Logic 7 amp wont turn off
08-06-2014, 05:36 PM | #1 |
32
Rep 520
After many hours of troubleshooting my electrical drain problem I have found out that my logic 7 amp wont turn off and is keeping the car from going into sleep mode. If I un-plug the fuse or the amp directly the car goes to sleep and all is right with the world. But the strange part is the amp in every other aspect works great. My question is since these things are pretty expensive almost $650 used!! Has anyone ever heard of this kind of issue? I have never heard of an amp failing in a way that it always stays on? Any input is appreciated!
KW V3's / AA Stage 2 Supercharger / Catless Mid-pipes / AA Mufflers / Apex Arc-8's / PFC 09's |
08-07-2014, 01:35 AM | #2 |
1917
Rep 13,109
I think the power is switched elsewhere.
Any time a door or the trunk is open the car will stay awake.
This keeps the amp powered on as it used for gongs . Any time you open or unlock a door the car awakens. The fastest way to get the car to go to sleep is lock it . There are some details of you this works in the following document. What do define as asleep and how are you monitoring it. There should be about a 20ma draw on the battery when the car goes to sleep . If its awake its about .5 amps. http://www.google.com/url?sa=t&rct=j...,d.cGU&cad=rja read pages 34 onwards. http://www.e90post.com/forums/attach...2&d=1260829447 There are some more electrical pdf's here http://bmwcoders.com/forum/3-er-8/bm...1-e92-e93-291/ Never have seen this reported before. Last edited by ctuna; 08-07-2014 at 04:37 AM.. |
08-07-2014, 07:40 PM | #3 | |
453
Rep 2,973
There is a relay inside most amps connected to the positive lead. If that relay has failed in the on position, you have a couple of options. 1. Replace the amp. 2. have the amp fixed 3. Add an external relay that is turned on by the accessory power. I won't go into a lot of detail except that you would have to insert the relay in the mains and run an accessory positive to the "+" side of the relay and ground the other side. This essentially moves that circuit that is internal to outside the amp and will give you auto turn off. Would cost about $10-15 dollars to do it that way.
Arctic Metallic\CF Splitters, Spoiler, Mirror Covers\LED Tails\LSD\Tinted\Coded\Apex Square SM10-19"\LED Angel Eyes\Gloss Black Grill\Integrated V1 & Galaxy Tab\M-Performance Brakes\Cobb Tuned\xHP Flash\Resonator Removed and -> is your friend.
08-07-2014, 09:33 PM | #4 |
300
Rep 3,969
Perfect opportunity to upgrade!
Mobridge DA2 > JBL MS-8 > ARC XDi 600/4 > JBL Gti 408 Mids & Vifa OT19 Tweeters; PG Ti2 1600.5 > Morel HCW-10 & IDMax 15
