complete loss of boost and other weird problems
08-07-2014, 11:47 AM | #1 |
154
Rep 770
i have a procede v5 with 9-10 maps, dci, downpipes, exhaust.
a few days ago, my car started to feel slower. more recently, during WOT at about 2k rpm, there is zero boost and the car feels really weak. i'm talking it can barely get up a hill and the rpm's take forever to climb. it happens after the first 5min of driving. starting up the car even on cold start is fine. i read the codes and got these: 12140 (no worries there) 11905 11906 10927 while going for a drive to replicate the codes, this picture popped up: when i parked it in the garage, my OSS lights were flickering (first time i saw that, may or may not be relevant) finally, when i turned the car off, it sounded like a huge fan/turbine was powering down (much louder than any normal occasion). and there was a constant squeak/creak under the hood at 1 second intervals like something was trying to start up but it couldn't. does anyone have any experience with these strange symptoms? |
08-07-2014, 11:51 AM | #2 |
12
Rep 420
This is a pb with water pump failure no?
Mee after this indication few time after indicator become red after yellow Stop the car & water pump/termostat replacement |
08-07-2014, 12:27 PM | #5 |
421
Rep 1,643
Yes, It would cause the car to feel weak, loss of power/boost (a protection measure), and fan would be blaring at full blast.
Check your coolant level to make sure it hasn't dropped significantly to rule out a leak (it should be fine).
2007 E92 335i MT
08-07-2014, 02:46 PM | #7 |
12
Rep 420
Yes me fan was blaring at full blast, just few seconds after start the car!!
My bavarian tool pro said pb water pump, in fact water pump speed 0!!!! |
08-07-2014, 05:49 PM | #10 |
34
Rep 1,093
Codes are
12140 - 2F6C Exhaust flap (If you have a BT cable address to disable is 447AC set to 0) 11905 - 2E81 Electric water pump speed deviation 11906 - 2E82 Electric water pump shutdown 10927 - 2AAF fuel pump plausibility (No issue)
07 335XI (A008006) 6AT ~94K miles JB4 G5 ISO VSRF DP's
09 135I M (VK80379) 6MT. Race Project car. 1) Install Cobb/piggyback? and Motiv 600 Kit[HTA3076R w/ tial .82] 2) JRZ or Moton suspension. 3) Build high flow intake manifold with multi-port fuel and relocate OFH 4) Build full cage 5) Complete staged twin setup with HTA4205R [w/Tial 1.16] 6) Complete dry sump system |
