Do you use the automatic 'climate control' when parked? How?
07-30-2014, 04:27 PM | #1 |
14
Rep 323
So I've got lci m-sport that has everything short of heated seats.
I have no clue how to use the auto climate control feature in the car when the engine is off/parked. Have any of you used this? If so, what do I do?
Getting back to my roots!
07-30-2014, 04:34 PM | #2 |
123
Rep 1,166
I am confused, what is the use case for this situation?
You are saying you want AC/heat with the engine off? I can barely cobb tune my car for 15-20min with lights on before the battery runs out of juice... |
07-30-2014, 04:36 PM | #3 |
123
Rep 1,166
If Manual push in the clutch and push the power button once/twice for AC/heat.
If Auto just push the brake in and push the power button once/twice for AC/heat. |
07-30-2014, 04:39 PM | #4 | |
533
Rep 2,872
OP hitting the "rest" button will activate the blower when the engine is off, but i believe is only designed for heat. Edit: REST might only be for pre-lci.
BSM E90 6MT-JB4 G5 ISO-BMS DCI-Golf-Tee Mod-Hankook S1N2 Non-RFT-ER Chargepipe/TiAL BOV-E40 blend-VRSF V2's-M3 CDV-MHD/JB4 FLASH-VRSF 5" STEPPED FMIC
07-30-2014, 05:09 PM | #7 |
44
Rep 385
How this works is like this. Let's say you're at work. Your lunch is usually 12pm...so before going into work, you would set the timer at 11:35 am for the car to turn on the blower, so your car interior would be cooled before you head out for lunch.
Of course if you don't have efficient battery life, the blower won't work. It doesn't turn the AC on, just the car fans. Your interior won't be super cold, just a bit cooler by 5-10 degrees. I have this feature, but I never really use it, find it a waste of battery life, just find a shade and park. Works just a well. Now, the REST button however, I love that function! Sorry for grammars, typed this using iPhone app |
07-30-2014, 05:16 PM | #9 |
182
Rep 3,393
I think I've seen this option in my X5. I always thought it would crack the sunroof open to vent out or something. If it just turns the fan on without cracking the window or sunroof down slightly, would almost seem pointless. It'd just be pushing hot air around.
-Don |
07-30-2014, 05:17 PM | #10 |
52
Rep 471
07-31-2014, 09:06 AM | #11 |
14
Rep 323
LOL
By no means do I mean turning the ac on while the car is off. I meant the venting method that's on the idrive/dash. I have no clue how to get it to work. That was the point of this thread. I have no covered parking where I work and I wont leave my windows open. The sunshade helps but I have a black car with black interior.
07-31-2014, 09:52 AM | #12 |
Drop-Top Turbo
181
Rep 598
Drives: 2013 991 C2S/ 2013 335is E93
If you have iDrive, Menu --> Settings --> Climate --> There will be three choices. Activate parked car ventilation (Press this box and the AC works without engine power), Set Timer #1, Set Timer #2. You do not need to check parked car ventilation to get the timers to work. As mentioned before, when set to a specific time and the box is checked, the AC will start blowing gently at the given time for about 15 minutes. It is an incredibly useful feature for hot days when you know your lunch or departure schedules.
Current 2013 Porsche 991 Carrera S [Agate Gray] [Black] PDK, PASM, Sport Chrono, Sport Seats, Sport Techno Wheels, BOSE
Current 2013 BMW 335is E93 [Mineral White] [Coral Red] DCT, Premium Pkg, Convenience Pkg, Nav, Heated Seats, HK, BMW Apps |
