Cobb Stage 2+ aggressive logs
08-10-2014, 07:28 PM | #1 |
9
Rep 113
Hey guys I need some input on my data logs, I just did a reflash to the Cobb stage 2+ aggressive map, I did 2 pulls in 3rd gear to about 5500 rpms on a highway I didn't want to push the car all the way to redline until I know for sure that everything is ok.
my 1st pull http://datazap.me/u/boostedbimmer10/...log=0&data=1-3 my 2nd pull http://datazap.me/u/boostedbimmer10/...og=1&data=2-11 I appreciate any help you can offer Thanks! |
08-10-2014, 10:39 PM | #2 |
35
Rep 1,652
Drives: '10 AW/CR e92 6mt 335i
What octane gas do you have access to? It seems you have above average timing corrections IMO. Did you disable DTC? Did you skip over the Sport map?
COBB AP Stg 2+ FMIC Aggressive | VRSF 3" Catless DP | COBB FMIC | BMS DCI | CP-e Metal Charge Pipe | 370+ whp/435+ lb.ft torque
08-10-2014, 11:30 PM | #3 | |
9
Rep 113
Ideally I should want the timing on all cylinders to be at 0 correct?? Since timing is being pulled it is to counter detonation?? Should I be cautious of anything?? I will be getting a PTF tune within the next couple weeks, once I have my charge pipe/DV & intake installed. |
08-11-2014, 12:24 AM | #4 |
35
Rep 1,652
Try a Sport log to see if its just the gas. I imagine if timing becomes too much of an issue I think it means loss of power up to misfires. What are your mods? You could always add e85 ike I've been doing. I'm on Aggressive but use to run Sport. Just watch your trims and adjust fuel scalars if needed.
08-11-2014, 12:46 AM | #5 |
98
Rep 615
Looks like my data logs on stage 1 aggressive and I have 94oct chevron in canada. Does your car feel slower than one might think for all your mods. Sport feels faster as it doesn't correct as much
08-11-2014, 09:23 AM | #7 |
9
Rep 113
currently my mod are only DP & FMIC.
As far as the performance on the Stage 2+ I def noticed the car pulls much more over stage 1 it does haul ass but I was expecting a little more power but I guess I'm not because of the timing being pulled? I've been using the same station since my first flash on stage 1 without any issues. I guess I'll try BP's and see if I have any issues |
