The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N55 Turbo Engine Tuning and Exhaust Modifications - 335i Tuning > is it just me or is something wrong?
      08-09-2014, 08:45 AM   #1
Schmidty335i
Drives: E92 335i PS2 turbo FBO JB4
I went to the track last night, it is a 1/8 mile track in the parking lot of qualcomm statium in San Diego. my car is a 2012 E92 6 speed with a JB4 map 5 with boost going up to around 17 psi, bms intake, catless dp and i was running 15% E85 tank was less than a 1/4 full also. i was racing my buddies 2000 trans am that only has exhaust and intake and it was a toss up on who would win. his best time was 9.05 at 84 mph and mine was 9.1 at 82 with a 2.4 0-60 which i know is horrible but traction there is not the best. where my question comes in is shouldnt i be making it into the high 8's at least easily? i am pretty confident in my driving i had a 2006 gto with intake exhaust and tune and could run low 13's and high 12's all night long. i have no engine codes or anything so as far as i know i have no boost leaks. its just kinda depressing not being able to get into the 8's with all that has been done to the car. oh and also i was shifting at 5.8k rpms cause after that the turbo falls on its face. thanks for any help or suggestions!
      08-09-2014, 11:09 AM   #2
SWalters
Drives: 2012 E92 335i
2012 E92 335i  [0.00]
Yep. Something is wrong there. My best time, bone stock - including runflats, is 8.76. I'm pretty near to 900' above sea level.
      08-09-2014, 11:23 AM   #3
Jdub679
88
Drives: 2011 BMW 335i coupe M Sport
I'm pretty sure you should shift a little higher than that. I think that BMS actually uses 6500 in 1st, 6400 in 2nd and 6300 in 3rd and on, or something very similar to that.
Also, guessing you don't have flex fuel wires since you didn't mention them. But you should get them and run more E85.
      08-09-2014, 12:18 PM   #4
MadToy
64
Drives: '18 340i Xdrive
2.4 60'. No traction, and no time to make it up in an eighth. Get traction, and a 2.0 will net you mid 8's.
      08-10-2014, 07:19 PM   #5
Johnny Boost
324
Drives: '21 M850i GC
It's hard to tell you anything if we cannot see your logs.
WedgePerformance E40 MHD | Performance Exhaust Mod | BMS DP | Vibrant 1790 | BMS Intake | VRSF CP | xHP Stage 3
Michelin PSS | M3 Control Arms
LUX v4 LEDs | Shadowline Grills | Lip Spoiler
      08-11-2014, 05:19 PM   #6
Schmidty335i
i knew something wasnt quite right! 8.76 sounds exactly where you should be with a stock 335i and a good driver. with the mods my car has you would think even with the worst driver it would be an easy high 8 second car and a good driver low 8's. i didnt run any logs due to the fact that iam not sure where i put my cable. i am gonna have to make it my mission to find it then run some logs cause something isnt right and i dont wanna continue embarrassing my 335i at the track when it deserves better than that!
      08-12-2014, 12:10 AM   #7
SWalters
I'd be willing to bet, with "all" the mods, and the right rubber on the ground, high 7's. I'm wondering if anyone's tried these, and how they worked out:
http://forums.bimmerforums.com/forum...ials-245-40-18.
