square track wheels and tires. I corded my PSS's after 4 tracks days with only 5000km on the odo, and some of those k's were on my winter tires.
My ns2-r's have 6 track days on them, are faster, and still lots of life left.
      09-04-2014, 04:02 PM   #14
timsev
24
Drives: BMW
To add to this, stock pads and rotors are free for now so why not use them up? I can't justify spending my own money on brakes for a tiny bit of extra performance when someone is willing to foot the bill for me. Use 'em up and replace!
      09-10-2014, 07:59 AM   #15
Béhème
41
Drives: M235i
I tracked my car for the first time on Monday afternoon.
I did 2 twenty minute lapping sessions with the first one being very conservative (I'm not used to such a heavy car) and during the second one I was pushing it mildly.
I had fresh Gulf RBF 1000 fluid, and it held up well.
It's a track which is demanding on the brakes and the stock pads started to fade a bit during the second session.
Therefore, with me driving on this track, it is a given that I couldn't lap any more aggressively or participate in time trials with the stock pads - these would definitely require dedicated track pads.
My Pagids (RS-29) are on order, and I shall post an update when I've tried them out.
      09-22-2014, 06:10 AM   #16
Béhème
41
Drives: M235i
The Pagid pads I ordered aren't in yet, so I do my weekly lapping with the stock ones in the meantime, but I have to drive very conservatively and leave time between the sessions to minimize brake fade.
I still get fade, though it is not incapacitating - it's just that I don't always get strong & predictable braking, which reduces my enjoyment enormously.
So as soon as someone mounts a set of track pads, please let us know the make and model as well as how they perform.
      09-22-2014, 07:07 AM   #17
mike@tpc
51
Drives: white M235i
If you can send the backing plates from a stock set of pads to Carbotech, they can make you some great race pads.
      09-22-2014, 01:25 PM   #18
Béhème
41
Drives: M235i
Thanks Mike, I'm trying to go through my stock pads as fast as I can !!!!
      12-10-2014, 05:01 PM   #19
hyperzulu
hyperzulu's Avatar
Drives: 2015 M235i
Turner has StopTech pads for the front calipers:
http://www.turnermotorsport.com/p-20...-f32-435i.aspx
These are more cost effective than the Pagids, but maybe they offer nothing over the stock pads. I find the stock pads behave similarly to one of these street pads, as the pedal feel on the street offers less initial bite than what I'm used to on my e92 with the stock m-sport brakes.
      12-11-2014, 11:49 AM   #20
boomboom22
Drives: M235i
Any updates? Interested to see if anyone has actually tried out the RS-29's or any other track pads or street/track pads..
      12-11-2014, 12:59 PM   #21
Béhème
41
Drives: M235i
Though I haven't done extensive testing on the matter, but based on my experience, to get better track performance than the OEMs you would have to go to a dedicated track pad, given the stockers are so good.
      02-02-2015, 08:18 AM   #22
Béhème
41
Drives: M235i
Like the man says.....
2addicts
