"Ebay" dual BOV's, $30 dollars all in
08-02-2014, 12:20 PM | #1 |
51
Rep 719
So after issues with my "aftermarket" diverter valves having constant leaks and their inability to reliably hold greater than 16 pounds of boost I ripped them off the other day... I had a pair of cheap (30 dollars combined) Ebay BOV's laying on my workbench, they're from a twin turbo fox body project that has stalled. I decided to borrow them for the xi... They're made of billet aluminum and brass, with an internal spring. The spec sheet that came with the valves (tons of misspelled words) claimed their operational range to be from 4-25 psi and if an increase in holding psi was needed all you have to do is get a washer and install it above the spring! I guess they don't believe in providing extra springs? I tested both valves with my Mityvac prior to installing them and they both seemed to work just fine. The install took 20 minutes and I plugged the intake diverter inlets with rubber stoppers that fit flush. Took the car for a quick ride and the valves seem to be functioning great! They do not have an obnoxious blow-off sound and hold perfectly up to a already tested 19 psi. I have not felt any compressor surge and they look decent under the hood. Hopefully they hold up for more than a year! Just wanted to share, take care...
ASE master tech (many moons ago)335xi- JB4 G5 iso/e50 custom flash/Custom meth/Borla mids/Custom x-pipe/DCI/ER charge pipe/Dual Ebay BOV's/Alpina B3 flash/Paddle shifter retro fit
06-02-2015, 09:28 PM | #4 | |
51
Rep 719
06-02-2015, 09:44 PM | #5 |
2134
Rep 3,554
06-03-2015, 07:03 AM | #7 |
172
Rep 1,910
Current: 2017 F30 340i xdrive
Previous: 2008 e92 335i coupe: RB turbos, mach 116 race fuel, methanol, alot of boost. Previous: 2003 Honda Accord V6 coupe: AEM V2, zex 75 wet shot (sold) |
06-07-2015, 04:30 PM | #10 | |
51
Rep 719
06-07-2015, 04:32 PM | #11 | |
51
Rep 719
06-07-2015, 04:33 PM | #12 |
51
Rep 719
These are pretty simple (as most BOV's) are and I'm fairly confident they will last.
07-12-2015, 08:25 PM | #15 |
37
Rep 656
I'm interested in finding this out as well. Apart from loud woooosh in 1st and 2nd gear I want to think my stocks are still holding up.
07-13-2015, 08:20 AM | #16 | |
The Cheap Arse Asian
47
Rep 585
PM me if you want
07 BMW E90 335i |JB4 + MHD Backend Flash (Pump) |AR Catless DPs|ER CP + Forge DVs|BMS DCIs + OCC|RB PCV valve + cap|
93 R33 Skyline GTS-T |SAFC-II piggyback|3" Turbo Back Exhaust + Highflow Cat|FMIC|Boost Tee|Apexi POD| Shitty Chinese spec tires = sideways action everywhere |
08-13-2015, 09:10 PM | #17 |
51
Rep 719
They aren't super loud but you can for sure hear them inside the cabin. They are holding up perfectly and I actually just installed some on a another forum members car last week. I'm not sure what "brand" they are...
08-13-2015, 09:12 PM | #18 | |
51
Rep 719
08-14-2015, 05:51 AM | #19 |
BimECU
193
Rep 759
hah.. they look exactly same as mine, that i got from the guy producing them locally
btw mine works perfectly! |
08-14-2015, 07:36 PM | #22 |
89
Rep 1,068
I installed these a few ago. They work fine, but I had to cut the springs as they were too stuff. I'm at 6500 feet altitude though which may contribute to the reason they needed to be cut.
335xi
